Old 04-14-2012, 09:04 PM   #1
LitRex315
Member#: 275563
2011 WRX 5-Door
Default loud whistling noise
Hey what's up everyone? I have a 2011 wrx hatch and I have had stage 1 torque tune for about a month now. My friend has the same car same tune and he his hitting 18psi. I have a loud whistle noise on acceleration and I'm losing 4 lbs of boost. I have read a lot about the plastic bpv being junk,has anyone had this problem or any sugestions for m
LitRex315 is offline   Reply With Quote
Old 04-15-2012, 11:03 AM   #2
Kinjirra
Member#: 258345
2009 Xterra
Had the same issue on my 08. Some leak some dont. Check to make sure everything is nice and tight, make sure the topmount isnt coming lose at the TB tube(they can blow off), make sure your endcaps of your topmount arnt leaking(those leak too...gotta love plastic pressed on crap). I ended up replacing my BOV with a Forge unit. Havnt had an issue since.
Kinjirra is offline   Reply With Quote
Old 04-15-2012, 11:57 AM   #3
LitRex315
Member#: 275563
2011 WRX 5-Door
Iv checked all the hoses and the intercooler,can't find it,I'm trying to get a forge bpv but having a hard time locating one
Old 04-15-2012, 12:01 PM   #4
Kinjirra
Member#: 258345
2009 Xterra
Give Foreman Performance a call or shoot them a PM...Talk with Jason or Vim. Top Notch guys that specialize in the 3rd gen Subaru's. Only place I buy parts from when it comes to my WRX.
Old 04-15-2012, 01:10 PM   #5
LitRex315
Member#: 275563
2011 WRX 5-Door
I'm gona check them out thank you man
Old 04-15-2012, 10:44 PM   #6
zombor
Member#: 246220
2004 WRX
San Remo Red!
I've got the same problem...Running 20psi, I get a really loud whine/whistle when it get past about 15psi. I've had the car checked for leaks, it's tight. Could it be the IC/bpv going not handling the high psi?
zombor is offline   Reply With Quote
Old 04-15-2012, 11:07 PM   #7
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
I didnt think with a stage 1 tune that you could or should be at 18lbs of boost that seems a lil high?
2011WRXMT is offline   Reply With Quote
Old 04-16-2012, 05:54 AM   #8
LitRex315
Member#: 275563
2011 WRX 5-Door
I'm not ruleing out any possibilites but I do know my friend with the same car,same tune is hitting 17.x at like 6k at the most
Old 04-16-2012, 05:55 AM   #9
LitRex315
Member#: 275563
2011 WRX 5-Door
It still makes the noise with the stock map
Old 04-16-2012, 07:02 AM   #10
GeNeTiC_FREAK
Member#: 205706
2002 WRX Wagon
check the throttle body to intercooler hose.
I had something like this, and it wast th TB hose that was fitted up side down:
GeNeTiC_FREAK is offline   Reply With Quote
Old 04-16-2012, 08:36 AM   #11
guygettnby
Member#: 298231
do a boost leak test or a smoke test on the car. that is the only real way to see were the problem is coming from.
on a side note, my stock by pass valve leaks at around 18psi slightly.
guygettnby is offline   Reply With Quote
Old 04-16-2012, 08:38 AM   #12
ETinder13
Member#: 234769
2016 WRX Limited
My 2010 was doing the same thing on a stage 1 map, it ended up being the throttle body hose being loose and the gasket blew out. I suggest t-bolt clamps and an aftermarket hose.
ETinder13 is offline   Reply With Quote
Old 04-16-2012, 09:10 AM   #13
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
I've also heard using hair spray on the inside of the tube to help it stay on as well, nothing crazy a little bit of spraying and wipe it off
freddy121389 is offline   Reply With Quote
Old 04-16-2012, 09:44 AM   #14
guygettnby
Member#: 298231
i heard the same thing and i tried it on my car when i took the ends off the hose and reinstalled using T-bolt clamps.
Old 04-16-2012, 12:56 PM   #15
LitRex315
Member#: 275563
2011 WRX 5-Door
I will definetly look into that thanks for the advice man
Old 04-16-2012, 01:07 PM   #16
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
Something seems off here im guessing your running the AP with the stage one OTS map? If so then then your going past the target boost.
Stage1 ACN91 MTv300
- Intended for an otherwise stock 2009-2011 Subaru WRX MT vehicle with a stock or
cat-back exhaust, STOCK INTAKE SYSTEM, and STOCK INTAKE FILTER ONLY. Intended for Arizona, California, and
Nevada 91 octane fuels. Boost Targets: ~14.5psi peak boost pressure tapering down to ~12.5psi by the 7000
RPM redline, +/- 0.8psi.
Stage1 91 MTv300
- Intended for an otherwise stock 2009-2011 Subaru WRX MT vehicle with a stock or catback
exhaust, STOCK INTAKE SYSTEM, and STOCK INTAKE FILTER ONLY. 91 or 92 octane fuels. Boost Targets:
~15psi peak boost pressure tapering down to ~13psi by the 7000 RPM redline, +/- 0.8psi.
Stage1 93 MTv300
exhaust, STOCK INTAKE SYSTEM, and STOCK INTAKE FILTER ONLY. 93 or 94 octane fuels. Boost Targets:
~16.5psi peak boost pressure tapering down to ~13.5psi by the 7000 RPM redline, +/- 0.8psi.
Old 04-16-2012, 02:07 PM   #17
ETinder13
Member#: 234769
2016 WRX Limited
My stage 1 map hit 17.5 psi, it wasn't a Cobb though.
Old 04-16-2012, 10:14 PM   #18
LitRex315
Member#: 275563
2011 WRX 5-Door
It was a opensource torque tune
Stage1 ACN91 MTv300 - Intended for an otherwise stock 2009-2011 Subaru WRX MT vehicle with a stock or
Stage1 91 MTv300 - Intended for an otherwise stock 2009-2011 Subaru WRX MT vehicle with a stock or catback
Stage1 93 MTv300 - Intended for an otherwise stock 2009-2011 Subaru WRX MT vehicle with a stock or catback
Old 04-17-2012, 06:32 PM   #19
LitRex315
Member#: 275563
2011 WRX 5-Door
Throttle body hose was lose...lol thanks everyone for the advice u guys rock !!!!
Old 04-17-2012, 08:40 PM   #20
dsmtweaker
Member#: 265405
2013 Audi
I would still look into a better solution, such as the AVO, that stock TB coupler will keep coming loose, or start breaking at its glue points.. trust me.
Here is the AVO... http://www.avoturboworld.com/avoshop...hose-p-33.html
dsmtweaker is offline   Reply With Quote
Old 04-17-2012, 09:15 PM   #21
ETinder13
Member#: 234769
2016 WRX Limited
I'm glad to see you found the problem, but just be aware... it can/will happen again!
Old 04-17-2012, 09:23 PM   #22
kingme
Member#: 280943
'11 WRX
Yup, the AVO hose and t-bolt clamps fixed my leak as well.
However, if I were to do it again I'd just take off the rubber end caps and use t-bolt clamps with the stock hose and some hairspray.
kingme is offline   Reply With Quote
Old 04-17-2012, 11:24 PM   #23
LitRex315
Member#: 275563
2011 WRX 5-Door
I'm getten the black one so that don't happen again
Old 04-18-2012, 12:22 AM   #24
tom312
Member#: 261936
2006 WRX STi
I had this the other day and turns out somehow I blew the hose from the turbo to intercooler right off, scared the **** out of me at first!
tom312 is offline   Reply With Quote
Old 12-30-2012, 06:27 PM   #25
LitRex315
Member#: 275563
2011 WRX 5-Door
Did that ever happen again?
Loud whistle/kazoo noise, loss of boost, white-ish smoke in oil fill tube Scooby921 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-08-2010 09:30 AM
Loud whistling noise after downpipe install....leak? AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 11-01-2008 10:27 PM
Loud Whistling Noise from Windshield SF Baja Baja Forum 9 09-06-2007 04:11 PM
Loud whistle noise at speeds > ~100mph? ZackyFarms Newbies & FAQs 13 05-27-2007 11:01 PM
Loud Whistle at 110mph SGOSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-27-2001 02:17 PM
