Old 04-16-2012, 02:49 AM   #1
joec wrx
Member#: 112359
14 Challenger RT
Default Hi-flow cat gone bad
I went to have my car protuned the other day and my tuner said my car was lagging due to a bad cat. I went to have the car checked, sure enough there was a crack inside. Now I'm running catless and going for a re-tune tomorrow. Could a bad cat cause power loss? Turbo lag? My tuner didn't want to tune my car until I got it fixed.
joec wrx is offline   Reply With Quote
Old 04-16-2012, 02:37 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
what happens when a sink or tub is clogged?
nhat is offline   Reply With Quote
Old 04-16-2012, 03:41 PM   #3
joec wrx
Member#: 112359
14 Challenger RT
Lol I get the point
Old 04-16-2012, 08:02 PM   #4
Bug-Eye WRX
Member#: 316988
2002 Impreza WRX
Power loss, yes, but how does this cause turbo lag if it is behind the turbo?
Bug-Eye WRX is offline   Reply With Quote
Old 04-16-2012, 08:16 PM   #5
mrsmithz9
Member#: 314767
2003 wrx
Turbo needs exhaust -> flow <- to spool, clog means no flow...
mrsmithz9 is offline   Reply With Quote
Old 04-16-2012, 10:18 PM   #6
Bug-Eye WRX
Member#: 316988
2002 Impreza WRX
That makes sense. To get gases through the turbo to spool quicker, it has to be able to flow out just as quick.
Old 04-17-2012, 02:35 PM   #7
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
yes exactly, running cats on a turbocharged car is quite redundant
brew02wrx is offline   Reply With Quote
Old 04-17-2012, 02:59 PM   #8
joelkarlonas
Member#: 317169
You'll see better results without a cat, high flow or not.
joelkarlonas is offline   Reply With Quote
Old 04-17-2012, 02:59 PM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
what?
Old 04-17-2012, 03:43 PM   #10
Bug-Eye WRX
Member#: 316988
2002 Impreza WRX
Originally Posted by nhat
what?
I think they mean that cats restrict flow, so running no cat at all is better.
Old 04-17-2012, 03:54 PM   #11
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
the NA honda guys thought i was nuts when i told them i was catless. told me i needed some source of back pressure. ha because a turbine wheel doesnt create sufficient back pressure lol. catless on a turbo car is basically the only way to go!
WhiteBgeye02 is offline   Reply With Quote
Old 04-17-2012, 04:23 PM   #12
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
I would rather not kill the environment for 5HP, so I have the Perrin high flow cat.
Ernest is offline   Reply With Quote
Old 04-17-2012, 04:38 PM   #13
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
fair enough^
Old 04-17-2012, 08:06 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
exactly.
and redundant wasn't used correctly.
Previous CATS HID conversion gone bad!! Jondoe1980 Interior & Exterior Modification 3 09-13-2011 09:51 PM
Stock cat vs Hi-flow cat whittleman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-19-2004 12:45 PM
hi-flow cat on downpipe or 3rd cat location showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-16-2004 07:33 PM
Header and hi-flow cat OR Cat-back? 2.5GTL Normally Aspirated Powertrain 5 06-14-2001 11:11 AM
Replacing stock cats with hi-flow cats Keiho Normally Aspirated Powertrain 2 01-04-2001 05:02 PM
