Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Motorsports Specific Items
Old 04-07-2012, 12:39 AM   #1
biknman
Member#: 47915
2003 GG HC TT
08 STI 06 OBXT 96 GC coup
Default Moroso wet sump Oil Accumulator Crawford AOS, 3pc 16x9w/Hoosiers, ACDC TIG welder etc
Giving yaw first debs on some stuff I'll be posting to eBay this weekend. Looking for $ (Paypal preferred) or to trade for a set of Injector Dynamics or Deatschwerks 1000cc top-feed injectors or Fuelab electronic fuel pump controller -8an fittings. Prices includes shipping (unless noted) via my discretion probably USPS to any of the 48 lower states. Will ship once payment is received in full. Local pick up is OK, I'm willing drive within 50 miles of Baltimore, MD. Lots of pics in album @: http://biknman.shutterfly.com/8 or upon request or via Ebay this Sunday search for user id biknman
Dave
Going dry sump so Wet Sump stuffs got to go:
SOLD Moroso wet sump 5 qt Aluminum oil pan with new cork gasket
SOLDOil Accumulator set up includes: Moroso 1.5qt Accumulator with -10an fitting, Canton sandwich adapter -10an, Canton remote manual valve Cable kit, Stainless mounting brackets, Moroso one way oil check valve 1/2 NPT (new) with -10an steel fittings, two -10an Stainless assembled hoses with fire-sleeving and Alum fittings, one -10an bulkhead fitting, one -10an aluminum hard-line with fittings.
SOLDCrawford V1 air oil separator with hoses cut and some push in -10AN fittings installed. Mounts to the passenger side of trans dog bone might work with TMIC I used with with a rotated turbo, reversed intake manifold, and FMIC
SOLD 02-03 WRX Perrin top feed black fuel rails with blue aluminum -6an fittings, also have the distro/FPR block modified to be used only as distro block. Included 4 straight -6AN push lock aluminum fittings with various length of hose attached (may need to be replaced).
03 WRX OEM stuff;
Front DS and PS Door cards best offer + shipping. Probably be more for shipping than I want of the cards. Pick up at my house for free :-).
"Bug Eye" Headlight left and right side with lamps $100 each shipped. DEAL PENDING
Passenger side airbag don't know if I can ship if I can and there specials fees it at your expense $75 + shipping.
Air bag SRS control module $30 shipped.
ABS pump F/U/W MT with wheel sensors $100 shipped.
SOLD Installing a EPAS so the hydraulics got to go.
Power steering pump setup with -10an and -6an fittings and UR lightweight aluminum pulley also includes; OEM Mount modified to remove the alternator side, -10an hose assembly F/U/W a KRC aluminium fluid reservoir (-6 and -10AN fittings) and pump input, two high pressures hoses with -6an fittings F/U/W output high pressure side of pump to rack hard line and low pressure from rack hard line to fluid reservoir. $200 shipped
Running 305s now on 16x11 so the below got to go.
Real Racing Wheels Pro 6s 3 piece with both 5x100 and 4x100 centers currently mounted with the 5x100s. Very light wight only 14.66lbs per wheel. New $360.00 each with one center ref: http://www.realwheel.net/products.php?catid=17 These easily fit over my Wilwood BBK with 12.88" rotors and 6 pot calipers in the front (140-7005) and 11" rotors 4 pots in the rear (140-7006) no spacers needed. OEM fenders may need rolling or trimming to prevent rubbing. Had no rubbing on my Stock 03 WRX wagon rear quarters that where mildly rolled and inside lip trimmed setting on RCE KW V3s.
They are mounted with 245 R6 Hoosiers (FYI 19lbs per tire) that have about %50 of life left in them.
Looking to get $1250+shipping+paypal fees, PRICE FIRM AND FIXED. Willing to drive up to an hour to deliver or local pick is available.
Pic form last time they where used at an AI Autox Waldorf, MD May 2010
Last is a Miller 230V AC/DC Econotig TIG and Stick welder with cart, 80cf gas bottle 3/4 full 100%argon, lots of aluminum and stainless 3/16" and 1/8"filler rod, red green and orange tungsten, and various TIG torch consumables 3/16" and 1/8" also HF auto dark Helmet.. $1200 Local pick up preferred but willing drive up to an with in an hour of Baltimore, MD or to drop it of at a local freight company if you willing to pay for it be packed up and shipped by them. Or you could use uShip - The Online Shipping Marketplace - Ship Freight, Furniture, Cars or Moves
That way you could also get the gas bottle. As I think most freight company's might have an issue with handling it.
biknman is offline   Reply With Quote
Old 04-07-2012, 03:25 PM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
pm sent
rjrutzky is offline   Reply With Quote
Old 04-07-2012, 10:13 PM   #3
biknman
Member#: 47915
2003 GG HC TT
Couple more item I found to sale:
03 WRX Lightweight crank pulley stock size $50 shipped.
Pic taken 7 April 2012
04 STI driver side Headlight $100 shipped SOLD
Turbonectics Evolution External 38mm Wastegate with 9psi spring and three spacers new gasket have stainless flanges for welding to exhaust can also supply short length of Stainless pipe for fabrication / installing. $150 shipped.
Momo race shift knob and e-brake handle both universal. $100 Shipped. Will throw in the pedal covers aluminum with little round rubber traction knobs and the leather shift or e-brake boot for free.
Pic taken 7 April 2012 bad cell pic can taken more if needed
Dave
Old 04-09-2012, 08:55 AM   #4
biknman
Member#: 47915
2003 GG HC TT
More stuff to sale. Seems the more I sale I find others stuff that's been hiding to get rid of:
03-07 WRX Primitive rear diff 3/16 skid plate with mounting hard ware $60 SOLD
I set of dual piston forged disc brake calipers for use with solid rotors. Got these with a hydraulic handbrake from a outfit that had them on Mazda Miata or Protege can't remember for use with a hydraulic hand rear brake setup in a drift car. Comes with what looks like new Hawk (I think DT60) pads and all -4AN SS TFPE lines and fittings, 1/4" aluminum mounting plates and grade8 hardware. $150 shipped
Also have a box of various -6an fittings and SS covered hose and one 90degree -20AN with about 8" of SS hose attached if interested PM me
Old 04-09-2012, 08:56 AM   #5
biknman
Member#: 47915
2003 GG HC TT
Bump for lots more stuff added see above post and for new more recent pics added and stuff sold noted.
Old 04-09-2012, 11:12 AM   #6
biknman
Member#: 47915
2003 GG HC TT
Another one.
SOLD Out date for SCCA FIA cert 04/09 G-Froce 5 point black cam lock pull down harness used four times $50 shipped
Old 04-09-2012, 01:36 PM   #7
biknman
Member#: 47915
2003 GG HC TT
Originally Posted by rjrutzky View Post
pm sent
Trying to leave postive I-trader feedback for ya, but it keeps giving me the follwoing error message,
"The following errors occurred with your submission:
1. The deal URL is invalid!"
WTF?
Old 04-12-2012, 11:14 PM   #8
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
condition of the bugeye headlights? interested.
RS drifter is offline   Reply With Quote
Old 04-13-2012, 07:04 AM   #9
biknman
Member#: 47915
2003 GG HC TT
Great! They were taken of car when it was pulled off the road to become a race car at around 40,000 miles and swap to a 04-05 front end. Used the 3m protecting film on them most of that time. Can send detail pics if needed just need an email address or I can post them up @ http://biknman.shutterfly.com/8 on request.
Dave
Old 04-13-2012, 09:51 PM   #10
biknman
Member#: 47915
2003 GG HC TT
Update PS stuff sold
Old 04-15-2012, 04:23 PM   #11
biknman
Member#: 47915
2003 GG HC TT
Update Deal pending on 04 STI DS headlight and rear diff skid plate.
More stuff for sale:
Aet of OEM quality 03-07 WRX strut tops NIB $50 shipped.
Stock 03 WRX full set of cams BO + shipping
Stock 03 WRX PnP's intake manifold with PnP'd + Kife-edged throttle body $100 shipped
Stock 03 WRX DS and PS mirrors black $100 for pair shipped.
Dave
Old 04-16-2012, 07:46 AM   #12
biknman
Member#: 47915
2003 GG HC TT
Update 05 STI Headlamp and rear diff skid plate sold
Old 04-17-2012, 03:20 PM   #13
biknman
Member#: 47915
2003 GG HC TT
Update deal pending on Fuel rails.
Old 04-19-2012, 11:42 AM   #14
biknman
Member#: 47915
2003 GG HC TT
Update Fuel rails sold.
And have the following for sale:
HKB Boss adapter for using a Momo or Sparco type steering wheel webs says it will fit Subaru Impreza/WRX 99-Up Legacy/Forester 99-Up, Outback 98-Up also has the chip for the air bag removal. $50 shipped
Here a pic of PnP'd intake manifold with throttle body FS probably do BO+shipping
And some more stuff I have
WRX MC BO+shipping
Brake Booster Bo+shipping
03 WRX steering column wiper light turn signal etc control module Bo+shipping
03-07 WRX Stock type NIB front strut mounts $50 shipped
Dave
Old 04-23-2012, 02:08 PM   #15
biknman
Member#: 47915
2003 GG HC TT
Update for G-Froce 5 point Sold
Old 05-20-2012, 08:35 PM   #16
biknman
Member#: 47915
2003 GG HC TT
Bump lots of stuff still available
Old 09-02-2012, 03:10 PM   #17
Beachbum911
Member#: 330139
2002 wrx
would the xm radio work for a stock 02 radio plug n play?
Beachbum911 is offline   Reply With Quote
Old 09-02-2012, 03:11 PM   #18
Beachbum911
Member#: 330139
2002 wrx
would the xm radio work for a 02 stock radio?
pm me
Old 09-04-2012, 12:28 PM   #19
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
Was the whole power steering Set up sold or still for sale. It's a tad unclear.
bugeyesubie is offline   Reply With Quote
Old 09-05-2012, 07:29 AM   #20
biknman
Member#: 47915
2003 GG HC TT
Yup sold several months ago :-)
Old 09-05-2012, 07:34 AM   #21
biknman
Member#: 47915
2003 GG HC TT
I sold it many months ago or I could have tried so sorry I have no idea .
FS : Crawford V1 AOS Air Oil Separator - $150 Woodenhorse VIC Private Classifieds 17 05-08-2012 11:12 PM
FS : (WA) Moroso oil pan, perrin EL headers, Crawford V2 AOS leonbmx Engine/Power/Exhaust 36 12-01-2010 01:35 PM
FS : Moroso oil pan, perrin EL headers, Crawford V2 AOS, Black Enkei RPF1 leonbmx NWIC Private Classifieds 26 11-22-2010 11:49 AM
WTB : Crawford V1 AOS FMIC Bariga Private 'Wanted' Classifieds 4 09-28-2010 03:02 AM
CT: FS - CT : Perrin rails, 5Zigen wheels, Act Flywheel GottaREX Private 'For Sale' Classifieds 11 05-11-2004 08:53 PM
