Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-14-2012, 07:16 PM   #426
seb28
Member#: 291749
2007 Impreza WRX
WHITE
Today the alarm goes off when I opened the trunk... So now the only moment it dont goes off is when I open the doors ( I tried driver and passenger side )
seb28 is offline   Reply With Quote
Old 04-15-2012, 11:39 PM   #427
CSVT_2004
Member#: 182213
1999 Contour SVT
Originally Posted by seb28 View Post
I know it has the OEM alarm because i heard it last summer and now it goes off but only when I the the key to "ON"... I just don't understand why does it don't work with the door and the trunk now
Do the dome lights come on for those doors when they are opened?
CSVT_2004 is offline   Reply With Quote
Old 04-15-2012, 11:44 PM   #428
Chrisbande
Member#: 280580
2002 WRX WAGON
World Rally Blue
Originally Posted by CSVT_2004
Have you tried rolling down the drivers window, arming it, waiting 1 minute, and then reaching in and opening the door from the inside? The alarm should disarm if you put the key in any door/trunk key cylinder so you don't set off your alarm when entering or opening the vehicle.
An aftermarket alarm. Example, Viper 350hv. If you want remote start alarm Viper 5701.
Ended up getting a viper 350 plus thx for the advice.
Chrisbande is offline   Reply With Quote
Old 04-15-2012, 11:55 PM   #429
CSVT_2004
Member#: 182213
1999 Contour SVT
No problem. Where from, because if it was bby it includes install labor... Also if you bought it from an website be prepared to probably not have a viper warranty.
Old 04-16-2012, 07:43 AM   #430
seb28
Member#: 291749
2007 Impreza WRX
WHITE
Yes! My done light is 24 LED so its hard to miss
Old 04-16-2012, 10:54 AM   #431
Chrisbande
Member#: 280580
2002 WRX WAGON
World Rally Blue
I went to a shop and had them install it. Works great
Old 04-17-2012, 05:51 PM   #432
Jaybfox4
Member#: 316662
2002 Subaru WRX
Default Tried reprogramming remote and now wont work
So i tried to reprogram my remote today and i put the key in and turned it 10 times and the horn chirped. Then i didnt apparently open the door and push a button on the keypad right. Took my key out and the horn chirped again(off). Now i have no working remote... Tired to start over but couldnt get the horn to chirp??
and i just looked at the flashing light and it looks like it in valet mode. blink blink pause. so i cant get it out of valet mode cause my remote dont work.
So what do i do now to program my remote?
Jaybfox4 is offline   Reply With Quote
Old 04-18-2012, 12:06 AM   #433
CSVT_2004
Member#: 182213
1999 Contour SVT
Maybe someone had a security system in there prior, know how to use a multimeter?
Old 04-18-2012, 07:03 PM   #434
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Repeat the procedure...follow the steps in the first post of this thread. There is also a section there if the car is in valet mode
RexyGirl is offline   Reply With Quote
Old 04-21-2012, 08:38 PM   #435
YamahaBoi
Member#: 317646
new here. was browsing through the forums and this was one of the many things i needed! thanks much!
YamahaBoi is offline   Reply With Quote
Old 04-25-2012, 10:54 PM   #436
04nhbpep3
Member#: 264798
So if I get any older remote, could I program it to work with my car? My car didn't come with one and I've already locked myself out three times
04nhbpep3 is offline   Reply With Quote
Old 04-27-2012, 02:07 AM   #437
CSVT_2004
Member#: 182213
1999 Contour SVT
2 remotes, @bby it'll include install except for the 5 material fee assuming they don't need any extra parts.
http://www.viper.com/P-412V/Viper-21...s-Entry-System
Old 05-04-2012, 03:21 PM   #438
iiibbb
Member#: 227273
7&11 Imprez$Forester
I have a 2007 Impreza 2.5i. For the life of me I cannot get the car to go into program mode. Is there some special way one needs to turn the key. Should the key be in the ignition when I open and close the door?
The stupid dealership wants to charge me $50 per remote just to program them because I already have a couple of used remotes... since I spent a ghastly amount of money having non-transponder keys cut- I couldn't let myself knowing there was a manual way that I hadn't gotten working yet.
EDIT-----
This is an apparent variant of the instructions widely distributed. This worked on a 2007 Impreza 2.5i
1) Make sure everything is shut (same as other instruction).
2) Get in, sit down, shut door (same as other instruction).
3) Open and shut door (same as other)
4) Put key in Ignition and turn key from "lock" to "on" 10 times, and finish in "lock" (slightly different from described)
- no tones or flashing lights occur as described
5) Open and shut door
- a faint tone is heard
6) Enter numbers as directed. Push lock the number of times that equals the value, then unlock between each digit.
- a tone is heard for each press
7) After <unlock> of last digit of the first sequence, hit unlock an additional time.
- tone flutters
8) Reenter sequence.
- tone for each press
9) for additional remotes or to push other codes out skip to 9a)
10) Open and shut door
- long tone
11) Remove ignition key
9a) Open and shut door
9b) Enter first sequence as described above
9c) After <unlock> of last digit of the first sequence, hit unlock an additional time.
9d) Reenter sequence.
9e) Continue to step 10 or 9a
Your mileage may vary - but that's what worked for me after a frustrating afternoon. I got my hint here http://www.clubwrx.net/forums/interi...tructions.html that the process may deviate from the description... and dumb luck opening and shutting the door when the lights weren't blinking.
iiibbb is offline   Reply With Quote
Old 05-04-2012, 09:39 PM   #439
pj2002wrx
Member#: 311204
i been trying to program my fob but i cant get the car to flash the lights or beep the horn is there a sensor or fuse that could be blow if so were is it iocated? i been trying for over a month to get this to work on my 02 wrx any ideas?
pj2002wrx is offline   Reply With Quote
Old 05-04-2012, 10:06 PM   #440
iiibbb
Member#: 227273
No horn of flashing lights for me... the standard programing method didn't work either...
...see my most directly above. Worth a try. There seems to be some variability.
Maybe you have the button? Our '99 had a button underneath the dash for that.
Old 05-04-2012, 10:20 PM   #441
pj2002wrx
Member#: 311204
no button under dash on 02wrx i unhitched batt no luck i found a plug unhitched under the kick panel hooked back up no go
Old 05-06-2012, 02:20 PM   #442
pj2002wrx
Member#: 311204
Well found out my keyless entry unit is no good
Old 05-06-2012, 06:30 PM   #443
iiibbb
Member#: 227273
Used, cheap(er)
http://www.carandtruckremotes.com/
Old 05-08-2012, 11:21 PM   #444
cboettch
Member#: 301752
iiibbb
Thanks ever so much for finding these crazy voodoo instructions and posting them. This was very well timed. I've just programed a new remote (on the 2nd try) using this write up (after not being able to do it following the factory instructions??) on my '07 2.5i.
I had purchased the car last fall with only one remote and the lock button did not work. So after purchasing a new remote on line. I attempted to program it. Well after hours of frustrating failure (nothing after 10x on/lock), I discovered, here, on another post that apparently the chirp/buzzer had to be functioning in order for the programing to work. Until then I did not know there was a chirp, because mine didn't work. So I left it for the winter, and today once again following this thread http://forums.nasioc.com/forums/showthread.php?t=608657&page=17 I got my chirp working, only to find I still could not get any further in the steps.
Of course now that the remote is working I've turned the chirp off. Just wonder now if I really needed it to be functioning in order to program the remote.
And why the heck does this method work and not the one in the owners manual??
Thanks again
Chris
cboettch is offline   Reply With Quote
Old 05-09-2012, 06:22 AM   #445
iiibbb
Member#: 227273
Originally Posted by cboettch View Post
iiibbb
Thanks again
Chris
Just dumb luck-- I mostly figured it out on my own through trial and error, but I credit the hint I got from that website to clue me that it might be different. I wasn't paying the dealership $100 after they burned me for $60 for a couple of keys.
Old 05-09-2012, 09:14 AM   #446
iiibbb
Member#: 227273
as to why the other instructions don't work. I suspect the changed it and didn't tell the people who write the manual. The above are actually simpler than that other craziness.
Old 05-09-2012, 02:34 PM   #447
SubieCS
Member#: 252747
'02 Impreza WRX
My lights flash when lock/unlock and the horn sounds. The remote functions perfectly...but the security light on the dash doesn't flash or anything. I used to lock the car with the remote, tap the car and the horn would honk once, now it doesn't do so anymore; i'm convinced the alarm is not armed.
I tried the steps but it doesn't seem to be working and when i cycle the key 10 times- 15 times, the horn doesn't beep.
Any tips?
Thanks guys!
SubieCS is offline   Reply With Quote
Old 05-11-2012, 08:02 PM   #448
GRUMPY514
Member#: 112285
2014 BMW 535i
Alpine White
Lost the key to my 2011 STi. Found a key fob online, well the process listed on the first page work with this key?
GRUMPY514 is offline   Reply With Quote
Old 05-22-2012, 03:23 AM   #449
airkareem
Member#: 293700
So i have a 2011 impreza and i managed to lose a set of key and remote. I need to get it replaced but the dealership told me it would be $300. Any ideas that are cheaper and i can do on my own? Any help would be super appriciated.
airkareem is offline   Reply With Quote
Old 05-22-2012, 09:09 AM   #450
iiibbb
Member#: 227273
Locksmith would likely be a little cheaper.
I also noticed that some hardware stores (an ACE hardware specifically) are doing transponder keys as long as you have another.
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
