Old 04-19-2012, 02:40 PM   #501
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Junior2JZ View Post
93
Still on the billet 35r
This thing is tuning like an Evo 9 timing wise. 2 degrees over my usual Evo maps on 93 and a 35r.
Btw, I lost the thread on the vf power band shape and low end hit vs linear mid and more top end. I agree and usually tune my vfs in the manor.. I have 3 vf cars in the 11s as proof, don't worry I'm building another to drive the point home.
Wow I was thinking you had that 6266 on there, so you did not even install that turbo. I was thinking about the 5862 CEA for my XTI once I do the motor. What is the final calculated compression ratio you're running and what headers do you have on the XTI? Still rocking the Spearco TMIC?
That curve looks pretty linear and pretty darn early as well, no lag at all, making 300 WTQ at 3700-3800, I'm sure you could fit a stock VF curve inside of it.
Very NICE!!
Old 04-19-2012, 03:50 PM   #502
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
He needs a 6466, it seems that the 6466 is a beast
Old 04-19-2012, 05:34 PM   #503
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Originally Posted by creative wrx View Post
the car hits boost and just keeps going cant wait for it to be back on E85 and see what it does with the new motor.
Thanks for all your help Dom, your VF shall do work shortly
Originally Posted by spoolinsti05 View Post
good work Jr. ****'s gonna ripe when you going to the track man?
Maybe the weekend, just enjoying it for now. Perfect DD, ice cold AC, handles, stops, pulls, and I can lug around the rottie and kid comfortably.
Originally Posted by OppositeLock View Post
^Nice! I'll save you some build trouble, just retune mine and I'll run it enough to get in to the 11's! You know, just trying to help you out.
Hit me up and lets do it!!
Im figuring if my 3500lb XT went [email protected], a 2800-3000lb STI will go a little faster
Originally Posted by soon2bblackongold View Post
Thanks jr, it's hard to put the words down when ALMOST everyone is doubting. Can't wait to see your work on the gtr world.
Trust me I know I don't even argue, I just let the cars do the talking
Im taking it slow with the GTR stuff... Not very many made and def a lot of people tuning them, plus I have JohnV
Originally Posted by Bariga View Post
New Rails? Are they o-ringed or NTP threaded?
Oring, I had the old style NPT ones.
Very NICE!!
Im not even doing much WGDC tuning to make it spool, I am still using the old settings from the stock motor. It comes in about 500 rpm faster.
62 will be going on in a few weeks, compression I will do shortly. I am not sure were it ended up. Spearco still kicking ass
My ultimate goal is 600tq/700whp on e85, I made 800whp with a 6266 so I think I will get were I want with the 62 and still have my TQ
Old 04-19-2012, 07:07 PM   #504
manitou
Member#: 193757
2006 XTI Limited
Sweet JR! You're using the 9.8/1 Manley's right? Can you shoot some pics of your engine compartment after you get the 6266 installed? Can't wait to see what that does on PG and E85! What are you running for crankcase ventilation, Crawford AOS or....?
Old 04-19-2012, 11:15 PM   #505
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Yep, 9.8's with thinner HGs and decked heads/block. We wrote it down somewhere, but I think it was like 10.2-10.3. The off boost is great, and the transition into boost even better. It is also getting some nice gas mileage now.
I will post pics tomorrow with the HTA82 tomorrow. I am running a custom can with -8an lines right now, but I did pick up a crawford AOS to install when I swap the turbo.
Im getting antsy.. I might take her to the track tomorrow on pumpgas and see how close to the 10s I can get.
Jr
Old 04-20-2012, 08:41 AM   #506
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i'd ask what track but i'll be at bassnectar tonight...
Old 04-20-2012, 09:08 AM   #507
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
Wait till I get out of class first dobt want to miss it
creative wrx is offline   Reply With Quote
Old 04-20-2012, 12:27 PM   #508
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
So its areomotive rails?
Old 04-20-2012, 12:43 PM   #509
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Old 04-20-2012, 12:51 PM   #510
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Clean man.
Old 04-20-2012, 01:08 PM   #511
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Originally Posted by wgr73
Clean man.
And so slow......
smeerone is offline   Reply With Quote
Old 04-20-2012, 02:09 PM   #512
manitou
Member#: 193757
2006 XTI Limited
Yes, nice and very clean EC!! I like where you mounted the catch can, it keeps it up higher so that should help with the drainage on the Crawford when you install that. I just bought a Crawford as well I'm gonna swap it in for the 2 stage/ Grimm AOS & Greddy can I have installed now. I like the closed loop and heated aspects of the Crawford AOS, it should work much better. I also really want to stay with a TMIC to keep the charge path short.
Are you using the rear reservoir for IC spray?
Old 04-20-2012, 02:53 PM   #513
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
What BOV is that?
g00fy is offline   Reply With Quote
Old 04-20-2012, 03:28 PM   #514
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
4th gear, 20psi still on 93 only reved to 6k due to traffic.. Something isn't right about the displayed power though. It doesn't feel like a 560whp car, but then again I'm used to a high 600s and 700+tq in my daily driver. So maybe it is making some good power, it def spools good!
Old 04-20-2012, 03:34 PM   #515
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
No IC sprayer hooked up yet, I have a NX spray kit that I could throw on... but the nozzle will end up in the TB knowing me
Originally Posted by g00fy View Post
What BOV is that?
Tial with P&L adapter kit
Old 04-20-2012, 10:34 PM   #516
manitou
Member#: 193757
2006 XTI Limited
Dude, you've got to over-lay your last VF power curve on that bad boy and extend it out to the right another 1500 rpm's. That is one sic power band. It's a solid 4K of let's get after it, short shift, run it out, whatever.....let's go!! Nice and rounded full of torque! I want my power band something like that except I don't need that much HP for a DD road car. I just want it early, good and steady and fully long legged like yours! E85 WTF
Old 04-20-2012, 11:13 PM   #517
juanmedina
Member#: 133146
The new version of Virtual dyno reads high because they changed the logarithm but they forgot to adjust the CF. Also you need to run more smoothing around 8-10 will give more accurate numbers. I noticed that you are using your AP for logging; when I use my AP vs RomRaider with fast spooling I get higher numbers, I imagine is because of the number of data points. So I think its reading a little high, I doubt the car is making about 655whp dynojet (580whp mustang) at 20psi with 93oct.
What you think Junior a 125-127mph car at the current level?
Old 04-20-2012, 11:56 PM   #518
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Juan,
I think it reads high. I am expecting a legit [email protected] on a dynojet. Honestly the curve shape is all I am after. Also switching it to 10 only makes like a 8whp diffrence but makes the graph look like it will pull to 12,000rpm... lol..
It feels like a solid 127-128mph car, or a high 10s car right now. I really want to get it to the track!!!!
Old 04-21-2012, 12:22 AM   #519
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Still stock motor?
C J is offline   Reply With Quote
Old 04-21-2012, 12:48 AM   #520
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Originally Posted by C J View Post
Still stock motor?
Nope, I swapped it out last season. I wanted to turn it up A LOT at the shootout, but ended up popping the clutch clip on the first pass.
Old 04-21-2012, 10:00 AM   #521
juanmedina
Member#: 133146
Juan,
Sweet! here is mine:
It will probably go down to 505-510 when they release the new version of VD. Although I am on E85 and with way more boost my car weights almost 1000lbs less . I turned down low for the sake of my 09 Sti rods.
Old 04-21-2012, 12:38 PM   #522
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Very nice, that setup in a sub 3k will probably trap 140mph! I am supposed to go setup and tune FastEddie's 2 cars in Georgia ( Buckhead Atlanta ) soon. You should let me or Eddie drive it for you and see if it will dip into the 9s on a stock location setup.
As for the TQ/Rods, I did the same thing on my stock block when I was making over 600whp. It gets to a point were you cant really fight it anymore though and the TQ just goes to were it wants too. Be careful with under timing the motor too, "conservative" timing can also cause det and super high EGTs.
If you want to mail me your Rom I would be more then happy to help you out with what I learned on my stock block big boost setup.
[email protected]
Old 04-21-2012, 01:16 PM   #523
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Damn. I wanted to see where it could go on the stock motor. I am going to try and push mine into the 10s this season on stock engine with a 3582.
Old 04-21-2012, 01:17 PM   #524
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
[email protected]
Jr, On E85 you tune timing with the knock sensor?
spoolinsti05 is offline   Reply With Quote
Old 04-21-2012, 01:21 PM   #525
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
I have pushed the stock motor into the 10s many times. My best ET/Mph on the stocker was [email protected] or so.. It has been a few years since we did any stock motor fun with the exception of mine. Judging by the 1/8th though, it was an easy 10sec 3500 ride.
Jr, On E85 you tune with the knock sensor or off the dyno's tq curve? And what catch can is that? thought you rocked the crawford still.
I am switching my car back to the Crawford can. Do I think I need it? Nope, but I dont know how well this can will manage when I have the boost at 36-38psi
As for your question, text me
Import Face-Off : Woodburn, Oregon : 05/29/11 jdmwarrior North West Impreza Club Forum -- NWIC 0 04-08-2011 03:56 PM
Another FAST pump + meth 35r car [email protected], 128.7 best mph Junior2JZ Proven Power Bragging 23 04-30-2009 05:16 PM
Anything going on this Sunday? 11/6/05 Crashsector Mid Atlantic Impreza Club -- MAIC 11 11-05-2005 11:12 PM
13.2 @ 101.83 mph hilife Proven Power Bragging 26 01-11-2004 06:12 PM
has anyone seen turboxs 11.9 sec 115 mph odin1 Proven Power Bragging 11 11-13-2002 12:04 PM
