Old 04-17-2012, 08:33 PM   #51
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Subscribed
BlackFighter is offline   Reply With Quote
Old 04-19-2012, 10:57 PM   #52
Bikelok
Member#: 254851
2002 WRX wagon 5mt
14 bucks well spent.
Bikelok is offline   Reply With Quote
Old 04-20-2012, 02:14 AM   #53
bonesetter
Member#: 285417
1997 Type R
Sonic blue
What effect does locking have 'down the line'? In particular, I understand trailing arm bushings have a harder time of things...
bonesetter is offline   Reply With Quote
Old 05-04-2012, 07:31 PM   #54
bsdoig
Member#: 199980
2005 VF39'ed WRX
Anyone have issues with the lockdown bolts not torquing up? I tried to torque to like 30ft-lbs and the just keep going in and won't tighten?
bsdoig is offline   Reply With Quote
Old 05-04-2012, 07:52 PM   #55
Bikelok
Member#: 254851
2002 WRX wagon 5mt
you dont quite understand the issue, here
lotsa d0000ds gonna snap off the captured nuts in the subframe tryin this.....lots and lots
and this is one of those things that is NOT easy to fix....but REAL-REAL easy to **** up because of rust in the threads of the captured nut....and once the captured nut snaps off...ya cant get the bolt out without dropping the subframe...even if ya cut the bolt head off....and then it will rattle
have fun
^^^bsdoig, this is what probably happened to you. You have to be VERY VERY careful that the threads are clean and you can thread it in with your hand all the way before using a wrench.
Good luck.
Old 05-04-2012, 07:55 PM   #56
Bikelok
Member#: 254851
2002 WRX wagon 5mt
From what I understand many many people have run them for tens of thousands of miles with no issues.
Old 05-04-2012, 08:55 PM   #57
bsdoig
Member#: 199980
2005 VF39'ed WRX
Good luck.
No I don't think so…….I was able to pull he bolts right back out without any issues. Threads were tapped and clean. I could run the bolt by itself all the way through without any issues. It was like where the brass meets the subframe it was just collapsing and wouldn't get tight. I'm gonna leave them off for now since I didn't like the way they felt when tightening.
What are they suppose to be tightened to?
Old 05-04-2012, 10:40 PM   #58
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
As Uncle Scotty said, you got to be really careful when installing these bolts... perhaps I used too much force when installing the bolt, which resulted in bolt freely spinning (bracket weld snapped).
Luckily it's not vibrating or anything.
Great write up.
Old 05-05-2012, 01:25 AM   #59
bonesetter
Member#: 285417
1997 Type R
Sonic blue
I think it's important to chase out these threads before install to avoid this issue
Old 11-12-2012, 10:06 AM   #60
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
So important to chase them out.
Old 11-12-2012, 12:04 PM   #61
bako
Member#: 226211
2002 impreza WRX JDM
blue
I made the same diy mod.
bought 2 bolts for 2$, then bought brass material for 10$ and then machining for 5$.
it made big difference! when my 02wrx rear was sliding away on tail braking in some specific conrners, in the same corners after lockdown bolts + front anti lift kit I had almost no rear slide, very controllable corner entry oversteer/understeer. I feel I'm not loosing rear camber when high side loads...
bako is offline   Reply With Quote
Old 11-12-2012, 09:15 PM   #62
choiboi
Member#: 126614
2006 WRB WRX TR
OS Stage 2
What torque specs should we torque the bolts to once they are in? Kartboy's seem to be at 60lbft. Would it be the same? Great DIY thanx
choiboi is offline   Reply With Quote
Old 11-12-2012, 09:16 PM   #63
sackytar
Member#: 149262
PrimerGrey
You do not want to over tourque these btw.
Old 12-05-2012, 10:06 PM   #64
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Where did you purchase the bolt smd flange from???
peanutswagon is offline   Reply With Quote
Old 12-05-2012, 10:07 PM   #65
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Im a machinist... if i have to I can machine the flanges out of any material... brass specific?
Old 12-05-2012, 10:09 PM   #66
Soul Shinobi
Member#: 130759
2002 Forester S
I got some from McMaster Carr, brass is easy to find the right size in but stainless steel would probably be ideal.
Soul Shinobi is offline   Reply With Quote
Old 12-05-2012, 10:20 PM   #67
sackytar
Member#: 149262
PrimerGrey
Fastenal has em.
Old 12-05-2012, 10:21 PM   #68
sackytar
Member#: 149262
PrimerGrey
You can make em out of whatever you want.
Old 12-06-2012, 01:15 AM   #69
i would try brass first as it is self lubricating which may reduce future issues
my whiteline bolts have been in my 06 wrx for almost 100k miles and Im not aware of any issues and my alignments dont 'wander'......which leads me to think all is well
Old 12-06-2012, 01:47 AM   #70
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Built Motor and all. WRB
I would say Delrin would be the ideal material. I have since made some for mine out of Delrin just to cut back on some of the rear diff whine I hear from the solid bushings back there. Brass would be my second choice.
chet.wrb is offline   Reply With Quote
Old 12-07-2012, 03:29 AM   #71
d00000d...the whiteline bolts are straight steel and they dont make any noise or have anything to do with rear diff whine
THAT is something else....
i think people have a misconception of what is really being done here
Old 12-07-2012, 09:50 AM   #72
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
The rear diff is mounted in the rear sub frame with rubber bushings, so you never hear the whine. With my car, I made solid bushings to make it have no more play in it. The combination of the rear diff being mounted solid to the subframe, and the subframe being solid to the rest of the car using these lockdown bolts, made it so I could hear the rear diff loud and clear at cruising speed on the highway. Once I made the subframe lockdown bushings out of Delrin, now I can barely hear the rear diff at all.
The difference is that I don't think anyone has mounted the rear diff solid to the rear subframe like I have. Yea, the polyurethane bushings for the rear diff would probably work better, but I already did mine solid, and I love the response of the rear end now.
Old 12-07-2012, 01:47 PM   #73
which is why....oh forget it
Old 12-07-2012, 02:04 PM   #74
chet.wrb
Member#: 255375
2003 Wagon w/cxr550
Sorry Scotty, I'm not trying to argue with you. I just prefer the Delrin. All steel works also.
Leave in Rear Subframe Lockdown Bolts forever? paulpat Brakes, Steering & Suspension 11 01-03-2011 10:42 AM
FS : Whiteline Subframe Lockdown Bolts SOLD! andrewp724 Suspension/Brakes/Handling 8 10-04-2010 09:29 PM
Help with subframe lockdown bolt install kmook Brakes, Steering & Suspension 11 10-19-2009 12:03 AM
Brand New Perrin Rear Subframe Lockdown Kit whitneyas Suspension/Brakes/Handling 2 07-28-2008 01:29 PM
