#501 | |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned |
That curve looks pretty linear and pretty darn early as well, no lag at all, making 300 WTQ at 3700-3800, I'm sure you could fit a stock VF curve inside of it. Very NICE!!
#502 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
He needs a 6466, it seems that the 6466 is a beast
#503 | |||||
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
![]() Quote:
Im figuring if my 3500lb XT went 11.7@116-117mph, a 2800-3000lb STI will go a little faster ![]() Quote:
I don't even argue, I just let the cars do the talking ![]() Im taking it slow with the GTR stuff... Not very many made and def a lot of people tuning them, plus I have JohnV ![]() Oring, I had the old style NPT ones. Quote:
62 will be going on in a few weeks, compression I will do shortly. I am not sure were it ended up. Spearco still kicking ass ![]() My ultimate goal is 600tq/700whp on e85, I made 800whp with a 6266 so I think I will get were I want with the 62 and still have my TQ |
#504 | |
Member#: 193757
#505 | |
Member#: 64908
I will post pics tomorrow with the HTA82 tomorrow. I am running a custom can with -8an lines right now, but I did pick up a crawford AOS to install when I swap the turbo. Im getting antsy.. I might take her to the track tomorrow on pumpgas and see how close to the 10s I can get. Jr |
#506 |
Member#: 159243
Vehicle:sg3 Turbo Tek Tuned Hakt Ecu e85 30r 6spd |
i'd ask what track but i'll be at bassnectar tonight...
#507 |
Member#: 141754
Vehicle:04 stock wrx ;) z31 project, passat dd |
Wait till I get out of class first dobt want to miss it
#508 |
Member#: 179846
Vehicle:07 STi MPS Build EFR 7670 TS |
#509 |
Member#: 64908
#510 |
Member#: 232458
SWIC
Vehicle:2008 STi (OBP) CAMTuned |
Clean man.
#511 | |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
#512 |
Member#: 193757
Yes, nice and very clean EC!! I like where you mounted the catch can, it keeps it up higher so that should help with the drainage on the Crawford when you install that. I just bought a Crawford as well I'm gonna swap it in for the 2 stage/ Grimm AOS & Greddy can I have installed now. I like the closed loop and heated aspects of the Crawford AOS, it should work much better. I also really want to stay with a TMIC to keep the charge path short.
Are you using the rear reservoir for IC spray? |
#513 |
Member#: 82524
Vehicle:2005 35R'd 4eat Flying Rhombus |
What BOV is that?
#514 |
Member#: 64908
4th gear, 20psi still on 93 only reved to 6k due to traffic.. Something isn't right about the displayed power though. It doesn't feel like a 560whp car, but then again I'm used to a high 600s and 700+tq in my daily driver. So maybe it is making some good power, it def spools good!
#515 | |
Member#: 64908
No IC sprayer hooked up yet, I have a NX spray kit that I could throw on... but the nozzle will end up in the TB knowing me ![]() Tial with P&L adapter kit |
#516 | |
Member#: 193757
#517 | |
Member#: 133146
What you think Junior a 125-127mph car at the current level? ![]() |
#518 |
Member#: 64908
Juan,
I think it reads high. I am expecting a legit 480-520whp@20psi on a dynojet. Honestly the curve shape is all I am after. Also switching it to 10 only makes like a 8whp diffrence but makes the graph look like it will pull to 12,000rpm... lol.. It feels like a solid 127-128mph car, or a high 10s car right now. I really want to get it to the track!!!! |
#519 |
Member#: 132587
Vehicle:2006 JrTuned STi E85 GT3582r/10.83@126mph |
Still stock motor?
#520 |
Member#: 64908
#521 | |
Member#: 133146
![]() It will probably go down to 505-510 when they release the new version of VD. Although I am on E85 and with way more boost my car weights almost 1000lbs less . I turned down low for the sake of my 09 Sti rods. |
#522 |
Member#: 64908
Very nice, that setup in a sub 3k will probably trap 140mph! I am supposed to go setup and tune FastEddie's 2 cars in Georgia ( Buckhead Atlanta ) soon. You should let me or Eddie drive it for you and see if it will dip into the 9s on a stock location setup.
As for the TQ/Rods, I did the same thing on my stock block when I was making over 600whp. It gets to a point were you cant really fight it anymore though and the TQ just goes to were it wants too. Be careful with under timing the motor too, "conservative" timing can also cause det and super high EGTs. If you want to mail me your Rom I would be more then happy to help you out with what I learned on my stock block big boost setup. Jrtuned@gmail.com |
#523 |
Member#: 132587
Damn. I wanted to see where it could go on the stock motor. I am going to try and push mine into the 10s this season on stock engine with a 3582.
#524 | |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
Jr, On E85 you tune timing with the knock sensor? Last edited by spoolinsti05; 04-21-2012 at 01:27 PM. |
#525 | ||
Member#: 64908
![]() As for your question, text me ![]() |
| Thread Tools | |
| Display Modes | |
| Import Face-Off : Woodburn, Oregon : 05/29/11 | jdmwarrior | North West Impreza Club Forum -- NWIC | 0 | 04-08-2011 03:56 PM |
| Another FAST pump + meth 35r car 11.3@126, 128.7 best mph | Junior2JZ | Proven Power Bragging | 23 | 04-30-2009 05:16 PM |
| Anything going on this Sunday? 11/6/05 | Crashsector | Mid Atlantic Impreza Club -- MAIC | 11 | 11-05-2005 11:12 PM |
| 13.2 @ 101.83 mph | hilife | Proven Power Bragging | 26 | 01-11-2004 06:12 PM |
| has anyone seen turboxs 11.9 sec 115 mph | odin1 | Proven Power Bragging | 11 | 11-13-2002 12:04 PM |
