Old 04-06-2012, 09:13 AM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default Retrofit rear camera into 2012 Impreza?
Is it possible (practical) to add a rear camera to the '12 Impreza Sport Limited? I have the Limited stereo (non Nav), could it be integrated into the stereo?
The notch cut out in the rear door for a camera is there, but it wasn't even an option surprisingly?
Thoughts?
BrysImpreza is online now   Reply With Quote
Old 04-06-2012, 10:01 AM   #2
BryanP5555
Member#: 314731
2014 WRX
i am not sure the option even exists for the stock NAV. Ask your dealer maybe the same HU is in a different model that does have the option.
BryanP5555 is offline   Reply With Quote
Old 04-07-2012, 07:45 PM   #3
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
The JDM accessories PDF does show a rear/backup camera. That's what the cut out is for. Not sure if the wiring is there, I wouldn't hold my breath (but yes, when I get around to replace the base factory HU, I'll look into it.)
dorkbert is offline   Reply With Quote
Old 04-12-2012, 04:51 PM   #4
bobdole888
Member#: 316658
2012 Impreza limited
5dr silver
If you have the limited non-nav stereo, it seems that there are hooks for a backup camera built-in on the stereo.
Check this out.
Put the key in acc position.
Turn off the stereo.
The holding down '6' and turning tune dial until a firmware version info screen comes up(it takes ~5 full turns).
Press the tune dial in once and you get the 'firmware update' screen.
So there is potential to update firmware for things like bluetooth, ipod interface, etc
If you press the tune dial one more time, it actually brings up the CAMERA!!!
Well, there is no camera attached, but if you connect it, presumably, it will show the rear view camera on the stereo screen. Currently when I get to that screen, it shows a blank screen, with backup markers. If I press some other number, it turn on/off the back up marker, or brings up different size markers.
I would assume that there is a video input jack in the back of the HU.
In the regular screen setup menu, there is even a setting for choosing NTSC or PAL video format.
I hope someone would try and hook up a camera to the stereo to see this really works.
Maybe there's even a way to have it automatically switch the display to the camera when you are in reverse.
Myabe down load the firmware from a forester or outback?
Old 04-12-2012, 05:02 PM   #5
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Check this out.
I'll be trying it soon, the Camera is about $169 from Subaru, but i have seen success with some Ebay aftermarket units and a custom harness from member SVXdc.
I'm going to try a combination of the two, $30 camera, run wiring myself, spliced to a factory harness
Thank you for instructions on how to access a firmware set up!
Old 04-12-2012, 05:18 PM   #6
dorkbert
Member#: 309901
... Camera for what vehicle? I thought that option is only available for JDM (CMOS or CCD) on the '12 Impreza (G4/Sport) and they cost MUCH MUCH MORE than a "meager" $169.
Old 04-12-2012, 06:24 PM   #7
bobdole888
Member#: 316658
5dr silver
I've seen after market cameras for cheap on ebay.
search for 'impreza camera' and you'll find some for $18.
Personally I would look for something built better for quality, but there are cheap cameras out there.
Brys, please let us know how it goes. I'm very much interested in this also.
Old 04-12-2012, 06:54 PM   #8
dorkbert
Member#: 309901
sorry, I was under the impression the quoted $169 was for an '12 Impreza specific OEM camera, not the "fleaBay stuff." I be interested in finding out if there are any camera(s) that would be a perfect fit to the factory "cut out" on the '12 Impreza as well.
Old 04-12-2012, 08:06 PM   #9
bobdole888
Member#: 316658
5dr silver
Genuine camera from Subaru is $169.
http://parts.subaru.com/subaruparts/...cat5=0&retval=
This is camera only. No display. You use the stereo's display.
Old 04-12-2012, 10:48 PM   #10
Rymar
Member#: 310672
2012 Impreza Ltd 5Dr
Dark Gray Metallic
Just to verify: this info is for the 4.3" non-nav HU (CM631UD or PF-3391A-A).
There are two unused connectors on the back of the unit, next to each other. The schematic shows:
8 pin connector (J901)
pin 1: CV(+)
pin 2: N.C.
pin 3: CAM +5V
pin 4: N.C.
pin 5: CV(-)
pin 6: CAM DET
pin 7: GND
pin 8: N.C.
This connector appears to be for the backup camera. A reverse signal is also present on the main connector, so I'm assuming this selects the backup camera video if CAM DET is grounded.
The camera composite video should be connected to CV(+) (signal) and CV(-) (ground).
Although the schematic shows pin 3 as +5V, it's really +6V.
12 pin connector (P903)
(I'm going by what's shown on the schematic signals, not the text description next to it, which doesn't match)
pin 1: SCAM_COMP
pin 2: N.C.
pin 3: N.C.
pin 4: N.C.
pin 5: VTR_AUDIO_L+
pin 6: VTR_AUDIO_R+
pin 7: VTR_AUDIO_R-
pin 8: VTR_AUDIO_L-
pin 9: N.C.
pin 10: VIDEO DET
pin 11: VIDEO_GND
pin 12: N.C.
This connector appears to be for another video input. It also looks like grounding the VIDEO DET pin will enable this video. I think this is what the PAL/NTSC select in the hidden menu is for. The video should be connected to the SCAM_COMP input.
No guarantees on any of this! I'm just reporting what the schematic shows; I haven't connected video to any of this pins.
Maybe SVXdc has found a source for the backup camera connector by now?
Rymar is offline   Reply With Quote
Old 04-12-2012, 11:05 PM   #11
ISportLTD
Member#: 316677
Can you hook up a camera to the OEM Nav Head Unit.
ISportLTD is offline   Reply With Quote
Old 04-12-2012, 11:52 PM   #12
bobdole888
Member#: 316658
5dr silver
It looks like someone might have gotten this to work with a similar HU from forester.
http://forums.nasioc.com/forums/show....php?t=2323331
The person bought a harness from svxdc to hook up a cheap ebay camera to the HU.
My biggest concern would be that the Forester does have the camera option, so the HU might have different firmware that enables the camera.
The if the impreza has a different firmware than the forester, then it might not automatically display camera on reverse.
Old 04-13-2012, 04:21 AM   #13
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The rear camera input on the Impreza model CM631UD HU is functional. It uses the same 8-pin socket (and same pin-out) as that 2011-2012 Forester HU, as well as the 2008-2011 OEM Kenwood Navi HUs.
The Impreza HU is already wired to the reverse gear signal. It just needs to see that a camera is present for the feature to start working.
I make an adapter harness with an RCA jack for an aftermarket camera. (and yes, I did finally obtain a large quantity of the 8-pin plugs for that)
I can also make an adapter with plain wires for anyone who wants to connect an OEM camera. The factory wiring is not present in North American Imprezas (and apparently not all Foresters, either). So you'll need to add a long segment from the HU to the camera.
I'd love to make a harness for the "VTR" A/V input, but haven't identified that 12-pin socket yet.
The 2012 Impreza/Forester Fujitsu Ten nav HU also has a rear camera input, on its 16-pin socket. See this post. Since the cars already have a factory harness there (Imprezas without the camera wires), the easiest way to connect a camera is to add a new female RCA jack whose wires have the appropriate pins to snap into the factory plug (which I can also provide). Just recently, an installer used my cable and confirmed that this camera input works.
Anyone who wants to contact me, see my profile (click on my username) and read the visitor message.
Old 04-16-2012, 09:45 AM   #14
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Harness and camera ordered, now i wait. I'll do a how to write up once it all arrives.
Old 04-16-2012, 01:01 PM   #15
dorkbert
Member#: 309901
I am partial to the "factory look" and fitting that particular camera on a hatch seem... out of place (to me.) But I have heard that it fits well on a sedan.
Old 04-16-2012, 11:44 PM   #16
Waterlogged
Member#: 294791
2012 Impreza Sport
I opened up the hatch and the wires are not there, nor is the mounting bracket for the factory camera. One could probably be fabricated or purchased from a Forester. I switched to a Pioneer so I now have a spare camera if anybody is interested.
Waterlogged is offline   Reply With Quote
Old 04-21-2012, 08:10 PM   #17
bobdole888
Member#: 316658
5dr silver
Any idea when these parts would arrive? Did you go with the $18 ebay camera?
I'm worried about routing the video signal to the HU being messy work.
I see some wireless option on ebay for ~$30. That might make the install a little less overwhelming. Although, I'm not sure how well it would work with the HU. Especially I would want to have it turn on automatically on reverse.
Old 04-21-2012, 08:16 PM   #18
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I finished about an hour ago, having installed a billion subwoofers, amps and various other components over the years, it was a breeze!
It was only 1 AV cable that ran to the radio, everything else (2 cables) ran to the reverse light, i snaked it all through the factory rubber passages.
It's certainly not OE, but it cost under $60 complete.
I used a $35 camera from a US Ebay seller.
The worst part was dremeling a hole in my brand new car!
Thank you SXVdc for the help and the harness!
Old 04-21-2012, 08:29 PM   #19
FourOhFour
Member#: 309509
2012 Impreza
Honestly? It won't. The wireless would let you skip running the video line from the rear to the front of the car, that's it. Since the camera needs power, you still need to get a wire from the camera through the tailgate to a source of power (probably the reverse light circuit unless you want to hunt down a constant +12 back there). And that is (in my opinion, anyway) the hard part. Getting from the back to the front is easy, it's snaking wires through that damn boot to the hatch that's annoying.
FourOhFour is offline   Reply With Quote
Old 04-21-2012, 08:43 PM   #20
bobdole888
Member#: 316658
5dr silver
I would have hooked up the wireless cam to the back up light, so I thought that would be fairly easy since all the wiring would stay in the hatch.
I don't know how hard it is to route a wire from the hatch to the HU.
It seems that Brys found some passage to route the AV wire. Does this need some special tool to pull a wire through?
Old 04-21-2012, 08:50 PM   #21
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Route the 1 wire under the trim on the drivers side, follow the wire loom or washer fluid line (5 door).
Buy SVXdc's 8 pin harness, connect the spade connector to one of the screws on the body of the radio, then plug in the AV cable.
The "special tool" i use is a bent out hanger or a long wooden dowel with the wire taped to it to pull the wires through the rubber boots and to route the cable from the reverse lights to the hatch door.
Old 04-21-2012, 08:50 PM   #22
bobdole888
Member#: 316658
5dr silver
It looks awesome!
Does it really automatically turn on when reversing?
Did you have to do anything other than using SXVdc's harness to enable the camera?
Could you share with us which camera you got from ebay? How is the video quality?
Did you need any special tool to run the AV wire from the hatch to the HU?
Old 04-21-2012, 08:54 PM   #23
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Yup, the radio is pre wired to sense reverse, the spade connector you put in completes the circuit to put the radio into camera mode when you put the car in reverse.
I used this one for $35, the video quality is excellent and the LEDS, bright.
http://item.mobileweb.ebay.com/viewi...d=280783021008
Old 04-21-2012, 10:14 PM   #24
FourOhFour
Member#: 309509
2012 Impreza
The reverse light isn't in the hatch. At least, it isn't on mine.
Old 04-22-2012, 07:52 AM   #25
bobdole888
Member#: 316658
5dr silver
Sounds like the LED light is visable? I was hoping that it would be the IR type light that is not visable to human eyes but provides illumination for the camera.
Finally got the chance to retrofit my 2012 Impreza Sports Premium JDMSTA Electrical & Lighting 287 08-05-2014 05:03 PM
95 legacy rear crossmember into 95 impreza? greg donovan Subaru Conversions 1 10-02-2010 01:07 AM
2000 2.5 rs rear lsd into 97 impreza abs?s oooo Transmission (AT/MT) & Driveline 7 07-01-2009 10:15 PM
anyone retrofit hid's into their impreza? scooter4483 Mid West Subaru Owners Club Forum -- MWSOC 15 09-29-2008 04:35 PM
