Old 04-12-2003, 03:12 AM   #1
jhong567
Member#: 29500
2003 WRX Sedan
Midnight Black Pearl
Default How do you use the camber bolts?
Hey I installed lower Eibach and people suggest to buy and install camberbolts. Well I bought them but i dont knwo how to use them or where to install them. I think they go at teh bottom of the shock. Now there are two bolts there. Does teh camber bolt go at teh top or the bottom. I tried at teh bottom but the bolt is so long it is only about a 1/4 inch from the CV boot of the rear axle. also my bolts came with this washer that has a bent tab at the edge and another bent tab on the inner edge and it has small teeth that dot the outer edge. I dont know what this is for.
jhong567 is offline   Reply With Quote
how do you make the strut's shaft not turning when tightening down the strut bolt? qualityracer Brakes, Steering & Suspension 14 06-08-2009 02:53 PM
How do you remove aftermarket camber (eccentric) bolts? SSLegacyGT Brakes, Steering & Suspension 3 03-29-2008 04:58 PM
How do you use the 0-60 feature on new accessport? Humboldt wagon AccessPort 3 03-03-2007 03:13 AM
How the hell do you get the header bolts off linux>windows Normally Aspirated Powertrain 17 09-22-2004 11:37 AM
How do you use the IMG button? mainj_sm Newbies & FAQs 5 01-23-2004 10:10 PM
