Old 04-14-2012, 06:16 PM   #1
RoOoLeR
Member#: 204183
2005 STI
Default Tinywrex NLTS Problems
Hey everyone looking for some help here.
I own a 2005 STi and had my tuner flash TINYwrex's LC/NLTS patch into my rom. The LC works perfectly however the NLTS is another story.. (I do 100% understand how it works as does my tuner. We successfully had it working however after updating my tune it is now butchered
Mods:
APS FMIC
APS CAI
stock VF39
TIAL 38mm EWG
TBE
TubroXS MBC (18PSi)
For example.
When doing a 2-3rd NLTS pull.. I get right to 6800-7k RPM then right when i shift and let the clutch out its almost as if i lose everything.. the gas pedal is still floored but it stutters then picks back up.. Anyone have ANY idea what this is?
The LC works perfectly and so did the NLTS.. However it just stopped working
I dont have any logs to post.. I will try to contact my tuner and ask.
Thanks everyone.
RoOoLeR is offline   Reply With Quote
Old 04-22-2012, 04:47 PM   #2
izergfx
Member#: 308012
C# & Java Devs***
PM me***
Are you riding the clutch at all?
Subaru's clutch switch is very high in the pedal, so unless you physically take your foot off of the pedal or move the switch, you could be stuck on the FFS limit.
Another possibility is FBKC/FLKC, sometimes LC/FFS causes false knock. If your tuner has messed with the knock control settings it could be pulling a ton of timing, etc.
Also check your redline fuel resume (boost) setting.
izergfx is offline   Reply With Quote
Old 04-22-2012, 05:25 PM   #3
RoOoLeR
Member#: 204183
2005 STI
I have a six puck clutch so there is zero error in that department. I'm very familiar with how to launch my car. (Not being rude)
I'll talk with my tuner and try to get this figured out! Thanks man.
Old 04-22-2012, 05:36 PM   #4
izergfx
Member#: 308012
C# & Java Devs***
PM me***
To clarify, I'm talking about the clutch pedal and the electronic switch, not the clutch itself.
By holding your foot on the clutch pedal after shifting, even very slightly, you can trigger the switch which triggers the lower FFS rev limit.
Old 04-23-2012, 12:08 AM   #5
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Try logging your run, including the parameters for FLKC, FBKC, RPM, and clutch switch. Leave out some boost - related parameters while you do these logs, but keep the usual stuff (RPM, load, throttle position, etc).
tinywrex lc patch jrrevo1 Open Source Reflashes 9 03-21-2013 12:36 PM
Problems after Turboxs down pipe numbnuts670 AccessPort 9 04-16-2012 09:22 PM
tinywrex site? sti4rs Open Source Reflashes 16 07-13-2010 06:36 PM
Tinywrex ecu Launch and FFS control subiesoho Transmission (AT/MT) & Driveline 0 02-01-2009 02:07 AM
Patched my map with tinywrex Launch Control. 4 extra options?? RSXiMUS Open Source Reflashes 10 12-12-2008 04:23 PM
