Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 04-23-2012, 11:45 PM   #1
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
Default Ahhh the things I do for my Subaru!
So I've been battling water spots for years now. My wife does her best to dry the car, but well.....yeah. It's a dark car so every little drop leaves a spot that is very noticable to me. I've got well water here, it is great for drinking but hard as hell, which means it leaves terrible water spots. I measured my hardness based on the ppm scale (parts per million) using a TDS meter. The standard is 0-60ppm soft, 61-120ppm moderately hard, 121-180ppm hard, 181+ppm very hard. My water is 216ppm! Initially I considered a typical home water softening unit. However, these use salt which simply can't be good for the paint. Salt does tend to be corrosive lol.
Below is my fix. My Subaru is now ONLY washed with 0ppm water. Doesn't get any better than that.
Explanation: Reverse Osmosis 4 stage water filtration system with a 20gal resivor tank featuring a 1600gph pump.
Take that water spots! (extra bonus: wife quit whining about having to dry the car)
TheTallOne is offline   Reply With Quote
Old 04-24-2012, 02:15 AM   #2
shawns_sick_STi
Member#: 126107
2004 STi
I have one of those water softener systems and the salt is only used to clean out the carbon filter, not soften the water. I use the house water to was the cars and it leaves a spot free car without drying. But cool set up you got there!
shawns_sick_STi is offline   Reply With Quote
Old 04-24-2012, 03:32 AM   #3
overdrivex
Member#: 220581
2010 Impreza
camilia red
yup my families coffee shop had a water softening system in it and the rock salt is only used to flush out the system
overdrivex is offline   Reply With Quote
Old 04-24-2012, 05:56 AM   #4
prototypeWRX
Member#: 78739
2015 WRX
Yeah the only time you might notice just a small (very minor, and for very little time) amount of salt is the first time you use your water after the softener does it's filter clean/flush cycle. Which I think is why some people choose to use potassium instead of salt, among other reasons. Most modern softeners support the use of either.
prototypeWRX is offline   Reply With Quote
Old 04-24-2012, 07:02 AM   #5
oceanwater48
Member#: 315882
V8 U make
Baby Poop
thefilterguys.com or .org, i forgot.
oceanwater48 is offline   Reply With Quote
Old 04-24-2012, 09:43 AM   #6
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
Guess I should have looked into the softeners more, oh well. I don't plan on living in my current house much longer anyway, the ro unit is cheaper and easier to move I'm sure.
Old 04-24-2012, 10:08 AM   #7
WRXwife
Member#: 240179
2008 WRX
I think it really comes down to: it amused him to build this. He can never go the simple and effective route. Ever. LOL.
But what's really really important is, I don't have to dry the car......as much. He still insists on moderate, but not psycho meticulous, drying.
WRXwife is offline   Reply With Quote
Old 04-24-2012, 01:39 PM   #8
wrx_02
Member#: 188471
This is great^^^^
wrx_02 is offline   Reply With Quote
Old 04-24-2012, 01:44 PM   #9
scubie33
Member#: 213687
08 STi
Aspen white
.biz
scubie33 is offline   Reply With Quote
Old 04-24-2012, 02:20 PM   #10
ExchangeGuy
Member#: 4383
2012 Camaro RS
Blsck/gray
A family that washes together, dries together....
ExchangeGuy is offline   Reply With Quote
Old 04-24-2012, 02:40 PM   #11
JbibWrx
Member#: 203162
2005 Wrx
How much for ro kit shipped to north Dallas when you move?
JbibWrx is offline   Reply With Quote
Old 04-24-2012, 02:44 PM   #12
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
You can actually put one together from Home Depot for pretty cheap. I had a bunch of customers use the under the sink reverse osmosis kits for the same purpose, and those aren't pricey at all.
I think they run from $250-$300.
Spider Pig is offline   Reply With Quote
Old 04-24-2012, 03:02 PM   #13
wrx_02
Member#: 188471
You work at HD? If so I am sorry, I use to work in the orange box.
Old 04-24-2012, 03:20 PM   #14
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
I'll be taking the Reverse Osmosis filter with me when I move. The 5 stage 75 gpd(gallons per day) RO filter was $130, booster pump $75, water pump 1600 gph(gallons per hour) $65, 20 gallon water tank $15, float valve $8, 60 feet of tubing $20, 50 foot water hose and nozzle $40.
Total $353
The booster pump isn't needed with most city water cases. I needed it due to low well water pressure, 35-40 psi. City water pressure is typically 60 psi which is ideal for ro filters.
Home Depot ro units work but are smaller, 40 gpd, 2-3 stages etc. They are made to supply a 1 gallon water tank for drinking, not the best for what I am doing. Plus they are more expensive there than online.
Looked into the softeners a little, appears average ppm(parts per million) of processed water with these systems is 100 ppm. I like my 0 ppm better. And for $50 a year, can't beat it.
Air dry a dark grey metallic car? Hell yea!
Old 04-24-2012, 03:32 PM   #15
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
No, I used to a few years back. It was great for a year. And then ****ty for the two that followed when I made assistant manager.
Old 04-24-2012, 04:03 PM   #16
wrx_02
Member#: 188471
Yeah me to. Good thing I use to work there so I know where everything is now cause good luck getting help now.
On a side note couldn't one just get a Brita filter? It would take a long time but.........
Old 04-24-2012, 04:45 PM   #17
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
Brita filters are mainly carbon based, meaning they primarily remove pharmaceuticals that cause odor and taste. The under sink brita filter in my kitchen reduced the ppm from 216 to 201, not much.
"In a Brita® Faucet filter, there is a two-step process. When you turn on your tap, water first passes through a non-woven screen around the filter to trap sediment. Then, the water then flows through a compressed block of carbon and zeolite, reducing chlorine (for taste and odor) and lead." Brita.com
"Because of its lower mineral content, reverse osmosis water is often used in car washes during the final vehicle rinse to prevent water spotting on the vehicle. Reverse osmosis water also enables the car wash operator to reduce the demands on the vehicle drying equipment, such as air blowers." Wikipedia
Old 04-26-2012, 12:15 AM   #18
Black07Sleeper
Member#: 207624
2015 STi
Ahhh..... love..... you guys are awesome
Black07Sleeper is offline   Reply With Quote
Old 04-26-2012, 01:11 PM   #19
Koiracer
Member#: 190132
2011 Impreza WRX
Have you tried the window trick?
Koiracer is offline   Reply With Quote
Old 04-26-2012, 09:12 PM   #20
WRXwife
Member#: 240179
2008 WRX
Not yet, got busy with school & job stuff. I plan on doing it tomorrow night.
Old 04-26-2012, 09:27 PM   #21
speakerpimp
Member#: 241673
Spark Silver
Now that's love!!!!!!!!!
speakerpimp is offline   Reply With Quote
Old 04-27-2012, 02:18 AM   #22
ajg10730
Member#: 219334
I use to work there also. I hate it with passion!!!!!!!
ajg10730 is offline   Reply With Quote
Old 04-28-2012, 02:20 AM   #23
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
this is sick. can i haz?
blakkboxer is offline   Reply With Quote
Old 04-28-2012, 12:08 PM   #24
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
Most city water providers will have their water quality posted on their websites. They also email customers the water survey every 5 years I believe. TCEQ, and AWA, will also have what's supposed to be in your water and what's not. As well as standards for each level.
That way you can determine if that process is right choice for you.
Most can agree though that the water from an RO element is better overall for consumption. Most bottling companies and water mill locations use a system like that. As do car washes for spotless wash.
m_clark54 is offline   Reply With Quote
Old 02-19-2014, 02:57 PM   #25
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
I'd say the best thing about working on my Subaru is... Moof General Community 62 04-02-2009 11:58 PM
Best thing to do to my car for $500? SubZombie Newbies & FAQs 20 06-09-2004 09:16 AM
('93-'01) first thing to do for my 2.5RS Blk Devil RS Impreza Forum 18 05-12-2002 03:53 PM
The things we do for our cars... VallejoWRX Bay Area Impreza Club Forum -- BAIC 2 03-18-2002 03:04 AM
What should I let the brake techs do to my Subaru? Mako Brakes, Steering & Suspension 4 02-08-2002 08:13 AM
