Old 04-18-2012, 12:23 PM   #1
Masterchief117
Member#: 311736
Default Do I need Meth/water injection or just a prefrence?
I read some of the sticky and skimmed through the section a bit. I get the gist that anyone would benafit from meth/water injection. Do I need it though. Stage III wrx w sti short block with wiseco forged pistons,forged rods acr bearings, tuned by turbo xs running 16-19 psi boost and lots of bolt ons.
Masterchief117 is offline   Reply With Quote
Old 04-18-2012, 01:44 PM   #2
bhinak
Member#: 300026
Nah. You don't NEED it. But you could run your engine a little harder, put some more boost in there, and get more horses safely.
bhinak is offline   Reply With Quote
Old 04-18-2012, 05:11 PM   #3
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
If you have access to e85 then go for that.
Ysidro is offline   Reply With Quote
Old 04-19-2012, 04:45 PM   #4
Masterchief117
Member#: 311736
I have and run 93 octane containing up to 10% ethonal here in Va. Ill look into options, thank you!
Old 04-23-2012, 05:02 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Need is a strong word. Your car is running now so i guess it is not needed right? People run 500whp+ setups without meth, why would you think you NEED meth at stage III?
short answer = no
Old 04-24-2012, 05:44 PM   #6
Masterchief117
Member#: 311736
I was thinking just to cool things off a bit and to prevent detonation if I decide to go with more boost in the future and retune it. But mainly for temp. reasons. Car runs good, recently did a warm leakdown test and got 10% on 3 cyls and 13% on the 4th. Dont burn oil but I think my turbo seals may be taking a dump. Puffed out smoke a few times (greyish) during a hard accel. but never blue and never on cold startups. so I figured Id get a bigger turbo retune and ad meth to prevent detonation and keep it cooler.
Old 04-24-2012, 07:17 PM   #7
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Alternative to running water injection, richen up the AFR is the most common practice to protect your engine from knock when encountering a dose of bad fuel or high ambients. Most of the time, the engine management will pull back timing and richen up the mixture even more.
A little bit of water will do wonders and will prevent the ECU from going to plan B. Only inject ~10-15% of water(to fuel) and a few psi of additional boost. Beyond that, you will require a re-tune and a water injection system with failsafe.
Aquamist is offline   Reply With Quote
FS OR : AEM Meth / Water Injection Kit wrxridah Engine/Power/Exhaust 14 02-19-2009 12:44 PM
Coolingmist alcohol/meth/water injection kit Phil Jr. Private 'For Sale' Classifieds 24 06-21-2006 04:51 PM
Timing values and alcohol/meth, water injection reid-o Engine Management & Tuning 0 04-27-2006 03:45 PM
EJ205 + DB TD05H-20G + 50/50 Meth/water Injection.... testes1010 Proven Power Bragging 39 03-06-2006 01:58 AM
Swaybars: Do you need front AND Back, or just a back sway bar SILVERWRXWAGON Brakes, Steering & Suspension 9 10-22-2001 12:24 AM
