Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 04-05-2012, 11:15 PM   #1
mpristave
Member#: 284761
2012 WRX
Default 12 WRX turn signal always going out.
About to bring my WRX for a 3rd warranty replacement on my left turn signal. Just wondering what could be the cause of this constantly going out? The first time they said that it could have been a kink in the wiring from the factory so they replaced the harness and that fixed it for a time until it went out again.
The light activates when the turn signal is put on but its very dim, looks like only 1 of the 2 filaments inside the light go on. Any ideas?
mpristave is offline   Reply With Quote
Old 04-07-2012, 11:33 PM   #2
Allen Horton
Member#: 315961
2008 WRX
Dark gray metallic
I am having the same issue, and will be visiting my dealer on monday afternoon. Please let us know if they give you a legitimate reason (doubtful) and I promise to do the same. It wouldnt be such a big deal if it wasnt such an involved job to replace :/
Allen Horton is offline   Reply With Quote
Old 04-08-2012, 12:01 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
It would be a good thing to check the power getting to the light. If the full 12 volts is getting to the lamp when it is on then it means there is a ground connection problem to that lamp. If the voltage is low then there is a problem in the wiring on the power side of the circuit.
Cougar4 is offline   Reply With Quote
Old 04-08-2012, 12:36 PM   #4
infinite012
Member#: 74392
2015 Forester
Driver side blinker? I thought there was a recall out for this and the fix was to push the plug harder onto the bulb?
infinite012 is online now   Reply With Quote
Old 04-09-2012, 10:04 PM   #5
Allen Horton
Member#: 315961
2008 WRX
Dark gray metallic
Infinite, you would be correct. I just posted a reply in the warranty/ electrical thread. Wires can be pulled to tight during the car building process. Push the base harder... It will work fine, reroute the wires and relieve any tension, in theory, FIXED.
Old 04-24-2012, 08:18 PM   #6
Jon-Preza
Member#: 299412
2011 Subaru Impreza
Camelia Red Pearl
I just noticed this thread. I just replaced my bulb again for the 2nd time in 6 months of owning the car. I will try this fix and see what happens. It seems to work for me for a few months and then it goes out.
Jon-Preza is offline   Reply With Quote
Old 04-24-2012, 08:28 PM   #7
f1speeder
Member#: 138854
Here is my Thread on it with some fix it yourself instructions. By the way it's not just the bulb. It's the wiring harness.
http://forums.nasioc.com/forums/show....php?t=2174949
f1speeder is offline   Reply With Quote
Old 04-24-2012, 11:37 PM   #8
Jon-Preza
Member#: 299412
2011 Subaru Impreza
Camelia Red Pearl
Thanks for the link. I did notice when I replaced the bulb that the harness was awfully tight. I will just take it in next weekend and have it fixed for free. Might as well.
Thanks for the help.
Old 04-27-2012, 04:42 PM   #9
hakira
Member#: 74211
SSM WRX 4DR
i just pushed in the connector in with more pressure.. for worked me for more than 20k miles now
hakira is offline   Reply With Quote
Turn signal fuse blowing out repetitively tehhali Electrical & Lighting 7 05-28-2014 10:05 PM
Why do American punk-rock boys always go out with the new-wave hooker girls? Protege Menace Off-Topic 2 10-19-2004 07:38 AM
2004 wrx turn signal bulb 04subaru Electrical & Lighting 3 10-05-2003 03:01 PM
WRX turn signal bulbs??? STEVESblueWRX Newbies & FAQs 2 01-03-2002 10:34 PM
('93-'01) WRX turn signal bulb size?????? BkylnWReX Impreza Forum 0 06-02-2001 06:19 PM
