Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 04-23-2012, 12:38 PM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default EJ20G Timing belt cover gaskets???
Anyone know of an American motor I can source these off of?
tenchu is offline   Reply With Quote
Old 04-23-2012, 12:52 PM   #2
RallyColtTurbo
Member#: 16819
2002 MBP WRX, '98 OB
Three Gen 1 Legacy Turbos
Legacy EJ20G? No source.
early Impreza EJ20G? '96 Legacy w/2.5 liter motor (EJ25D)
later Impreza or Forester EJ20G? '98 Legacy w/2.5 liter motor.
RallyColtTurbo is offline   Reply With Quote
Old 04-23-2012, 08:51 PM   #3
tenchu
Member#: 64147
1993 STi RA V LTD
Green
SUPER early EJ20g me thinks.
Old 04-23-2012, 11:27 PM   #4
RallyColtTurbo
Member#: 16819
Legacy EJ20Gs are the oldest and can be identified by 2 bolts holding each coil down vs. only one bolt on Impreza versions.
Old 04-23-2012, 11:46 PM   #5
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Single bolt. But I have old style cam/crank sensors vs my last EJ20G which had cam/crank sensors like my 99 EJ253.
Old 04-24-2012, 09:50 AM   #6
RallyColtTurbo
Member#: 16819
If it's single bolt then the early ('96 or '97) Legacy EJ25D stuff should work. Might need to figure out if it's the same as '96 or '97-'99 - if there is even a difference.
Old 04-24-2012, 08:23 PM   #7
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Do those sources also hold true for timing belt, component kits, tensioner, water pump, etc?
GGSimpreza is offline   Reply With Quote
Old 04-24-2012, 10:47 PM   #8
RallyColtTurbo
Member#: 16819
Timing set, yes.
Water pump, no. If you have the oil cooler use a USDM WRX pump ('02 is fine). If you don't have the cooler use a '92-'94 Legacy TURBO pump.
Old 04-25-2012, 12:03 AM   #9
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Originally Posted by RallyColtTurbo View Post
Timing set, yes.
Correct me if i'm wrong, but he can only use the belt & idlers off the EJ25D, I'm fairly certain the tensioner on the EJ25D is the newer style, whereas the EJ20G uses an EJ18 tensioner. Also don't think cam/crank seals will work from EJ25D?
Old 04-25-2012, 12:51 AM   #10
spackyscooby
Member#: 169257
2000 impreza rs
millenium jade
As far as I know (and I am just basing this off what the parts manager at local dealership said) all the cam and crank seals should be the same across the entire ej series line.
spackyscooby is offline   Reply With Quote
Old 04-25-2012, 02:33 AM   #11
RallyColtTurbo
Member#: 16819
Correct, you need to match your tensioner. EJ25Ds have been built with both new and old style and there is no clear line for the changeover.
IIRC, cam seals should be the same across all the phase 1 DOHC heads. Front crank seal is part of the oil pump and has never changed as far as I have seen.
Old 04-25-2012, 04:27 PM   #12
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
you can convert easily from one style tensioner to the other, personally i always prefer the newer rocker style. just source the backing/mounting plate that goes with the later tensioner.
elislider is offline   Reply With Quote
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 02:10 PM
EJ20 Center Timing belt cover & gaskets moss Engine/Power/Exhaust 26 01-07-2008 10:31 AM
Odd Q: EJ20G and MY98 EJ25 Timing belt covers Kostamojen Subaru Conversions 2 08-03-2004 09:44 PM
Timing belt cover gasket Tomnel Service & Maintenance 8 02-10-2004 01:28 PM
Timing Belt Cover Gasket??? I3eXa Normally Aspirated Powertrain 4 03-06-2003 03:53 AM
Message Board Statistics All times are GMT -4. The time now is 01:26 AM.
