Old 04-24-2012, 10:22 PM   #1
jacksonsk
Member#: 289583
Default bugeye rebuild
I have a coupe general questions about rebuilding the ej205.
I'm going with acl race bearings but what size fits the 2002? Can I reuse the head bolts after I have removed them? What has been the best way you guys have found to split the block? Any help would be appreciated! Or any parts anyone may have for sale. Thanks
jacksonsk is offline   Reply With Quote
Old 04-24-2012, 11:22 PM   #2
BlInK311
Member#: 240840
2002 Bugeye
Sedona Red Pearl
Fastwrx.com has a pretty good guide to taking apart a block. You should go check it out.
As far as reusing head bolts. I've always read to replace. But I am in no way an expert.
BlInK311 is offline   Reply With Quote
Old 04-25-2012, 12:12 AM   #3
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
The bearings you need are going to be size specfic to the cranksaft depending on if it has to be resurfaced or if it already is resurfaced. The crank will need to be machined first and the shop will tell you what they machined it to. You then have to buy the corresponding oversize bearings. With that said, you need Main bearings in Thrust position #5 and Rod bearings in 52mm. DO not buy them till you know what oversize you need. But if you have a NEW crankshaft you will order STD size bearings for both. Maximum over size for Subaru crankshafts are .50mm (US .20) on the rod journals and .75mm (US .30) on the mains. Make sure you relay that info to the machine shop
Best way to split the block with common tools is to make sure you have removed ALL the bolts! Some are hidden and hard to find. Then using a rubber mallet tap along the seam of the block where it splits. The at the front and rear of the block find a good solid place to give it some muscle with the mallet and work it evenly. There is a dowel pin on the front top and bottom rear that are pretty tight but require the block to be separated evenly to avoid damage to the block.
As for reusing the bolts.... meh. Maybe once if you have to and skip the backing off of the bolts in the tightening sequence because that is for stretching new bolts. New OEM bolts cost just as much as ARP studs so....... yeah pretty pointless to buy OEM in my opinion.
UK-Wagon is offline   Reply With Quote
Old 04-25-2012, 01:33 AM   #4
jacksonsk
Member#: 289583
Thanks guys I appreciate the help! I'll keep looking and get my crankshaft to the machine shop! Thanks again.
Old 04-30-2012, 09:27 PM   #5
fendrick
Member#: 254744
buy new bolts or better yet. head studs. head studs are reusable versus its not really recomended to reuse bolts. i bought head studs after i only had about 5k on my new motor that blew. new bolts,studs for sure
fendrick is offline   Reply With Quote
What fogs for bugeye? streetspeed607 Interior & Exterior Modification 11 04-25-2012 07:21 PM
FS : jdm grill bugeye 02 03 wagonkid24 Exterior/Styling 5 04-24-2012 08:58 PM
Headlight rebuild clip replacement - bugeye hybrid gti 2 Interior & Exterior Modification 6 11-10-2011 03:22 PM
Rebuild The Bugeye Or Buy '11 STi? sube-trex General Community 56 09-06-2011 06:42 PM
Kevin's Bugeye Rebuild (JDM 6 speed, and everything in between) kscasper13 Member's Car Gallery 133 02-27-2011 07:30 PM
