Old 03-29-2012, 11:46 PM   #51
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
A few months ago, I stumbled across a new type of CV joint, and I immediately thought it would be great for axles and driveshafts, if it could be made suitable for the high RPMs.
So I guess this is the place to ask: have you guys at DSS looked into using a Thompson coupling in place of the Rzeppa and/or tripod joints? The main obstacle I can see is the strength of the inner bearings, yokes, and scissor links.
The CV joint wikipedia article has a nice cutaway of the joint.
Old 03-30-2012, 04:12 PM   #52
Driveshaft shop
Member#: 306253
The issue with this design is that it can only turn to 15 Degrees, you would not be able to turn the car with this set up. its a very interesting design and has its advantages but i don't feel an Axle would be the place.
Driveshaft shop is offline   Reply With Quote
Old 03-30-2012, 06:56 PM   #53
subi400
Member#: 216984
1996 Impreza outback
Green
This is a great product!!! As more and more people find out, look for your business to be hopping even more especially for people with stock cars that just wanted a better axle all the way around along with better quality boots.
Do you think you will be able to make some axles for the older imprezas like the 1996 - 2001 and from 2002 - and above?
Subscribed!
Old 04-02-2012, 01:47 PM   #54
dragoontwo
Member#: 275500
1992 SVX
Or for the Subaru SVX!
dragoontwo is offline   Reply With Quote
Old 04-24-2012, 04:52 PM   #55
nattywrx
Member#: 271998
Phatbotti tuned 16GXT E85
Wait so are you guys currently selling axles? I need a set for my 02 wrx.
nattywrx is offline   Reply With Quote
Old 04-24-2012, 05:04 PM   #56
Driveshaft shop
Member#: 306253
Old 04-24-2012, 06:59 PM   #57
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Did ya'll ever make any headway on Level 0 axles like I mentioned in post #7 here? Also http://www.driveshaftshop.com/import...-a-racing-axle says that they only work in 02/03 but this is an 04-07 page so something isn't right with the wording.
Old 04-24-2012, 07:15 PM   #58
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
If I were to guess they are using 02-03 and 04-07 as vocabulary for referring to stub ins or stub outs...
02-04 WRX should have a female-ended axle, 05-07 WRX should have a male-ended axle.
lancelucas is offline   Reply With Quote
Old 04-24-2012, 10:50 PM   #59
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
To add to this, there's also a pretty big market for R180 conversion axles -- R180-style inners and R160-style outers. I realize DSS already makes a solution for this but it's $1000...I'm currently putting an R180 in my WRX so I am pursuing an axle solution. Suberdave's conversion races @ $175 are hard to pass on compared to $1k for these; a more basic solution in the $400-$600 range would be fantastic!!
Cheers and thanks for all of your hard work and for sharing so much info!
Lance
Old 04-25-2012, 01:04 AM   #60
nattywrx
Member#: 271998
This is where I got confused as well. Any help would be appreciated.
Old 04-25-2012, 07:16 AM   #61
Driveshaft shop
Member#: 306253
yes we did (level 0 Front acles for the later cars), ill review the info i have later and let you know. as for the R160 to R180 swap axles we cant really make them any less expensive, the WRX outer is very small and being Dave is making the races you have and alternative if you wan to use Factory parts for a great price.
Old 04-26-2012, 08:55 PM   #62
caperex09
Member#: 243122
now on my list of things I wish for!
caperex09 is offline   Reply With Quote
Old 06-25-2012, 04:46 PM   #63
Driveshaft shop
Member#: 306253
just checking to see how you guys that bought the carbon shafts like them.
Old 06-25-2012, 05:14 PM   #64
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Still love mine. have multiple 1.5x 60' times on it so far.
cnstman is offline   Reply With Quote
Old 06-25-2012, 07:32 PM   #65
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Do you not make any axles for the 2008-2012 WRX? (not STI)
I see parts for STI rear axles (but no fronts)
Old 06-25-2012, 08:03 PM   #66
obsolesce
Member#: 248337
Unfortunately I installed this part with a lightweight flywheel, new motor, tons of upgrades etc. So I can't really speak to an A - B comparison. What I can say is excellent fit and finish. Bolted right up no issues and reinstalled the factory rear diff/shaft protection cover no issues. No weird vibrations at any speeds etc. Very pleased with this part. A true high quality bolt on part here.
obsolesce is offline   Reply With Quote
Old 06-26-2012, 03:46 AM   #67
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
I recently bought a new set of DSS R180/WRX conversion rear axles for my 04 WRX Wagon. Overall I am very impressed -- great work guys! Need to keep stashing cash and get the CF Driveshaft and Level 5 front axles
Old 07-04-2012, 09:03 PM   #68
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Will call
Old 08-19-2012, 09:47 PM   #69
redrexmeister
Member#: 111692
04 wrx wagon
Bookmarked
Thank you for very informative thread.
redrexmeister is offline   Reply With Quote
Old 08-30-2012, 06:34 AM   #70
Driveshaft shop
Member#: 306253
Thanks, if you have any other questions on axles or shafts don't hesitate to ask. just send a PM. were here to help
Old 12-03-2012, 01:16 PM   #71
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Are these wagon fitment or sedan?
Wagon owners are really screwed. The only aftermarket axle that anyone vouches for with good experience is EMPI (or raxles) but they are only sedan fitment!
I need a reliable axle alternative to OEM's $400/each replacement
I have only stage 1 power so I don't need the 900 HP stuff.
chimchimm5 is offline   Reply With Quote
Old 12-03-2012, 04:00 PM   #72
Driveshaft shop
Member#: 306253
what year car did you need it for.
Old 12-03-2012, 07:22 PM   #73
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
2006 WRX wagon 5sp
Old 12-03-2012, 07:53 PM   #74
Driveshaft shop
Member#: 306253
its been some time since i have looked at this but i was thinking the 04 and up wagons had the same front axles. if not le me know whats different we should be able to make them from parts in stock.
Old 12-05-2012, 10:28 AM   #75
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Driveshaft shop axle reviews emsbuff124 Transmission (AT/MT) & Driveline 0 07-11-2011 11:02 AM
Driveshaft shop axles oem hub failures mtcs Transmission (AT/MT) & Driveline 2 12-14-2010 01:06 PM
Anyone running the driveshaft shop axle shafts? jetfan8178 Transmission (AT/MT) & Driveline 1 11-09-2006 09:19 PM
What makes a $350 tent so much better than a $60 Coleman? Gravel-Fun Off-Topic 54 09-20-2005 02:16 PM
Driveshaft Shop Axles Cossey Transmission (AT/MT) & Driveline 4 06-24-2004 12:43 PM
