Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-24-2012, 09:26 AM   #1
rookrex
Member#: 214118
2015 STi
CWP
Default RA Mudflap Install - Baja?
For you guys that have RAs on your Baja? How'd you install them? I keep looking and I can't seem to find anything. Does the hardware that comes with them fit or do you just put rig them up yourself?
If you rigged them up yourself I'd love to what you did and if you'd recommend it or not.
rookrex is offline   Reply With Quote
Old 04-24-2012, 09:00 PM   #2
slagman
Member#: 214691
2005 Baja Turbo
I bought the basic ones first to make a template as you can see here (front flap is the left one in pic and rear is the right) then I got the universal urethane ones and copied the template. I drilled a only a few holes, finally got them in the right spot after some trial and error. Will post some pics later of them installed. I think they came out nice.
slagman is offline   Reply With Quote
Old 04-25-2012, 11:03 AM   #3
got_baja_?
Member#: 261189
2003 Baja
Baja Yellow
i just drilled mine in... lazy i know and the do flap a little in HEAVY wind but all in all they look pretty decent.
got_baja_? is offline   Reply With Quote
Old 05-05-2012, 09:51 AM   #4
lumpy
Member#: 28410
2012 Impreza Sport
+1. I traced the shape and created cardboard ones to play with, get level, get square and get even. I then bought some stainless hardware and metal tie-ins at Home Depot (flat pieces of metal used to tie wood together) and used them to brace the side facing the fender liner. Unfortunately I neglected to take pictures of the process, but here is what they look like installed.
lumpy is offline   Reply With Quote
Old 05-05-2012, 09:59 AM   #5
lumpy
Member#: 28410
2012 Impreza Sport
Here are the metal tie-ins that I used. <CLICK ME>
Basically I just used these to span the dead space in the wheelwell, creating a flat surface and giving the flap some support and rigidity at the top. It worked great through the, albeit mild this year, Ohio winter.
2003 WRX RA gearset install - ATX - recommends Kastley85891 Texas Impreza Club Forum -- TXIC 2 07-31-2011 10:54 AM
2011 WRX RA mudflap install help brandonk_5 Interior & Exterior Modification 33 04-04-2011 01:19 PM
FS: NJ - Set of Black RA Mudflaps Nsj77h Exterior/Styling 3 05-14-2010 12:13 PM
FS IL: Rears Only RA Mudflaps - Urethane, black with Grey logo JM530 MWSOC Private Classifieds 1 05-06-2009 03:09 PM
FS - Bayside, NY - Seibon 06-07 hood, RA Mudflaps, Turbo Inlet, Momo, bpv, more.... PointWRX Tri-State Area Private Classifieds 27 12-04-2008 12:40 PM
