Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 04-23-2012, 10:38 AM   #1
visualsinz
Member#: 160900
2004 WRX STI
JBP
Default 04 Forester XT M/T Build
I traveled 2 hrs about 2 weeks ago to pick this 2004 Forester XT up from a Ford dealership.
I drove it home and noticed a little bit of smoke (white, oil smell). I threw on my full TurboXS turboback exhaust and at that point realized something was wrong as the smoke was just pouring out. The car ran fine though.
I swapped turbos (4 times), but this was not the problem.
I came to the conclusion that it was either a bad head gasket or a bad piston and decided to do a small engine build.
Lessons I have learned... Always get a turbo car compression checked.
Background:
I have owned 5 turbo Subaru in the past 6 years and 1 non turbo.
2002 WRX- Stage 2
2004 STI- Stage xxx- 375 awhp
2006 WRX- Stage 2
2002 WRX- Stage 2
1998 2.5RS
2004 Forester XT
So back to the Forester build.
These are the parts I have bought so far:
New EJ257 longblock
Gates timing/ water pump kit
ARP head stud kit
Full OEM gasket kit
Killer B oil pickup
STI TMIC
V9 VF37 full twin scroll setup
BC valves, springs, retainers
BC stage 3 heads
AP fuel rail/line kit
18x8 Rota Tarmac
2007 WRX shocks/springs
I'm sure there is more.
I am taking the heads tomorrow so they can start on the cleaning/machine work.
The Forester
Empty
Engine pulled
The breakdown starts
Continued
Heads off
visualsinz is offline   Reply With Quote
Old 04-23-2012, 10:38 AM   #2
visualsinz
Member#: 160900
2004 WRX STI
JBP
New Block
Valves, springs, retainers... hopefully the cams are waiting in the mail
Cams came in- BC stage 3
Painting before and after
Old 04-23-2012, 10:38 AM   #3
visualsinz
Member#: 160900
2004 WRX STI
JBP
New 08+ STI Oil Pump Installed
Gates Water Pump Kit Installed
Heads back: BC stage 3 cams, valves, springs, retainers. Port and polished and 2 angle valve job. ARP head studs and OEM STI head gasket.
Old 04-23-2012, 10:38 AM   #4
visualsinz
Member#: 160900
2004 WRX STI
JBP
Took a break. Back on it.
Old 04-23-2012, 10:39 AM   #5
visualsinz
Member#: 160900
2004 WRX STI
JBP
More parts added, most notably the JDM intake risers are cleaned, painted, and installed and the AP fuel rails are mocked up.
More added, plus fit the IM to decide how I will be running my fuel lines.
Old 04-23-2012, 10:39 AM   #6
visualsinz
Member#: 160900
2004 WRX STI
JBP
More work. I'm going to have to take the IM back off and hone out the 2 center bolt holes. I'm also going to put some teflon paste in the rail connections while I'm at it.
More parts finally arrived and installed.
STI IM came in. I modified it, and it fit great.
Killer B oil pan came in also. fits like a glove.
Old 04-23-2012, 10:42 AM   #7
visualsinz
Member#: 160900
2004 WRX STI
JBP
Finally started working on the car again.
Old 04-23-2012, 10:43 AM   #8
visualsinz
Member#: 160900
2004 WRX STI
JBP
reserved 7
Old 04-23-2012, 10:43 AM   #9
visualsinz
Member#: 160900
2004 WRX STI
JBP
reserved 8
Old 04-23-2012, 10:43 AM   #10
visualsinz
Member#: 160900
2004 WRX STI
JBP
reserved 9
Old 04-23-2012, 10:43 AM   #11
visualsinz
Member#: 160900
2004 WRX STI
JBP
reserved 10
Old 04-23-2012, 10:03 PM   #12
Abest10
Member#: 190962
00 STM RS
04 FXT
O my. That is and is going to be a one hawt Forester. Ive been looking at buying one. How do you like yours so far?
Abest10 is offline   Reply With Quote
Old 04-24-2012, 08:39 AM   #13
visualsinz
Member#: 160900
2004 WRX STI
JBP
I love it, granted it needs some improvement in the handling department.
There's not much to say about a Subaru that can be faster than a STI with a STI turbo swap, STI TMIC, and a tune and still haul and pull a ton of stuff.
Old 04-24-2012, 09:44 AM   #14
Slurpyy08wrx
Member#: 256155
Got a lot of courage buying a new car then ripping the engine out and building it! I wish I had the courage to do it to my 08 wrx, I do have another DD.. Hmm haha.
Good job so far!
Slurpyy08wrx is offline   Reply With Quote
Old 04-24-2012, 08:59 PM   #15
Abest10
Member#: 190962
00 STM RS
04 FXT
Well I will be watching this build thread closely. I have a STi intercooler already just need the forester to put it on haha. keep up the good work!!
Old 04-25-2012, 09:15 AM   #16
visualsinz
Member#: 160900
2004 WRX STI
JBP
Thanks. I will have more pics up today for the work I did last night.
Old 04-25-2012, 02:40 PM   #17
visualsinz
Member#: 160900
2004 WRX STI
JBP
updated
Old 05-03-2012, 11:41 AM   #18
visualsinz
Member#: 160900
2004 WRX STI
JBP
My Forester oil pan (whick is the same as the 2.0 wrx) will not work with my Killer B pickup, so I ordered a Killer B oil pan.
I am also waiting on my 04 STI intake manifold. The JDM TGV deletes I bought gave me some problems. The 2 center mounts are slightly different, so I went to notch my stock manifold (at 11 at night) and ended up notching the wrong side.
Old 05-08-2012, 01:43 PM   #19
visualsinz
Member#: 160900
2004 WRX STI
JBP
updated
Old 05-08-2012, 08:39 PM   #20
LiCelsior
Member#: 182551
2004 STi
damn thats a nice build.
LiCelsior is offline   Reply With Quote
Old 05-10-2012, 02:35 PM   #21
rifxt
Member#: 270874
2004 FXT 5MT
What ended up being the problem? Head gasket, piston, or something else?
rifxt is offline   Reply With Quote
Old 05-12-2012, 11:18 AM   #22
visualsinz
Member#: 160900
2004 WRX STI
JBP
I think head gasket and maybe a ring. I didn't investigate further once I got the new block.
Old 05-16-2012, 04:34 PM   #23
visualsinz
Member#: 160900
2004 WRX STI
JBP
Well, probably won't be updating for a couple of weeks after these. I've spent about $8k on the build and the cash flow has run out. I still have to buy another downpipe and clutch and take the car to Altanta to put on the dyno for breakin/tune.
Mod list to date:
New EJ257
Complete head rework including port and polish
BC stage 3 cams
bc valves, springs, retainers
All new oem Subaru full gasket kit
Gates timing belt, pulley, and water pump kit
11mm 2011+ STI oil pump
AP fuel rail and line kit
DW 850cc injectors
Killer B oil pan, baffle, and pickup
STI intake manifold
JDM intake risers (TGVless)
STI TMIC
FMS silicone intercooler/bpv piping kit
Perrin V2 inlet tube
GS AOS kit
3 Port BCS
FMS catless uppipe
Deadbolt SZ55
TurboXS RFL catback exhaust
GFB dual port BPV
07 WRX suspension
Rota Tarmac II 18x8
Cobb AP V2
S.S. braided AVCS/turbo lines
Everything is new except for the turbo and IM. Looking back, I wish I would have bought more used, but it's so hard on a build like this. Being new, I should not have to worry about defects or wear.
I will be setting the timing and buttoning it up, but other than that I am stuck for a bit.
Old 06-26-2012, 09:36 AM   #24
visualsinz
Member#: 160900
2004 WRX STI
JBP
Old 06-28-2012, 09:16 AM   #25
visualsinz
Member#: 160900
2004 WRX STI
JBP
New development: TRading the Deadbolt SUperzilla55 for a SZ65 (60lb/min wheel), 3" AP inlet, and Externally gated uppipe.
04 Forester XT or 04 WRX Wagon which to buy?? RonnieButironi Newbies & FAQs 19 12-22-2010 10:26 AM
04 Sti front end on 04 Forester XT???? Possible?? scoobydoo666 Subaru Conversions 5 11-24-2010 07:15 PM
(SoCal) Cobb Accessport V2.0 AP-002 2.5L 06+ WRX 04+ STi 04+ Forester XT 05+ Legacy midnightkiss Engine/Power/Exhaust 5 01-09-2010 12:32 AM
Is the 04+ WRX up-pipe the same part as the 04+ Forester XT up-pipe? illt3ck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-01-2009 04:38 PM
Forester XT 2 sti build Sun2bOwner Newbies & FAQs 6 11-29-2009 03:04 PM
