Old 04-25-2012, 01:22 AM   #26
wheaties
Member#: 316633
2012 Impreza
I really like what you have done so far. I just bought a 2012 impreza and also wanted to put supertones on it. Is it possible to mount the hellas behind the top grill?
wheaties is offline   Reply With Quote
Old 04-25-2012, 11:32 AM   #27
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Anything is possible. You might have to drill a couple holes or fab some kind of bracket but there shouldn't be any reason why you couldn't. For ease of installation, I used existing bolts to mount mine.
italia490 is offline   Reply With Quote
Old 04-25-2012, 04:19 PM   #28
Kennan04
Member#: 268525
1993 Chevy Cavalier
Red w/ Yellow flames
Finally a modded 12 impreza. turbo down the road...supercharger...
Kennan04 is offline   Reply With Quote
Old 04-25-2012, 04:28 PM   #29
sweetsatin
Member#: 304578
2012 WRX Limited
Just out of curiosity, you said you wanted to do a wrx engine swap down the line, why not just start off with a Wrx instead?
Keep on modding the car and hopefully there will be a bigger aftermarket support.
sweetsatin is offline   Reply With Quote
Old 04-25-2012, 04:41 PM   #30
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
The plan is to turbo the car. I won't do it though till the warranty is up. I am actually in the process of planning right now.
Old 04-25-2012, 04:51 PM   #31
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
That's a great question. I did look at the WRX and Legacy GT and financially it didn't make sense. I wasn't going to settle for anything other then a Subaru so the Impreza make good sense. I have several goals in mind with this car and ultimately I am after the "sleeper" look. There are several exterior mods that I will be doing like roof spoiler, side skirts, front lip and possibly some type of body mods (to remain under wraps for now) as well as suspension work and wheels but I want to preserve the original look of the car. I'd say I am pretty resourceful and since the aftermarket for our cars is poor at best, the purpose of my build is to show that with a little ingenuity and research you can set out to achieve what you want regardless of the aftermarket support. And who knows, maybe the aftermarket will realize that even though are cars don't have turbos, there is still a desire to mod them and consequently develop parts....as in the case with rallisport racing for the UEL headers.
Old 04-26-2012, 11:05 AM   #32
BryanP5555
Member#: 314731
2012 Impreza Sport
Lets get that drive by video
BryanP5555 is offline   Reply With Quote
Old 04-26-2012, 03:03 PM   #33
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I was wondering how much plasti dip you used to spray your grille? So I can kind of gauge how much to use. I think I'll need three coats to get full coverage.
Old 04-26-2012, 03:27 PM   #34
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
It's on my list of things to do.
Old 04-26-2012, 03:29 PM   #35
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I think I used 1/2-2/3 of a can. I did at least 4 coats. Make sure the first coat is pretty light and gradually build it up.
Old 04-26-2012, 11:23 PM   #36
Huffin
Member#: 315575
2012 Impreza Sport
Dark Metallic Gray
Originally Posted by italia490 View Post
I figured I should start a build journal to document the path I plan to take in modding my car. I picked up a 2012 Impreza Sport Premium in Marine Blue Pearl at the end of January. I have been lurking on this site and IWSTI for a couple of years readings and learning in hopes of getting an STi. With the cost of gas and potential engine trouble I decided NA was more economically feasible. I went to a few dealerships looking for a 2.5i Legacy but wasn't too keen on the electronic handbrake. So I found myself at Irvine Subaru with Marcelo helping me. That's how the story begins.
As you can imagine, idle hands are the devil's play ground and the urge to mod bit right away. Problem is, there isn't yet a lot available so thinking out of the box is a must.
Link to pictures:
http://s1161.photobucket.com/albums/q507/strunz490/
Mods installed:
Prodrive shift knob. Freebie from the dealer.
Smoked tail lights-turn signal and reverse only with VHT Nightshades
Rear Bumper LED reflectors wired up to brake lights
Plastidipped front grille
Hella Supertones with Blue powder coated grill
Rally pig sticker on drivers side mirror
Full LED swap except for DRL's
Sharkfin Antenna
Custom axleback exhaust
6K HID's
Planned:
Cobb adjustable short shifter
Cobb shifter bushings
Cobb/Perrin shift knob
JPM Coachworks Shift boot and ebrake boot.
LED DRL's
STi front lip
Side skirts
Tein S-Tech springs
Rota G Force 18x9 +35et
Rally Armor Mud flaps
UEL Headers
Project KICS lugnuts
Kartboy pitch stop
GT Spec steering wheel
Grimmspeed license plate delete
Custom LED tail lights
Blacked out headlights
STi brake swap
And lastly a WRX engine swap.
For your exhaust, all you did was take out the muffler and weld those 2 pieces together and bolted it to where the muffler used to be?
If so, can you do that for me as well and I pay for it? I want the boxer growl but I still want to keep my muffler when I have to bring it in to the dealer for any reason so I can easily swap it to stock.
PS- doing a muffler delete, does it effect the hp or mpg?
BTW, I live in NYC.
Huffin is offline   Reply With Quote
Old 04-29-2012, 07:55 PM   #37
pkL
Member#: 313093
2012 Impreza 2.0i
Got it thanks, I made an offer to the eBay seller you got your HIDs off of. I think it was you who had posted the link. Our 2012 Imprezas take the H11 bulb is that correct? Did you just install the HIDs into the halogen housing or did you get projectors or something to go with them?
Old 04-30-2012, 12:20 PM   #38
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
[quote=Huffin;36992157]For your exhaust, all you did was take out the muffler and weld those 2 pieces together and bolted it to where the muffler used to be?
BTW, I live in NYC.[/quote
Sorry for the late reply....At this time I don't have any plans on fabricating more exhaust setups like this, especially since I have not yet completed design/testing. Maybe down the road I might consider it. In the meantime though I can point you in the right direction as to where you can get the raw materials if you like....
As far as the muffler delete goes, there is no effect on hp or mpg. It's strictly for the sound.
Old 04-30-2012, 12:22 PM   #39
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yes, H11 bulb is correct. I just installed the HID's into the stock housing. Light scatter is minimal. A projector retrofit is something that I am considering after completion of more "important" mods.
Old 04-30-2012, 01:39 PM   #40
Huffin
Member#: 315575
2012 Impreza Sport
Dark Metallic Gray
As far as the muffler delete goes, there is no effect on hp or mpg. It's strictly for the sound.[/quote]
Yeah I would definitely like some advise on how you did your exhaust and where I can get the materials.
Old 05-02-2012, 12:50 AM   #41
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yeah I would definitely like some advise on how you did your exhaust and where I can get the materials.[/quote]
PM sent
Old 05-07-2012, 04:22 PM   #42
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Scan gauge II going in this weekend and depending on time, I might take the headlights off, bake them and then black them out. I have had several requests for drive by video, so I will try and get that taken care of as well.
Old 05-13-2012, 10:19 PM   #43
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Not much of an update but didn't get anything done this weekend. Too much going on, especially being mother's day weekend. I'm keeping my fingers crossed for next weekend.
Old 05-22-2012, 11:08 AM   #44
scubyruvy
Member#: 277146
2012 2.0i Sport SWP
07 zx6r, RIP 04 wrx wagon
ahhh wheres the drive by video.... want to do the same thing with the exhaust
scubyruvy is offline   Reply With Quote
Old 05-23-2012, 12:44 PM   #45
Huffin
Member#: 315575
2012 Impreza Sport
Dark Metallic Gray
I did the same mod with the exhaust. When I get my car back from the body shop I will do a video too. It sounds amazing!!! Btw.... Some guy hit me which is why my car is in the shop. 😔
I will probably post it to YouTube and add a link.
Old 05-23-2012, 12:55 PM   #46
ben_art
Member#: 172635
2003 WRX Wagon
Aha! I knew this day would come! You MUST be one of the first Looking foreword to this. Subscribed!
p.s. can you just post pics in here, instead of posting links please.
ben_art is offline   Reply With Quote
Old 05-23-2012, 12:59 PM   #47
NOTanEVO
Member#: 210790
PSM EJ207 power plant
i love the new impreza hatches and have been waiting to see someone attempt a wrx/sti swap on them. exhaust sounds mean also, i was not expecting that. nicely done sir
NOTanEVO is offline   Reply With Quote
Old 05-23-2012, 03:26 PM   #48
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I have a 3 day weekend coming up which should give me ample time to do a few things this weekend. I noticed a rock chip in the plasti-dip on my grill due to too thin of sprayed material. So, I'll be removing the front bumper and grill so that I can fix the small issue. I'll take better pics of the Hella supertone setup for those that are interested. I am also going to do a DRL light mod, and a mod that involves the front, sides and rear of the car. A drive by video will also be taken....finally.
On a side note, I found a vendor that might potentially have an aftermarket CAI and axleback exhaust for our NA cars. I am just waiting to hear back.
Stay tuned.
Old 05-23-2012, 04:13 PM   #49
Huffin
Member#: 315575
2012 Impreza Sport
Dark Metallic Gray
Stay tuned.
Sweet!!!
Old 05-23-2012, 04:16 PM   #50
Huffin
Member#: 315575
2012 Impreza Sport
Dark Metallic Gray
Props to italia490 for giving me advice.
Base Line on ICS Project '07 STI - and test with snorkle removal Dyno Flash Proven Power Bragging 18 08-23-2007 09:25 PM
Blue Bomber! Project TunerWORKS STI Tuner4 Member's Car Gallery 88 03-20-2007 05:00 PM
Project 05 STI - modification recommendations AnorexicSTI Vancouver Impreza Club Forum -- VIC 41 09-09-2006 07:53 PM
Project CBRD STi for sale... chadblock Private Vehicle 'For Sale' Classifieds 12 07-05-2006 07:27 PM
Project Mu STi Brembo B-Force Fr + Rr Brake Pads paperchasin Private 'For Sale' Classifieds 14 07-08-2005 01:57 PM
Message Board Statistics All times are GMT -4. The time now is 06:20 PM.
