#3276 | |
Member#: 224785
MWSOC
Vehicle:2005 wrx-jdm207 i went black... |
#3277 |
Member#: 99103
NESIC
Vehicle:2003 WRX STI ej207 Yellow |
#3278 |
Member#: 246669
MWSOC
Vehicle:2002 WRX V8 EJ207 Aspen White |
looks sick man ^^^
#3279 |
Member#: 271412
Tri-State
Vehicle:05 ej207 wrx wagon wrb |
got the car dyno tuned today at efi logics
298whp/264tq on 18psi i did have an issue though which id like to figure out asap and go back for a retune with 21psi. my car is blowing out spark higher than 18psi. i had this issue with the car since ive got it last year. did it with the old plugs,new ngk bkre7ix both when they came out of the box and after i gapped them down to 0.26 like reccomended by clark. im thinking coil packs? or are my plugs still not right? friends car has ngk iridiums in his car and he got a 19psi tune with no issues. efi also said they never had any issues with the ngk iridiums and high boost eventhough some people swear copper is better ![]() |
#3280 |
Member#: 246669
MWSOC
does it matter if i have the pins in the spot for tgv sensors as long as there not plugged in to anything or should i i remove them for the connector?
#3281 |
Member#: 246669
MWSOC
using a IA Performance Bulk wiring kit to re-wire for avcs on a v8 swap into a 2002 wrx^^^
#3282 |
Member#: 46135
Tri-State
Vehicle:02 WRX Powered by Sti V9 Spec C |
You can leave the TGV as is.
#3283 |
Member#: 246669
MWSOC
Awesome thank you!
#3284 |
Member#: 154281
W. Canada
Vehicle:2002 V7 EJ207 Dom1.5 MBP |
I know that BKR7EIX is the spark plug to use for the EJ207... but im upgrading my turbo to the Dom 1.5XTR.
Is that spark plug still the one I should be using? |
#3285 |
Member#: 224785
MWSOC
i would assume so^ guys usually keep the same spark plugs for most applications. the gapping might change slightly if anything.
hurry up and get it on/tuned so i can see the results! |
#3286 | |
Member#: 154281
W. Canada
Im just wondering if I need to move to BKR8EIX because of the larger turbo. What're you guys with the GT30's and 20g's running for spark plugs? Still the same ones? Last edited by Zaider; 04-26-2012 at 10:44 AM. |
#3287 |
Member#: 54060
Tri-State
Vehicle:205 + td04=12.4@109 V8 207+VF37=12.3@111 |
Does anyone here know if the NPS is the same between an 04 WRX, 04 FXT and a JDM V6 STi non-RA? Need to know what will have to be changed with a V8 ECU.
What fuel will you be running primarily? |
#3288 |
Member#: 154281
W. Canada
Havent decided quite yet. Either Shell 91 or Husky 94. We dont have E85 here. In the future, I'll probably be installing my HFS-6 to run 50/50 water meth as well.
#3289 |
Member#: 6886
Tri-State
Vehicle:MY01 EJ207 HTA35r nothing to see, i'm stock |
stick with the bkr7eix on 91, the bkr8eix ran a bit too cold for me , at least on AZ 91 piss
#3290 | |
Member#: 154281
W. Canada
Our Canadian gas isn't any better than your AZ 91. Its tempting to switch back to 94 but it becomes a little harder to get and you have to plan out road trips... not like this car will see that sort of mileage anymore, but its something to think about in the summer months. I'll stick with the bkr7eix for now and if my tuner thinks they're not working, then Ill switch. oh, and fastnoypi, do you have a project thread? I want to see what a 35r looks like on a 207. |
#3291 |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
I have tuned hundreds of cars across canada in person and on e tune. The canadian fuel is far better then AZ91 summer blend fuel.
C |
#3292 | |
Member#: 6886
Tri-State
#3293 | |
Member#: 154281
W. Canada
Thanks Clark. Right on. Thanks, I will. |
#3294 |
Member#: 86107
E. Canada
Vehicle:02 SD built 207 |
yeah I've seen worse than canadian fuel.
94 oct oump is nice up here, but at 1.58 / L this morning ( it's cheap this week ) that brings it to 3.79L ( 1 US GAL ) = 5.99 $ CAD 5.99 CAD = 6.09 $ USD per gallon. Do the math. I call it rape fuel. Last week I filled @ 1.68 CAD / L for 94 oct. |
#3295 |
Member#: 224785
MWSOC
thank gosh for alot of local 93. nearly every station has 93 even though its a e10 mix most stations within 20 miles have 78,89, and 93. if i go up to Green Bay for some reason they love 91 octane so I always fill up before I go see the woman.
#3296 |
Member#: 246669
MWSOC
anyone have a base map for 93 octane for a V8 207, just so i can drive it to my tuner.
#3297 |
Member#: 224785
MWSOC
didnt one come on the ecu you have??? what setup are you running it on? you need the correct rom ID on the hex file to flash onto the one you have.
#3298 |
Member#: 246669
MWSOC
I thought the stock ecu is setup for 100 Ron which I was told will harm my motor using 93 octane. Im not sure what a rom ID is, is that one of the serial numbers on the ecu? this is my first time dealing with flashing an ecu so sorry if i sound like a newb
#3299 |
Member#: 246669
MWSOC
the only mods I will have is 3 inch downpipe, 3 inch cat back, P&L short ram intake, walbro 255
#3300 |
Member#: 224785
MWSOC
send me your rom file and ill change it so its good for ya. just open ecu flash. pull the rom and save it. then email it to me.
ill pm you my email. |
| Thread Tools | |
| Display Modes | |
| ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain | 2 | 02-26-2011 07:29 PM |
| Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain | 10 | 06-03-2010 04:53 PM |
| JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
| 08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
| Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain | 21 | 10-17-2005 01:56 AM |
