#426 |
Member#: 291749
E. Canada
Vehicle:2007 Impreza WRX WHITE |
Today the alarm goes off when I opened the trunk... So now the only moment it dont goes off is when I open the doors ( I tried driver and passenger side )
#427 |
Member#: 182213
MWSOC
Vehicle:1999 Contour SVT |
#428 | |
Member#: 280580
SCIC
Vehicle:2002 WRX WAGON World Rally Blue |
#429 |
Member#: 182213
MWSOC
#430 |
Member#: 291749
E. Canada
#431 | |
Member#: 280580
SCIC
#432 |
Member#: 316662
NWIC
Vehicle:2002 Subaru WRX Aspen White |
So i tried to reprogram my remote today and i put the key in and turned it 10 times and the horn chirped. Then i didnt apparently open the door and push a button on the keypad right. Took my key out and the horn chirped again(off). Now i have no working remote... Tired to start over but couldnt get the horn to chirp??
and i just looked at the flashing light and it looks like it in valet mode. blink blink pause. so i cant get it out of valet mode cause my remote dont work. So what do i do now to program my remote? |
#433 |
Member#: 182213
MWSOC
#434 | |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
#435 |
Member#: 317646
new here. was browsing through the forums and this was one of the many things i needed! thanks much!
#436 |
Member#: 264798
MAIC
Vehicle:2002 WRX WRB |
So if I get any older remote, could I program it to work with my car? My car didn't come with one and I've already locked myself out three times
#437 | |
Member#: 182213
MWSOC
http://www.viper.com/P-412V/Viper-21...s-Entry-System |
#438 |
Member#: 227273
Vehicle:7&11 Imprez$Forester |
I have a 2007 Impreza 2.5i. For the life of me I cannot get the car to go into program mode. Is there some special way one needs to turn the key. Should the key be in the ignition when I open and close the door?
The stupid dealership wants to charge me $50 per remote just to program them because I already have a couple of used remotes... since I spent a ghastly amount of money having non-transponder keys cut- I couldn't let myself knowing there was a manual way that I hadn't gotten working yet. EDIT----- This is an apparent variant of the instructions widely distributed. This worked on a 2007 Impreza 2.5i 1) Make sure everything is shut (same as other instruction). 2) Get in, sit down, shut door (same as other instruction). 3) Open and shut door (same as other) 4) Put key in Ignition and turn key from "lock" to "on" 10 times, and finish in "lock" (slightly different from described) - no tones or flashing lights occur as described 5) Open and shut door - a faint tone is heard 6) Enter numbers as directed. Push lock the number of times that equals the value, then unlock between each digit. - a tone is heard for each press 7) After <unlock> of last digit of the first sequence, hit unlock an additional time. - tone flutters 8) Reenter sequence. - tone for each press 9) for additional remotes or to push other codes out skip to 9a) 10) Open and shut door - long tone 11) Remove ignition key 9a) Open and shut door 9b) Enter first sequence as described above 9c) After <unlock> of last digit of the first sequence, hit unlock an additional time. 9d) Reenter sequence. 9e) Continue to step 10 or 9a Your mileage may vary - but that's what worked for me after a frustrating afternoon. I got my hint here http://www.clubwrx.net/forums/interi...tructions.html that the process may deviate from the description... and dumb luck opening and shutting the door when the lights weren't blinking. Last edited by iiibbb; 05-04-2012 at 04:41 PM. |
#439 |
Member#: 311204
i been trying to program my fob but i cant get the car to flash the lights or beep the horn is there a sensor or fuse that could be blow if so were is it iocated? i been trying for over a month to get this to work on my 02 wrx any ideas?
#440 | |
Member#: 227273
...see my most directly above. Worth a try. There seems to be some variability. Maybe you have the button? Our '99 had a button underneath the dash for that. |
#441 |
Member#: 311204
no button under dash on 02wrx i unhitched batt no luck i found a plug unhitched under the kick panel hooked back up no go
#442 |
Member#: 311204
Well found out my keyless entry unit is no good
#443 |
Member#: 227273
#444 | |
Member#: 301752
Thanks ever so much for finding these crazy voodoo instructions and posting them. This was very well timed. I've just programed a new remote (on the 2nd try) using this write up (after not being able to do it following the factory instructions??) on my '07 2.5i. I had purchased the car last fall with only one remote and the lock button did not work. So after purchasing a new remote on line. I attempted to program it. Well after hours of frustrating failure (nothing after 10x on/lock), I discovered, here, on another post that apparently the chirp/buzzer had to be functioning in order for the programing to work. Until then I did not know there was a chirp, because mine didn't work. So I left it for the winter, and today once again following this thread http://forums.nasioc.com/forums/showthread.php?t=608657&page=17 I got my chirp working, only to find I still could not get any further in the steps. Of course now that the remote is working I've turned the chirp off. Just wonder now if I really needed it to be functioning in order to program the remote. And why the heck does this method work and not the one in the owners manual?? Thanks again Chris |
#445 | |
Member#: 227273
#446 |
Member#: 227273
as to why the other instructions don't work. I suspect the changed it and didn't tell the people who write the manual. The above are actually simpler than that other craziness.
#447 |
Member#: 252747
Tri-State
Vehicle:'02 Impreza WRX PSM |
My lights flash when lock/unlock and the horn sounds. The remote functions perfectly...but the security light on the dash doesn't flash or anything. I used to lock the car with the remote, tap the car and the horn would honk once, now it doesn't do so anymore; i'm convinced the alarm is not armed.
I tried the steps but it doesn't seem to be working and when i cycle the key 10 times- 15 times, the horn doesn't beep. Any tips? Thanks guys! |
#448 |
Member#: 112285
MAIC
Vehicle:1994 E34 530i Oxfordgrun |
Lost the key to my 2011 STi. Found a key fob online, well the process listed on the first page work with this key?
#449 |
Member#: 293700
NWIC
So i have a 2011 impreza and i managed to lose a set of key and remote. I need to get it replaced but the dealership told me it would be $300. Any ideas that are cheaper and i can do on my own? Any help would be super appriciated.
#450 | |
Member#: 227273
I also noticed that some hardware stores (an ACE hardware specifically) are doing transponder keys as long as you have another. |
| Thread Tools | |
| Display Modes | |
| Factory Alarm + Keyless entry from 04 FXT | Skidd | Interior/Dressup/Audio & Security | 0 | 01-22-2009 08:26 PM |
| Factory alarm/keyless entry install - Anyone want to help?! | NickWRX | Tri-State Area Forum | 3 | 07-06-2008 09:22 PM |
| All you need to know about ass hair. | WRick | Off-Topic | 22 | 01-23-2006 07:22 PM |
| Factory Alarm / Keyless entry | Woody | Vancouver Impreza Club Forum -- VIC | 3 | 04-21-2002 11:51 PM |
| Factory alarm/keyless entry on MY01 | Safir | Car Audio, Video & Security | 1 | 02-08-2001 01:01 PM |
