Welcome to the North American Subaru Impreza Owners Club Saturday October 25, 2014
Old 06-11-2011, 10:12 PM   #1
slovak
Member#: 168922
07 STi
Obidissian Black
Default Cheap Crank Tool
Long story short, I was working on my 07 sti then my friend came with his 2000 Subaru Outback, 5-speed with a new crank pulley and bolt, I had made a tool that would fit the crank pulley on my car and when we were torquing it down my tool snapped.
Luckily I went to a tool store nearby and they had something that caught my eye, it said for use on cam gears but I gave it a try and it worked!
Here is a link to it on amazon.com:
Amazon.com: Lisle 38220 Universal Cam Adjuster: AutomotiveAmazon.com: Lisle 38220 Universal Cam Adjuster: Automotive
I paid a little more, $10 to be exact but a good tool to have, never know when that next motor build is coming and of course no more having to use the poor crank bolts to provide the holding power and hoping they don't snap under the load.
Happy wrenching.
slovak is offline   Reply With Quote
Old 06-15-2011, 03:33 PM   #2
slovak
Member#: 168922
07 STi
Obidissian Black
Anyone else have another tool for the crank pulley they would like to share?
Old 06-15-2011, 07:44 PM   #3
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
Yeah, 5th gear and the ebrake on if its in the car. If it's on an engine stand vice grips on the flywheel.
Old 06-15-2011, 08:05 PM   #4
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
Impact gun works wonders on stuff like that.
tobylazur is offline   Reply With Quote
Old 06-15-2011, 08:37 PM   #5
flstffxe
Member#: 155358
2008 Forester
Steel Silver
flstffxe is offline   Reply With Quote
Old 06-17-2011, 09:34 AM   #6
slovak
Member#: 168922
07 STi
Obidissian Black
Never tried the vice grips, did the 1st gear and parking brake, but so much easier with the tool of me knowing that its done proper.
Old 06-17-2011, 09:35 AM   #7
slovak
Member#: 168922
07 STi
Obidissian Black
yes it does, for taking it off, my impact gun is rated too high for the crank pulley or too low.
Old 06-17-2011, 09:38 AM   #8
slovak
Member#: 168922
07 STi
Obidissian Black
Originally Posted by flstffxe View Post
Yeah, blows me away, now I there was DIY cam holder..........
Old 08-17-2011, 01:43 AM   #9
subyfreak619
Member#: 233092
1996 legacy wagon
5mt tein coilovers
How bout a big screw driver in the flywheel teeth via the access cover under the TB.
subyfreak619 is offline   Reply With Quote
Old 08-17-2011, 12:17 PM   #10
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Grimmspeed makes a very nice puller
PARANOID56 is offline   Reply With Quote
Old 04-25-2012, 11:12 PM   #11
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
I used a pry bar and stuck it in between the flywheel and one of the clutch bolt didn't wanna break any teeth on the flywheel. Then I had a friend turn the crank bolt with a rachet. Easy enuff for me.......
NutWagon is offline   Reply With Quote
Old 04-26-2012, 06:26 AM   #12
Travisty
Member#: 241216
1995 LX Wagon
2013 SWP BRZ
I really doubt that you'd snap the teeth on the flywheel... That's how I've removed and installed all of my flywheel bolts, and I've never even bent a screwdriver. I normally engage both holes and teeth on both sides though, that way there's less stress on just one point.
Travisty is offline   Reply With Quote
Old 04-29-2012, 10:35 PM   #13
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
long breaker bar resting on the driver side frame, then as you watch have someone try to crank it over once or twice (have the fuel pump disconnected or somethin similar in order to keep the car from actually firing.) a bump or two from the engine is enough to get it loose enough to do it by hand.
dirtbikeridr12 is offline   Reply With Quote
Old 04-29-2012, 10:35 PM   #14
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
double post.
Cheap alignment tool here makofoto Brakes, Steering & Suspension 5 11-23-2004 01:24 AM
Cheap Scan Tool. subiekid General Community 8 10-15-2004 02:14 PM
cheap air tools phillywrx Service & Maintenance 4 11-14-2002 09:09 PM
Anyone know where I can get a cheap OBDII tool? Big_Hitter Texas Impreza Club Forum -- TXIC 5 06-17-2002 01:08 PM
ARGH! Crank tool to close roof? dada21 Mid West Subaru Owners Club Forum -- MWSOC 4 12-26-2000 05:14 AM
