Old 04-26-2012, 12:12 AM   #1
ToyotaMike
Member#: 286007
2007 WRX TR STI Swap
OBP 399.9 WHP E85 PAS/CTC
Default 07 WRX VF39 350/416 E85 Tune by Dave Brown @ PAS
Event: dyno pull/Tune for newly installed ID 1000s, JDM TGVs, Tial 38mm External gate and P&L up pipe
Location: No Limit Motorsports (Medford, Long Island NY)
Ambient Temp: 57*
Elevation: 89 feet
Weather: partially cloudy
Tires: 235 40 18s
Car: 2007 WRX TR
Tuner: Dave Brown of MSPT/Performance Auto Solutions
Dyno Info: Dyno Dynamics AWD Dyno
Transmission: 5 Speed
Gear: 3rd gear pull
Peak HP at RPM: 350 WHP @ 5000rpms
Peak Torque at RPM: 416 3500 RPMS
Baseline hp/tq for a stock on same dyno: 160?
Target Boost: 19.6
Fuel: E85
Engine/Power Modifications: AEM intake, VF39, STI TMIC, Perrin Turbo inlet, Grimmspeed EBCS, Bell mouth catless 3" DP, Apexi 3" stealth exhaust, ID1000cc, Tial 38mm, P&L up pipe, JDM TGVs
Driveline Modifications:
N/A
Suspension Modifications: Tein H-techs lowering springs
Other Modifications: Kartboy short throw shifter and bushings, Kartboy engine Pitch mount, Omori boost gauge, pro sport gauges, SPT trans mount
The proof
the graph
YUP
Thanks for looking
-Mike
ToyotaMike is offline   Reply With Quote
Old 04-26-2012, 12:47 AM   #2
strange_magic
Member#: 259257
Nice!
strange_magic is offline   Reply With Quote
Old 04-26-2012, 01:54 AM   #3
rymaggi
Member#: 253442
Stock tranny?
rymaggi is offline   Reply With Quote
Old 04-26-2012, 02:09 AM   #4
rexblake
Member#: 178426
2010 S4
Gray
So your saying you gained 200whp with 5psi? That's pretty thick... You def should find out what a stock 05sti did on the dyno with the same correction factor you used.
Old 04-26-2012, 02:15 AM   #5
subi_owna2.5rs
Member#: 182178
2006 Wrx sti
Sgm!
+5psi from stock,e85 and all supporting mods. nice job dave, ill be by friday for my retune. enjoy the car man
subi_owna2.5rs is offline   Reply With Quote
Old 04-26-2012, 07:42 AM   #6
ToyotaMike
Member#: 286007
Originally Posted by rymaggi View Post
Stock tranny?
Yes, I don't beat the snot out of the car...no flat foot shifting or launching and stock clutch so it has been fine so far.
My car is an 07. I found some time back that a stock 07 ran on this dyno made 160 give or take...that is what I based it off. The car made 290/350 last sept with above mods on 93 minus the gate, TGVs, and injectors.
Thanks and good luck with your tune.
-Mike
Old 04-26-2012, 11:39 AM   #7
rymaggi
Member#: 253442
-Mike
How does it pull. How Much do you think you've shortened the motor and tranny life?
Old 04-26-2012, 11:41 AM   #8
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Ehh I think the dyno is tuned more than the car..
codesoccer is offline   Reply With Quote
Old 04-26-2012, 12:04 PM   #9
rymaggi
Member#: 253442
Seems right to me. I'm stg2 235whp 280wtq. Then add his vf39 280/310. Then add the e85 and other mods. It's not far off...
Old 04-26-2012, 12:23 PM   #10
ToyotaMike
Member#: 286007
The transmissions in these seem to be hit or miss from what I has read on here and other forums. When I went for a ride with Dave afterwards he did say to be careful with the 5 speed. People said it would break on my last round of mods and it didn't...I personally don't think I will have a problem. A 6 speed swap is my next big upgrade though.
As far as the motor goes, E85 is cooler and safer for the engine. External gate also helps draw the heat out the cylinders faster. I'm not running anymore then 19lbs so I am confident in the tune that the motor will be ok.
You got me I totally photoshopped the graph so I could feel like a boss of bosses on nasioc...SMH haters going to hate...
Thanks dude
Old 04-26-2012, 12:29 PM   #11
codesoccer
Member#: 179573
2002 MBP Bugeye
Ehh I guess I came off kinda harsh. I didn't say you tampered with the graph those just seem a little inflated to me and the injectors seem like overkill for your setup, unless those flow less than 1000cc which I might have read.
Old 04-26-2012, 12:54 PM   #12
burton58
Member#: 115369
2011 WRX.
RIP Bugeye's
All lies, subarus can't make power with e85. Should have bought a jeep haha. Seriously though mike, great numbers. Now hand those keys over to me
burton58 is offline   Reply With Quote
Old 04-26-2012, 01:02 PM   #13
rymaggi
Member#: 253442
How many miles per tank you think your gonna get.
Old 04-26-2012, 01:12 PM   #14
ToyotaMike
Member#: 286007
I, unlike most people do all my own work on my car...I definitely do not want to have to take the manifold off again to change injectors. I asked Dave what he recommended and he said he could do the tune on 850cc but if I ever decided to go up from my vf39 I wouldn't have enough injector for that. So that is why we opted for the ID1000cc
Old 04-26-2012, 01:17 PM   #15
ToyotaMike
Member#: 286007
Lol no jeeps! Solid axle toyotas for life ya heard!
Not sure to be honest with you. I filled it and I am going to run it down and see what numbers I come up with. As of now I'm at 3/4 and have gone roughly 66 miles or so. I am trying to drive it nicely but it's hard because it just wants to go...hearing the external gate open is like music to the ears
Old 04-26-2012, 01:50 PM   #16
rymaggi
Member#: 253442
Haha. For sure. When u use a full tank. Report back!!
Old 04-27-2012, 12:04 AM   #17
rexblake
Member#: 178426
2010 S4
Gray
-Mike
Ah, I'm tracking. I was thinking it was a vf39 both times. A tdo4 at about 160 certainly makes sense. Though I'm still curious what correction factor was used. The dyno dynamics Ive been tuned on hits about 280-300 with a vf39, E and all the goodies uncorrected.
Old 04-27-2012, 12:29 AM   #18
Su||y
Member#: 169794
2007 WRX Wagon
Stage Catless
Numbers sound about right for the mods, these guys don't know what the vf39/2.5 combo is really capable of.... Very similar setup to what I had planned to run, I'm sure you could trap 110mph easily with that setup!
Su||y is offline   Reply With Quote
Old 04-27-2012, 12:31 AM   #19
daseca07
Member#: 277630
2007 WRX TR
good job and impressive numbers
daseca07 is offline   Reply With Quote
Old 04-27-2012, 12:57 AM   #20
rexblake
Member#: 178426
2010 S4
Gray
Lol that's what I'm saying. 110mph trap is good for about 300whp (3200lb car, 200lb driver). 350whp should be good for about 115mph trap speed (same weight).
Old 04-27-2012, 08:07 AM   #21
ToyotaMike
Member#: 286007
My 1st time ever at the track, this past Evo vs STI day, I went 13.4 @ 102. I left off of a 4800 2 step and basically side stepped the clutch...had to redeem myself after stalling at the line on my 1st pass haha. I am sure now with my n00b as behind the wheel I could definitely break into the 12s. However I don't think I'll be hitting the track again until I obtain a 6 speed.
Old 04-28-2012, 03:08 PM   #22
Clark Turner
Member#: 178047
02 WRX STI Spec C
Good job Mike and the crew at PAS and NL
Old 04-30-2012, 01:15 PM   #23
ToyotaMike
Member#: 286007
Thanks Clark.
Ran 1 tank down and filled I just missed 16mpg...15.8. Prior to E85 I was getting 21 and that's with a mix of driving and the occasional full boost
Old 04-30-2012, 01:36 PM   #24
Clark Turner
Member#: 178047
02 WRX STI Spec C
Thats not to bad Mike!
Old 05-02-2012, 12:24 AM   #25
ToyotaMike
Member#: 286007
Certainly isn't! I went and saw Dave today to drop the head lights off for my mom's scoob he asked what I got for fuel mileage. He said that seemed pretty good! I topped off on the way home, the gauge was reading somewhere between 1/4 and a 1/2 and the numbers were 16.8. Its really not to bad, plus the smile factor obtained from having that much more power kinda makes it all worth it Now if this money tree I planted would grow and shed off roughly 4k I would slap the STI trans in. Then I could really enjoy all that it has to offer
07 STi 3071 423awhp/430awtq on e85 Tuned by ATS Applied Tuning Proven Power Bragging 60 06-30-2012 04:35 PM
07 WRX OG Green on E85 goes to the 1/8th track 7.37 @ 95.2 mph. Phatbotti TKR tuned juanmedina Proven Power Bragging 51 04-17-2011 04:01 PM
Who Needs An STI When You Have A USDM EJ205 Tuned By Dave Brown And Clark Turner!! Cards2323 Proven Power Bragging 81 05-13-2010 11:40 PM
07 WRX VF39 Tuned By EQ Tuning Boost_Creepin Proven Power Bragging 24 03-10-2009 01:55 PM
07 WRX VF39 tuned by Hill at Agile ray101381 Proven Power Bragging 47 04-02-2008 09:31 AM
