Old 04-26-2012, 07:32 AM   #1
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Default 05 vf34 Wrx hybrid 1/4 mile
Some friends and I went to Cecil county drag strip last night. Only got two passes in. this the first time I have been to the track with the new setup.
Event: quarter mile
Ambient Temp: 50 degrees Fahrenheit
Elevation: at sea level
Weather: 50degrees and clear (night time)
Track and Conditions: asphalt/concrete
Tires: Nitto Neo Gen 225-45-17
Car: 2005 wrx
Tuner: jermaine @ TXS
Dyno Info: dyna pack
Transmission: 5spd stock gearset
Gear: 4th
Peak HP at RPM: 318whp
Peak Torque at RPM:353wtq
Baseline hp/tq for a stock on same dyno: n/a
Target Boost: 21psi
Target AFR: 11.2
Fuel: 93oct
Engine/Power Modifications:Brand new Sti short block, Wiseco pistons (99.5mm), stock 2.0 heads, vf34 turbo, 565cc injectors, walbro 255 fp, Perrin turbo inlet, Turbo XS fmic, invidia bellmouth dp-catless, invidia n1 street catback, gt-spec EL header, killer-B utlimate oil pickup, sti oil pan, sti dip sti, sti baffle, IAG 38mm ewg, TurboXS shorty intake, halman mbcs
Modifications: stock trans with NEW stock clutch/flywheel
Suspension Modifications: BC coilovers, cobb front sway, kartboy front and rear endlinks, whiteline front shifter stay bushings, whiteline rear diff lock down kit, kartboy front and rear shifter bushings, torque solutions motor mounts, torque solutions pitch stop mount, groupe n trans mount, kartboy short shifter, spt short shifter linkage
Other Modifications: spare tire removed
Car 630
First pass
Second pass, a little better
shadowmd is offline   Reply With Quote
Old 04-26-2012, 09:53 AM   #2
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Thats impressive for rolling off of the starting line with a vf series turbo.
2gnt2wrx is offline   Reply With Quote
Old 04-26-2012, 10:25 AM   #3
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Thanks. It's a ton of fun to drive. The power hits pretty hard and fast for what it os
Old 04-26-2012, 10:26 AM   #4
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
I have a vid on Facebook. I'm going to try and get it on here
Old 04-26-2012, 11:47 AM   #5
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Nice runs, did I read that Cecil got repaved? If so, how is it? How is the starting line now?
He has a 1.825 and a 1.7 flat, not exactly rolling off the line.
OppositeLock is offline   Reply With Quote
Old 04-26-2012, 12:03 PM   #6
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Vid of 2nd run added to first post
Old 04-26-2012, 01:23 PM   #7
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Cecil did get redone and I think it's pretty sweet. It's concrete up til the 1/8
Old 04-26-2012, 09:31 PM   #8
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
It's been a long day... lol for whatever reason during the 5minute break I took today, I thought it said 2.7.... Still very impressive for a vf on 93.
Any more info on your hybrid? who built it?
Old 04-26-2012, 10:15 PM   #9
josedwrx
Member#: 199988
2002 wrb bugeye
vf39 12.3 @113
Very nice times and 60ft, wish i could cut a 1.7 lol
What clutch are you running?
josedwrx is offline   Reply With Quote
Old 04-26-2012, 10:38 PM   #10
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
new stock clutch on the stock 5spd. and thanks. i kno if i would of got one more pass in, i could hit 1.6xx 60' lol
i did all the work to my car minus the engine assembly/install. andrewtech did it and it runs amazing. it was tuned by jermaine over at txs
Old 04-27-2012, 12:27 AM   #11
i_adz
Member#: 281829
04 wrx
02 ts DD
wow thats very impressive... nice launch too
i_adz is offline   Reply With Quote
Old 04-27-2012, 08:16 AM   #12
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Thanks man
Old 04-29-2012, 11:15 PM   #13
WOTisfreedom
Member#: 192212
2004 S203ish WRX
Smurf'd OUT
Amazing times , that's what I'm shooting for!! Gotta luv those extra liters!
WOTisfreedom is offline   Reply With Quote
Old 04-30-2012, 07:27 AM   #14
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
thanks. i was super happy with the last pass. i wanted to get one more in, but i didn't want to push my luck lol
Old 05-02-2012, 10:36 PM   #15
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
even with the stock 2.0 heads, the 2.5 bottom end is such an improvement over the 2.0.
Old 05-05-2012, 12:24 AM   #16
Dat8687
Member#: 243261
2004 WRX
Java black pearl
how the hell did you run faster with a way slower 60 foot
Dat8687 is offline   Reply With Quote
Old 05-05-2012, 07:41 AM   #17
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
with a better 60' i suppose there is less track to get up to speed? i was a lil confused myself lol because it's almost a 3mph difference which is a decent amount
Old 05-07-2012, 05:48 PM   #18
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Looks like you have most/all the info in your 1st post. When you have a few minutes it would be appreciated if you could update the 1st post to the required PPB format found here. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 05-08-2012, 12:16 AM   #19
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
thanks for the heads up. thread was updated
Old 05-08-2012, 06:38 AM   #20
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
nice runs. good driving and E85 oughta put you close to the 11s.
99STM is offline   Reply With Quote
Old 05-08-2012, 07:24 AM   #21
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
thanks man, i just have no idea of anyone close to me that sells e85 :-/
Old 05-08-2012, 06:32 PM   #22
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Is there anyone local to you that sells Sunoco race gases? If so, they should be able to get you Sunoco E85.
Md05STI is offline   Reply With Quote
Old 05-08-2012, 11:42 PM   #23
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
i think there is a shop close to me that sells sunoco 98oct. not sure if they are still there. i'll have to check
Old 05-10-2012, 10:58 AM   #24
prashanth
Member#: 123534
2012 Evo X MR
Grey
Sunoco in loch raven blvd in Towson sells 100 oct gas. I have used it couple of times for autox to prevent detonation.
prashanth is offline   Reply With Quote
Old 05-10-2012, 10:47 PM   #25
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
yeah that's the one i was thinking of
05 stage 2 lgt 1/4 mile times AWDxBOOST Legacy Forum 11 11-04-2005 06:56 PM
05 STI w/SZ49 1/4 mile times Md05STI Proven Power Bragging 47 11-04-2005 09:40 AM
2.5 hybrid 1/4 mile post mikeG8U Proven Power Bragging 15 09-07-2005 06:06 PM
Porsche Turbo beat by WRX in 1/4 mile - Import nationals alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 50 09-25-2001 08:12 PM
Auto Tranny WRX wagon 1/4 mile results Willman67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-19-2001 10:30 AM
