Old 04-18-2012, 08:01 AM   #51
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Well I seem to have found a picture I made in the past with the TESTPADS highlighted. I hope it can help you out as I believe the 06 and 07 ECUs are the same.
2006 WRX ECU:
Cheers,
Jasper.
jkopinga is offline   Reply With Quote
Old 04-18-2012, 08:04 AM   #52
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Regarding the voltage of the Watchdog......
If you only have a Multimeter at your disposal you can try to measure the voltage and you should see roughly 2.5V since the dutycycle is close to 50% which means the signal is LOW and HIGH the same amount of time.
Most Multimeters are RMS meters which means they will show the average which in this case should be roughly half which is 2.5 Volts. It's not a nice approach but at least it gives you a clue of what might be wrong.
Cheers,
Jasper.
Old 04-18-2012, 08:06 AM   #53
toxin
Member#: 51259
2007 WRX
СGM
Cheers,
Jasper.
Jasper,
Thank you,
Yes the testpads are the same in 07 and 06 ECUs.
However, I still not succeeded in the ECU recovery, and trying to figure out where's the catch.
Do I still need to tie the C446 capacitor to the ground wire as shown at your picture?
Cheers,
Jasper.
The multimeter reads roughly +5V at the WDT pin
Thanks,
Anton.
toxin is offline   Reply With Quote
Old 04-18-2012, 08:15 AM   #54
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
If the Multimeter reads +5V that is WRONG!
The signal is 50% Dutycycle changing from +5V to 0V. Any RMS multimeter should show a lower value. If you say the voltage reads 5V I suspect your WDT signal is continuously high. Perhaps some problems with the way you connected the RC circuit to the 555 Timer?
Cheers,
Jasper.
Old 04-18-2012, 08:52 AM   #55
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Have you tried using ECUFlash which has the SHBoot recovery function as well? It would be good to give it a try and make sure it's not a software related issue. It works a charm for me and I suspect others that use the Renesas SH7058 MCUs but might not work for the older '04 SH7055 MCUs although I cannot confirm that.
Cheers,
Jasper.
Old 04-18-2012, 01:20 PM   #56
Noah
Kim Jong Hung
Member#: 111510
05 WRX
If your WDT output is 5 Volts DC, your timer isn't timing at all. Sounds like your output line is tied to your 5 volt supply. If the timer was operating correctly the output voltage will be around 2.2 to 2.5 volts whether you measure it as DC or AC voltage on your multimeter. If you reversed the order of resistors R1 and R2 on the timer circuit, your output frequency will change to around 290Hz instead of 150Hz, but your output voltage should stay close to the same. It seems that your connections to the ECU are correct based on Jasper's picture, so I think something is wrong with your timer circuit.
Noah is offline   Reply With Quote
Old 04-18-2012, 04:03 PM   #57
Dyno503
Member#: 314017
I went crosseyed reading all this.
Dyno503 is offline   Reply With Quote
Old 04-19-2012, 12:29 PM   #58
toxin
Member#: 51259
2007 WRX
СGM
jkopinga, Noah,
Guys, thanks for your input. There was a short circuit on the board. I'll re-do all connections this weekend and tell you what'll happen.
and, BTW, will this SHBootmode work for 16-bit ECU? ('03 WRX)
Thanks,
Anton
Old 04-19-2012, 12:31 PM   #59
Noah
Kim Jong Hung
Member#: 111510
05 WRX
The 16-bit ECU uses a different microcontroller made by Motorola, so this method won't work for the 32-bit ECU which uses a Renesas(Hitachi) microcontroller.
Old 04-21-2012, 12:05 PM   #60
toxin
Member#: 51259
2007 WRX
СGM
Well guys...
I can't thank you enough...
My ECU got unbricked and I just drove my subie around.
Just a couple of pics of the SHboot mode board:
And, BTW, Ecuflash worked like a charm for me.
Thanks again everyone! Damn, I love Subie community!!!
Old 04-21-2012, 01:26 PM   #61
Noah
Kim Jong Hung
Member#: 111510
05 WRX
Glad to see you got it to work finally!
Old 04-28-2012, 08:01 AM   #62
fluke177
Member#: 318394
Hello everybody
I am try to unbrick my 07 EDM FXT. ECU number was 22611AM240
It took some time but have not succeeded yet.
timer is going 150Hz measure by fluke177
USB dongle is well in WIN XP and WIN7
But FDT shows as below
Could someone can tell me witch step that I am going wrong?
Thank you !
Fluke
fluke177 is offline   Reply With Quote
Old 04-28-2012, 12:05 PM   #63
Noah
Kim Jong Hung
Member#: 111510
05 WRX
That seems pretty strange, as the 7058 chip uses Protocol C or so it says when you set it to flash to a 7058. Since it seems you are having a problem getting the initial connection to the ECU I would try swapping your TX and RX lines and see if that changes anything. first.
Alternately you could try using ECUflash recovery mode.
Old 04-28-2012, 05:50 PM   #64
fluke177
Member#: 318394
Hi Noah,
I used ECUflash, But it not work.
How to supply 12V to ECU?
I connect 12V B135 .5,6,19 & B136 .7 &B137. 15
GND B135 .1,3 & B137 .12
Does any pin I missed?
Fluke
Old 04-28-2012, 06:14 PM   #65
Noah
Kim Jong Hung
Member#: 111510
05 WRX
I don't have the wiring pinouts for your specific ECU.
+12V should go to Control Unit power supply, Backup Unit power supply and Ignition switch.
Ground should go to GND Power supply and I think GND Control systems.
Old 05-01-2012, 06:44 AM   #66
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Dude,
You got your connections all wrong.
THE BEST advice I will give you and others is the following:
- Do the recovery INSIDE the car. That way you never need to think about which connections you should make, etc. ALL the wiring is there
- Make sure you take the ECU circuit board out of it's case and solder the recovery board to the ECU. Plug everything as it should making sure you blank the board, etc. if necessary with insulating paper, carton, etc. to prevent it touching other stuff.
- Do the recovery and call it a day.
In case you DO want to do it on the bench. Try this:
12V Power Feed:
B135 pin# 19 Ignition Switch
B135 pin# 5 Backup Power Supply
B134 pin# 7 Control Power Supply
B135 pin# 2 Control Power Supply
B135 pin# 12 Main Switch
GND:
B134 pin# 5
B137 pin# 1
B137 pin# 2
B137 pin# 3
Cheers,
Jasper.
Old 05-11-2012, 04:46 AM   #67
fluke177
Member#: 318394
Hi Jasper,
I had connect as you said, But it still no work.
Maybe I should try it on car.
Does any setting with USB dongle?
I am suspect it.
Old 06-09-2012, 01:10 PM   #68
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Worked Great for me got an 04STI ecu back up and running. Just as a point you can use different Resistors and Capacitors just use the calculator at the following web page to get the correct Hz output.
http://freespace.virgin.net/matt.wai...y/pinouts/555/
Bamofo is online now   Reply With Quote
Old 06-25-2012, 06:50 PM   #69
Hagen5244
Member#: 284174
Anyone done this on an 08+? I dont see the c446 cap, with only the p4xx pads connected I get a success full flash from recovery in ecu flash, but the car will not start, the dccd and s drive stuff is flashing on the dash and I can not communicate with the ecu using obd2 port. Any help would be great.
Hagen5244 is offline   Reply With Quote
Old 06-25-2012, 08:19 PM   #70
izergfx
Member#: 308012
C# & Java Devs***
PM me***
Give the Renesas tool a shot, it might throw the error that is occurring.
izergfx is offline   Reply With Quote
Old 06-25-2012, 09:10 PM   #71
Hagen5244
Member#: 284174
Renesas tool wont even start writing, it gives a check sum error, error 16170 if i remember correctly. again any and all help is appreciated thank so much
Old 06-25-2012, 09:35 PM   #72
izergfx
Member#: 308012
C# & Java Devs***
PM me***
Post a full log from the renesas tool, and a picture of the wiring.
It also might be worth trying with a bone stock, freshly downloaded rom. It's possible that the one you are flashing is corrupted if it throws a checksum error.
Old 06-25-2012, 10:42 PM   #73
Hagen5244
Member#: 284174
Everything is unhooked and put away now, and I don't have a log from eirlier, but. I have tried 2 stock roms for the 08/09 sti and one tuned rom from an 08/09 rom. All with the same error or in ecuflash the same success, but then when the key is on the car acts like there is no ecu connected, dccd and sdrive amoung other lights flashing. Thanks again
Old 08-05-2012, 06:45 AM   #74
norbs
Member#: 135787
Great thread guys.
Just one question.
Is it necessary to earth C446??? If so, does someone have a clear/zoomed picture of how that is done?
Cheers.
norbs is offline   Reply With Quote
Old 08-05-2012, 07:32 PM   #75
norbs
Member#: 135787
Anyone?
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How to Make an STI Look Like a Sleeper? FostersAFB General Community 88 10-20-2004 09:29 PM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
Message Board Statistics All times are GMT -4. The time now is 04:13 PM.
