South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-27-2012, 01:27 PM   #1
explosivo
Member#: 175579
2006 WRX TR
Default rattling engine noise
Just noticed on my way to work this morning, a rattling noise, almost like my flywheel is wobbly and grinding up against something. The car does not drive any different, and feels healthy. It's not noticeable at idle, but if I put the car under some load, say 3rd gear at 2500, then hit the gas, I can hear it pretty well. The noise also happens at deceleration, hitting the brakes does nothing, the sound still persists. I also tried cranking my wheels and driving in circles both directions to see if it was something with the steering, but that all worked fine.
When I got to work, I looked in the engine bay, and didn't see anything off hand. I'm going to put it up on the ramps tonight and take a look, but was hoping you guys could give me some places to start. My car has 105k on it now and still has the original clutch, so I'm pretty easy on the car, but maybe the throwout bearing is dead or something else in the tranny?
explosivo is offline   Reply With Quote
Old 04-27-2012, 01:34 PM   #2
Hah72215
Member#: 77815
2002 WRX WAGON
Maybe check for a broken crank pulley ot loose pulley? Just had that happen in my brother's Infiniti G20. Awful rattling. And the rubber ring on the pulley wore out and was rattling.
Hah72215 is offline   Reply With Quote
Old 04-27-2012, 07:10 PM   #3
explosivo
Member#: 175579
2006 WRX TR
I'll check those tonight. I'd like to get the car in somewhere tomorrow if I can't figure it out, called subaru superstore but they are booked tomorrow, anyone got any suggestions on where I could get it looked at if I can't figure it out? I don't want to drive all the way to goodspeed, so any other good shops that have good mechanics will do.
Old 04-27-2012, 08:24 PM   #4
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
Could it be detonation?
FastS2k is offline   Reply With Quote
Old 04-27-2012, 08:45 PM   #5
yman
Member#: 199051
04 sti
psm
check your axles, I thought I had a bad clutch and it turned out to be an axle. could have a torn boot and its just running dry in there.
yman is offline   Reply With Quote
Old 04-27-2012, 10:25 PM   #6
explosivo
Member#: 175579
2006 WRX TR
definitely not detonation. seems to only happen when the car is rolling in or out of gear. Ill check the boots
Old 04-28-2012, 11:28 AM   #7
explosivo
Member#: 175579
2006 WRX TR
You called it yman, drivers side torn inner cv boot. looks like everyone suggests just replacing the axle. calling around for pricing now unless its uber easy to replace an axle?
Old 04-28-2012, 12:04 PM   #8
Z_A_D_E
Member#: 243185
You should let me know what kind of pricing you find because I had the same issue and thanks to yman again, I found my inner boot torn also... Passenger side though.
Z_A_D_E is offline   Reply With Quote
Old 04-28-2012, 12:17 PM   #9
yman
Member#: 199051
04 sti
psm
You can replace it yourself, but shops usually only charge an hour of labor for them since they are fairly easy to replace if you have the tools.
Old 04-28-2012, 02:04 PM   #10
explosivo
Member#: 175579
2006 WRX TR
Subaru wants to charge 385.00 and will give a 45 dollar core charge if the axle is rebuildable. Napa wants to change 109 for the axle, and rougly 202 +tax for the replacement. Autozone charges 69.00 for the axle, but the Subaru guy at the dealership told me not to use anything other then a genuine subaru axle, so still shopping around.
Old 04-28-2012, 05:22 PM   #11
FastS2k
Member#: 59577
04 fxt notansti
Phoenix rack and axle can probably rebuild it, give them a call:
(602) 252-8255
Old 04-28-2012, 05:23 PM   #12
yman
Member#: 199051
04 sti
psm
I would personally do the autozone or napa one and just replace it myself.
http://www.scoobymods.com/showthread...ent-11665.html
Old 04-28-2012, 06:27 PM   #13
explosivo
Member#: 175579
2006 WRX TR
I ended up going to the Subaru Superstore in Chandler since they could get me in today, spoke with the service manager Gil and he gave me a discount. In the end I ended up paying 302 out the door and they had me in and out in a little over an hour.
I drove the car home and the majority of the noise is gone, although I still hear a rattling... ugh. I can reproduce the noise now when the car is in neutral and I rev up the engine, so I'm still thinking something in the tranny. Going to climb back underneath tonight and do another inspection =(
Old 04-28-2012, 09:46 PM   #14
explosivo
Member#: 175579
2006 WRX TR
Found a loose front o2 sensor bracket, got it all tightened up, but still no love, still get the whining from somewhere. Doesn't sound like it is any of the belts. What all is being rev'd when the car's in neutral that could be making the noise, pulleys and something in the tranny right?
Old 04-28-2012, 09:58 PM   #15
fbjr2003
Member#: 258846
2011 Impreza WRX
Blue Pearl
Sounds like fly wheel like you said earlier or clutch. 105k seems like a lot for stock clutch for me. But that wouldnt happen if you were in neutral. I had a friend bust one bolt on his fly wheel in his srt4 and that caused some rattling I believe. Tough to say man.
fbjr2003 is offline   Reply With Quote
Old 04-28-2012, 10:17 PM   #16
explosivo
Member#: 175579
2006 WRX TR
yeah, having a hard time diagnosing. I think I'm going to rip all the belts out tomorrow just to verify its not any of the pulleys in the engine bay. If it's not a pully, should I just take this back down to the dealership and have them diagnose, or does anyone know somewhere with a scooby mechanic that knows their stuff?
Old 04-29-2012, 12:34 AM   #17
TwinscrollGT35R
Member#: 256810
Have you checked your Radio?
TwinscrollGT35R is offline   Reply With Quote
Old 04-29-2012, 06:42 PM   #18
explosivo
Member#: 175579
2006 WRX TR
definitely not coming from the radio, I probably shouldn't have said whining above, its more of a rattle or a clank. I'm thinking that it's either a timing belt tensioner, or something in the tranny. Going to take it down tomorrow and have the dealership diagnose.
Old 04-29-2012, 07:13 PM   #19
TwinscrollGT35R
Member#: 256810
No my point is if the radio works. Turn it up a tad bit more. If you start chasing sounds. Your going to be locked up in a white padded room.
Old 04-29-2012, 08:49 PM   #20
05bluesti
Member#: 251804
05 WRB STi
In many ways twinscroll is right, if you chase every noise the car makes you will go crazy, cant hurt to check tho, probably a stupid question, but could it be an interior piece rattling, ive **** bricks a few times thinking my car was making nasty sounds only to find it was a stupid interior panel
05bluesti is offline   Reply With Quote
Old 04-30-2012, 12:13 AM   #21
explosivo
Member#: 175579
2006 WRX TR
Definetly something mechanical though, sounds serious or I probably wouldn't care so much, I'll post more after its diagnosed
Old 04-30-2012, 01:01 AM   #22
05bluesti
Member#: 251804
05 WRB STi
Could you get video with noise so we can hear it?
Old 04-30-2012, 02:21 PM   #23
explosivo
Member#: 175579
2006 WRX TR
Tried, but the exhaust and the wind drown out the sound.
Old 05-01-2012, 12:22 AM   #24
explosivo
Member#: 175579
2006 WRX TR
I got a video of the noise, listen right at 5 seconds when I start to decelerate, you can hear the rattling. The noise only happens after the engine is warm.
http://youtu.be/rqUQT-tEOmg
Old 05-01-2012, 07:47 AM   #25
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Check the heat shield on the up pipe. It is extremely common to have them break and rattle. They are only held on by a couple of spot welds and when they crack, the shield will move around a bit and rattle. There are a ton of threads on it.
Any rattles or noises in the interior? jimtweet Interior & Exterior Modification 50 04-15-2008 08:02 AM
Strange rattling/clicking noise comign from engine bay... Yes Its Nate South West Impreza Club Forum -- SWIC 5 02-22-2008 10:09 PM
Rattles, road noise, and other strange noises [email protected] Car Audio, Video & Security 1 11-15-2001 09:01 AM
Ground Control Rattle/Banging/Noise problem! HELP Corey Technical Forum Archive 9 05-26-2000 11:41 AM
