Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 04-28-2012, 10:40 AM   #26
sureshot007
Member#: 142405
#716 G2 OBS
I have to assume everyone is talking about national events, so what about the stock street tire class? I think it would be competitive, especially if its wet at all.
sureshot007 is offline   Reply With Quote
Old 04-28-2012, 05:09 PM   #27
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
To be honest, I think it'd be a blast in RTA with the GS pax. Put a big rear bar on it (and make sure you get one of the 2000-2001 models with the viscous rear diff), set of koni yellows for some shock stiffening and some 225/45/16's. Done. Fun DD and fun RTA setup. Wouldn't even really need to be raining IMO.
subydude is online now   Reply With Quote
Old 05-01-2012, 04:03 PM   #28
Dark_Helmet
Member#: 148563
I've got an 01 with 160,000 miles. I'm willing to bet the rear diff isn't so viscous anymore. :P
Dark_Helmet is offline   Reply With Quote
Old 05-01-2012, 11:18 PM   #29
subydude
Member#: 80649
Even if it isn't, it's still better than open
Old 05-03-2012, 09:45 PM   #30
russubaru
Member#: 306295
2006 WRX STi
In my opinon, no, but if you spend a lot of money in Street Mod it could be awesome.
russubaru is offline   Reply With Quote
Old 05-03-2012, 11:49 PM   #31
Lrn2Corner
Member#: 246224
2012 WRX Sedan
12 Rav4 V6
Originally Posted by Mavrik View Post
Been running my 1999 2.5RS in STC class. it fights off turbo WRX and modified SM class vehicles with ease.
Why not post our last autoX results from the other week? You were insane. It was so awesome watching you mop the floor with most of us last event. Just a proper set up and stock power and you made so many drivers look like they had serious learning to do.
Made my first meet in this car something to remember.
Lrn2Corner is offline   Reply With Quote
Old 05-07-2012, 09:41 PM   #32
madlib
Member#: 16149
2001 impreza 2.5RS
blue
At nationals, I still think it is competitive in DSP if you are just trying to trophy. For overall win...you will need to get extremely lucky. However, you will have to have the car almost fully modded to the rules to fight for trophies.
At Pro solo's, the chances of winning are even better. Usually the BMW's are putting down 2.2 60ft times while I was getting 1.6 60 ft times. But, make sure you have some extra transmissions handy.
madlib is offline   Reply With Quote
Old 09-24-2012, 04:06 PM   #33
Ibrake4scoobs
Member#: 228665
2001 2.5 RS
2010 BMW 135i NTR_S
To bring this thread back from the dead, I have a 2.5 RS with nothing more than a rear bar and some ventus evo's in RTA and it's a blast. Unlike most of the members on NASIOC i havn't owned or driven anything for a long period of time over 300 WHP so I may be a little bias on the fun factor but at the local level, a set of direzza's, AGX's, a set of camber bolts, auto x alignment and a bigger rear sway will be alot of fun and keep you competative in RTA. This also makes for a comfortable ride home after the event, doesn't rape your wallet and requires very little work to go from event ready back to DD or visa versa.
Ibrake4scoobs is offline   Reply With Quote
Old 09-24-2012, 05:58 PM   #34
racerjon1
Member#: 43612
National level, IMO:
GS
This could be interesting, though I drove a stock one the other day in an autocross and I forgot how horribly slow they are. Rear sway bar, RT with PAX... could be interesting.
STC
Too heavy. Good luck with that.
DSP
Nope.. too much development for those BMWs. Knife to a gun fight etc. (Also, now with a rule change it's not the RS that is the best car, it's the L with an RS drivetrain if anything.)
SM
Again, considering the RS is the chassis because drivetrain is open - Nope.
L Chassis? Perhaps but the 2.5 engine hurts when it comes to weight.
2.5 RS N/A - 2550lbs
2.5 turbo - 2,850lbs
Compared to an Evo: 2,640
Maybe somewhere in there is a 2-liter swap into an L Chassis, get it below the 2,640 and ballast up to help with handling, but that's not a 2.5 RS anymore by a long shot.
Prepared, Modified, etc: No benefit to a 2.5 RS shell as a start in those classes.. you're better off selling a 2.5 RS to a Subaru enthusiast and using the $ to put into an L shell.
I am going to enjoy mine going back to nearly stock as a daily/trip light track duty car.
racerjon1 is offline   Reply With Quote
Old 09-25-2012, 11:45 AM   #35
subydude
Member#: 80649
GS
STC
DSP
SM
Just some quick clarification, an AWD 2.5 car in SM would need to weigh 2,970 while a 2.0 AWD car would need to weigh 2,820. Minus 200 lbs if you went to a 275 or less tire and it would be 2,770 and 2,620 respectively.
If you convert to RWD then it's a few hundred less again due to the weight*displacement calculations.
Honestly, with the turbo 2.5 you can do an RS without issue in SM and be very good locally. It just takes a lot of work to do it nationally. And if you had a choice of shells to start with, an L is a better starting point due to the lower weight.
Old 09-25-2012, 02:02 PM   #36
recnelis
Member#: 92778
2000 Impreza 2.5RS
#74 ST - RCE Tarmac 2
Agreed with Jon. GS or RTA are probably the best shot it has at being nationally competitive.
If you just want to have fun, I enjoyed mine in STC trim. The suspension work got it to handle decently, but it was still streetable and I didn't have to change wheels at each event.
recnelis is offline   Reply With Quote
Old 09-25-2012, 03:07 PM   #37
racerjon1
Member#: 43612
Right. But honestly, anything can be made to be competitive locally. (Provided you don't have one of the 5-10 of the top cars in class local to you, and you don't have a pro class for them to run in.)
Right, which is why other than maybe GS or RTA/GS, there is no place for the 2.5 RS in national level autocross anymore.
Old 09-28-2012, 07:08 PM   #38
Storm
Member#: 5218
96L Most Over-
Developed Beater
^truth......
Cut it up, go to F Prepared....have a blast!!!
Jay
Old 09-29-2012, 04:16 PM   #39
silverhks
Member#: 242402
Originally Posted by Storm View Post
^truth......
Jay
Don't forget...
And break stuff
silverhks is offline   Reply With Quote
Old 09-29-2012, 07:45 PM   #40
Storm
Member#: 5218
96L Most Over-
Developed Beater
Breakage happens in every class above stock....or you end up staying painfully slow. The nice thing about prepared is the leeway to overbuild for reliability.
Jay
Old 12-04-2012, 02:30 AM   #41
YarkoSoloSCCA
Member#: 339644
^truth......
Jay
Alright, I've been running a Prepared Cooper S for 3 years. Now I'm in this thread cause I want to run RTA.
I bought completely stock 2000 rs25 coupe with a fresh engine, and extra oem wheels. RTA/GS will be fun ..I'm looking for some setup advice.
As far as running prepared yes its fun but... dedicate a car to only autocross $$$. re-engineer everything to work around 11" wide bias ply tires $$$. Build most things yourself they don't make bolt-ons for prepared. I spent about 200-400hours a year on development. Drive 3 or 4 minutes at an event. learn to drive much faster. My best points so far 935 against national champs. It's been fun. I'll still be doing it.
But I just want to have some fun in a car that I believe is likely to be competitive in RTA(GS PAX)
YarkoSoloSCCA is offline   Reply With Quote
Old 12-04-2012, 09:42 AM   #42
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^At the risk of sounding like a penis....I'd say you were just doing it wrong in prepared.
That may only be because the re-engineering, development, and building aspect is part of the fun (for me). I agree 100% about the low seat time and dedication to one dicipline. I am now beginning to broaden my horizons with changes to allow the car to be used in other venues, such as hill climbs and track duty with a known autocross setup to fall back on when it goes to big events.
Jay
Old 12-06-2012, 12:35 AM   #43
Thorium06
Member#: 254372
HAHA! Yarko is on NASIOC!
My advice.. Talk to Dwight and even drive Dwights car.
Thorium06 is offline   Reply With Quote
Old 12-06-2012, 12:44 AM   #44
99GC
Member#: 199207
1999 impreza
white
i still need coilovers and to decide on tires for next year but i feel i might be able to chase down kinch at least once next season if i can get this done
99GC is offline   Reply With Quote
Old 12-10-2012, 01:47 PM   #45
Ibrake4scoobs
Member#: 228665
2001 2.5 RS
2010 BMW 135i NTR_S
I have very limited experiance with Solo but I really enjoy running the RS in RTA. From what I've seen the newer WRX's are the car to have in this class these days but I'm not sure if any one has tried to make a 10/10th's RT RS yet, so who knows. I've done fairly well locally against several WRX's and with nothing more than some Hankook Ventus v12's, adjustable RSB and an air filter. Due to stock rule set and limited camber, toe and caster adjustments there's not a whole lot to the setup of the car that is legal (that I am aware of). Will be interesting to see how far some one who has alot of seat / development time can take an RS...
Old 02-17-2013, 11:13 PM   #46
YarkoSoloSCCA
Member#: 339644
I'm running in GS.
We have 3 stock RS in GS!
Everyone complains that the RS hits third too often. I figured go ahead and embrace it with shorter tires-- I'm running 215/40/16 v710 there 2" shorter than stock. I give up a little width that I could have in the 245 710, but I gain a lot in gearing, less weight, and the sidewall is square with the wheel so a higher sidewall spring rate, oh and the car is 1" lower. right now 710's are a set of 8year old 1/16" tread test-do-they-fit how's-the-car-like-em's. Will get a new set for March30 Series Kick-off.
There is an a6 in the same height, but Its easier to get the suspension all sorted with the 710's feedback.
I've installed rear AGXs;set at #6 with 36PSI, where I can throttle rotate and cautiously trail-brake.
waiting on some bits for the fronts. My front left strut only has oil on the outside, it claps. the front bobs 4x when you press it down. 41-42 PSI is stable in the front. surprised how well the front tires do on the stock alignment McStrut curve.
I'm looking at 24mm front bar & endlinks. get some weight transferred to the rear, and make those tires do a little more....
Does anyone have advice on which whiteline fits the NA header. I haevn't looked at it yet lifted, only from the side, but If the bracket bush is offset closer to the subframe the striaghter, and therefore stiffer turbo FSB might clear above the header.
Any word on group n mounts being legal for GS Impreza rs. I heard rumors but I can't find any supporting docs.
race pads go on when the chance of snow stops. then some other bits.
Despite dead strut today's non-points event 918Pts.
4 wheel drift for the first time in this car today-- nice neutral controlled feeling -- hmm how to rotate---throttle-- worked very well.
I'll be running GS with this for our local series, 950 points on pax is my goal.
(locally 1000pts = Dorsey [Last year's pro & nats EP champ], Mark Smith [DSP VW Champ] or Thorne STR)
If I do well locally with the RS you will likely see me in it in GS at Nats.
Old 02-18-2013, 07:32 PM   #47
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
The whiteline GC turbo swaybars foul on the stock header. They are supposed to fit with the borla header, but my 22mm whiteline turbo swaybar hit my ebay borla knockoffs.
Suba_Roo is offline   Reply With Quote
Old 02-18-2013, 07:57 PM   #48
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Originally Posted by Robin2 View Post
with the wider tires, you'll certainly have to have stiff enough suspension.
couple of friends have swapped RS... and both are running in 265-45-16 tire 16x9 and 17x9 on 275-40-17
one had V8 jdm sti swap and hybrid 2L/2.5L wrx/sti swap engine.
both are much lighter than any 04+ sti.
Every time I've seen an RS swap that carried the 6 speed over, it wasn't much lighter than a GD. Are these cars still running 5speeds?
Butt Dyno is offline   Reply With Quote
Old 02-18-2013, 08:29 PM   #49
subydude
Member#: 80649
Mine is under 2800 lbs right now with factory front seats and heavy brakes/wheels. It's entirely possible to get a swapped GC (ej257/6speed/brembos/r180) into the mid 2600 range in SM.
Old 02-19-2013, 02:39 AM   #50
YarkoSoloSCCA
Member#: 339644
Originally Posted by Ibrake4scoobs View Post
... running the RS in RTA. From what I've seen the newer WRX's are the car to have in this class these days but I'm not sure if any one has tried to make a 10/10th's RT RS yet, so who knows...
I was initially thinking of RTA, but everything I looked at said the WRX's were killing it. GS Trophies have had pretty low pax points at nats since they Cooper S got bumped out. I think they started around 9300 and 1st was in the 9500. Much easier class to exploit than RTA.
The other big thing is tire height. NA engine need lowest gearing to launch faster. shorter tires take less angular force to rotate, as the tread weight is closer in. shorter tires lower the car for better handling. shortest sidewalls usually have the most feet back and highest spring rate. There's not much in the stock springs, and with deflection in the rubber bushes. I want things as stiff as I can get them.
Hoosier and Kumho both have short 22.6" 215's for GS.
the only shortish ST tire for the 16x7 is the Kumho XS, it behaves but is not considered a responsible tire.
When I was tire shopping, I found 200 tread wear 255/30/16 Kumho's of BFGs with a v-block pattern, but only a pair and old-stock and discontinued. the new Kumho v720s might come in some short sizes--the only size info I've found is a picture of a 255/40/17 in Tokyo. But they should be official in a couple of months. But with the WRX there RTA is not going to be the place for an RS.
I don't know if I'll build a 10/10ths GS RS. Coming from prepared I've got a solid list of my legal GS build, and I'm putting together some site/course condition paddock changeable suspension options.
Are There Any Stainless Resonated Midpipes for the 2.5RS? williaty Normally Aspirated Powertrain 7 07-15-2007 02:23 PM
any place to buy 2.5rs bumpers?(replicas even) Dokturseuss Interior & Exterior Modification 3 01-02-2007 01:05 PM
will the brospeed muffler for the 2.5RS fit the forester? V6 Forester Forum 1 12-11-2001 07:16 AM
Anyone tried the genuine Subaru performance exhaust for the 2.5RS? V6 Normally Aspirated Powertrain 8 10-20-2000 08:38 PM
Borla catback for the 2.5RS...got off the phone with Competition Design Overtime Technical Forum Archive 6 07-23-2000 12:26 AM
