Old 04-08-2012, 02:20 PM   #1
pippen
Member#: 171290
2008 STi
Default Do I need bigger Injectors?
So I'm looking to have Clark Turner tune my car when I get setup here.. Here's what I got:
Grimmspeed EBCS
Walbro 255 Fuel Pump
TBE (Greddy Ti-C Catback / Invidia DP in the mail)
TurboXS CAI
I talked to Clark and he actually recommended a dw65c fuel pump (before I got the walbro) and dw850cc injectors.. It seems like there are a ton of people running on my same setup without bigger injectors and some even without the fuel pump.. So I'm wondering if it's just his method of milking every bit out of the car or if I actually need the injectors at this point? I just don't have the funds right now to go there and pay for a tune on top of that.. Thanks for the help!
pippen is offline   Reply With Quote
Old 04-09-2012, 10:27 AM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
what fuel are you using? E85 or 93/91?
dux10 is offline   Reply With Quote
Old 04-09-2012, 11:51 AM   #3
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
If that's what your tuners recommending for your setup you should probably follow his advice.
In my opinion...... 850s for a stock turbo is fine and gives you room to switch fuels or a differant turbo in the future is you ever decide to do so.
wrxsubiemod is offline   Reply With Quote
Old 04-15-2012, 12:22 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
many cars run on stock injectors and stock fuel pump at stage2.
Your IDC's will be 90-100% depending on the AFR.
a bigger fuel pump will help keep the idc's down IF the idc's are falling off due to the stock pump being done.
the injectors and pump are basically adding ~$600 to the cost of a stage2 car....
Old 04-27-2012, 08:20 PM   #5
DannyW
Member#: 281871
Which size injector do you have now?
DannyW is offline   Reply With Quote
Old 04-27-2012, 08:25 PM   #6
It_wasntt_me
Member#: 300955
2004 WRX
Java Black Pearl
Stock, I'm assuming.
It_wasntt_me is offline   Reply With Quote
Old 04-29-2012, 12:40 AM   #7
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
not necessary for pump gas.
alexmartynyuk is offline   Reply With Quote
2007 STI Stage2 Protune Do I need Bigger Injectors or Fuel Pump? Destroy AccessPort 4 03-17-2008 04:24 AM
Do I need bigger injectors? Silver'04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-10-2007 03:33 PM
How do I control bigger injectors? damonmlime Normally Aspirated with bolt-on Forced Induction Powertrain 1 01-16-2007 11:08 PM
Will I need bigger injectors to run this turbo in my car? eagleschico Tri-State Area Forum 11 12-12-2004 05:14 AM
When do I need bigger injectors, pump, etc. makofoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-15-2004 04:58 PM
