Old 04-29-2012, 08:16 PM   #1
chino_487
Member#: 209156
2009 WRX Sedan
SSM
Default Brake Rotor Groove?
Recently did a Brembo upgrade to my 2009 WRX about 2 months ago. While driving I looked over the driver side window and noticed through the reflection from the car next to me that there a dark circle on my rotor. When I got home I saw that there is a circular groove on the rotor which seems like a scratch on the surface. This is absent on the passenger side. Is this normal? any ideas on what is causing this?
The pictures dont do it justice but they are deeper than they seem.
chino_487 is online now   Reply With Quote
Old 04-29-2012, 08:52 PM   #2
subergoo
Member#: 141237
2003 Impreza WRX
cant we all get along?
how deep are you talkin here? just high grit sand paper rough or can you snag a finger nail on it?
have you inspected the pad?
subergoo is offline   Reply With Quote
Old 04-29-2012, 10:45 PM   #3
chino_487
Member#: 209156
2009 WRX Sedan
SSM
I didnt touch as I had just driven the car but you can actually see the grooves (scratch-like, if you must) if you look closely.
I'll have to inspect the pad soon.
Old 04-30-2012, 01:48 AM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
Could just be a pebble stuck in between the pad and rotor.
Do you notice a squeal?
EdHilario is offline   Reply With Quote
Old 04-30-2012, 04:33 AM   #5
chino_487
Member#: 209156
2009 WRX Sedan
SSM
Yeah. I do at low speed braking (maybe <10 mph).
My question is: will the rotor be ok?
Old 04-30-2012, 01:40 PM   #6
SW21MR2
Member#: 60135
WR Blue
Your rotor will probably be fine. Just find out what's causing the grove and remove it.
SW21MR2 is online now   Reply With Quote
Old 04-30-2012, 07:17 PM   #7
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
Totally normal.
If it bothers you get slotted or drilled rotors to keep the pads cut clean. Or take the wheels and caliper's off and clean them manually all the time.
aberg12012 is offline   Reply With Quote
Old 04-30-2012, 11:38 PM   #8
EdHilario
Member#: 137398
2004 Impreza 2.5RS
The rotors will be happier the sooner you fix the problem. They will be fine. If you're super anal get the fronts turned or replaced if you have the money. Good luck.
FS : Brake rotors, Brake rotors, Brake Rotors! 04 STi generalee69 NWIC Private Classifieds 16 05-11-2012 02:45 PM
Loose front brake rotor. Is the bearing shot? I3E4VEI2 Brakes, Steering & Suspension 13 05-01-2012 11:20 AM
EBC Sport Grooved Brake Rotors D-Speed 2.5 Brakes, Steering & Suspension 2 07-21-2004 03:05 PM
front brake rotors unusual wear/ grooves new_wrx_owner Warranty Issues & SOA Problems 1 10-20-2002 07:08 PM
Grooved brake rotors (stock) pitansk Brakes, Steering & Suspension 21 04-07-2002 11:09 AM
Message Board Statistics All times are GMT -4. The time now is 10:34 AM.
