Old 08-11-2009, 06:46 PM   #1
Roon
Member#: 154494
2007 WRX TR - 18g'd
Default 18g'd 07 WRX
Had it road tuned last night by Bullwinkle.
Mod List -
TD05 18g 7cm
TurboXS TMIC
APS 70mm Intake
DW 750cc Injectors
Grimmspeed Up-pipe
Grimmspeed BCS
Walboro 255
Running 22.5psi and tapering to about 16 at redline. Intake temps were about 85 degree's.
Roon is offline   Reply With Quote
Old 08-11-2009, 07:07 PM   #2
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
what kind of gas are you using? how hot was it when you got tune?, 91 degree
To me it looks like the numbers are too low for the boost you are running, the small housing and 2.5L should net a lot more torque. Some VF39 make 300whp on airboys on 93oct at 17psi.
GL
Old 08-11-2009, 07:10 PM   #3
Roon
Member#: 154494
2007 WRX TR - 18g'd
GL
I was running 93oct and it was something like 85 degrees outside. Well tuned Stage 2 STi's in similar weather using my tuners graph put down 275whp / 290wtq.
Old 08-11-2009, 07:33 PM   #4
treystoys
Member#: 97436
05 WRX/ver8 207/
4.44fd/rotated3076/FJblue
Graph looks nice man...car should be an easy mid 12 110mph car.
treystoys is offline   Reply With Quote
Old 08-11-2009, 10:24 PM   #5
Bullwinkle1983
Member#: 172332
2006 WRX
18g'd and RomRaided
GL
His turbo is fairly heavily ported, so it yielded lower torque numbers but higher HP numbers then I expected. Raw intake temps where between 85-90, as it was around 85-87 degrees outside.
No local VF39's put down 300+ WHP on Airboy's dyno. Those types of numbers are a pipedream, or from logs with 40 degrees or less ambient temperature.
Nasioc power numbers are inflated as all hell, you should know that .
Bullwinkle1983 is offline   Reply With Quote
Old 08-12-2009, 09:31 PM   #6
rsw0124
Member#: 173013
..08 AwwGrr FTW!
370wtq@5000+ft ^sea level
#'s do seem kinda low, but I bet its still fun drive. Have fun with it!
I dropped 286whp(vf39@18psi) and 310whp(hta68@21psi) with my 2.0l.
rsw0124 is offline   Reply With Quote
Old 08-13-2009, 08:09 AM   #7
Roon
Member#: 154494
2007 WRX TR - 18g'd
I am sure Bullwinkle would be happy to inflate them to "normal" Nasioc power numbers .
Old 08-13-2009, 12:17 PM   #8
Trevor723
Member#: 57989
2011 F150 EcoBoost
flame blue
how are the idc? I'm going to run an 18g on my car as well.. not sure if I should get 650s or just step up and get the 750s.
Trevor723 is offline   Reply With Quote
Old 08-13-2009, 12:20 PM   #9
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 12.8@105mph
very nice roon! wish bullwinkle was around me to tune my car...currently i am running one his maps though - thanks buddy!
boostdog is offline   Reply With Quote
Old 08-13-2009, 02:25 PM   #10
jpjester
Member#: 153624
2009 WRX Hatchback
Mica Blue
I put down 311 @ 298 at 22 pounds of boost on my 2004 2.0L running the 18G with 93 Oct. Is that High for a 18G?
My Setup Was:
Deadbolt Zilla 18G Turbo
STi TMIC
SPT Short Ram Intake
Invidia UpPipe
Invidia Catless Bellmouth Downpipe
Invidia G200 Exhaust
Cobb Light Main Pulley
Power Enterprise 650 cc Injectors
NGK Iridieum Spark Plugs
jpjester is offline   Reply With Quote
Old 08-13-2009, 05:35 PM   #11
Bullwinkle1983
Member#: 172332
2006 WRX
18g'd and RomRaided
You bet man.
Originally Posted by jpjester View Post
I put down 311 @ 298 at 22 pounds of boost on my 2004 2.0L running the 18G with 93 Oct. Is that High for a 18G.
No. Like everyone else on NASIOC, please read one of the thousands of rants regarding the differences between dyno numbers.
Old 08-13-2009, 07:56 PM   #12
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Originally Posted by Bullwinkle1983 View Post
You bet man.
you both have 18Gs putting down real numbers . what do this cars run ?
Old 08-13-2009, 10:52 PM   #13
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
I put down 310WHP/349 ft/lbs on an 18g7cm on a 2.5 Liter. 18lbs of boost tapering to 14 at 6300.
mods were:
Ebay TMIC
deadbolt 18g
TBE
91 octane Piss gas
CAMtuning open source tune ;D
IDC's were kind of high at 93% but
Juan I have put down 3 13.2@102 back to back on 3 different nights and I'm cutting 1.73 60". Im also out here with Cam at a mile high and the DA was 8200ft on 2 of the runs and 7300ft on the other. I have only run the car these three times since the tune, i don't need to be replaceing a tranny any time soon I just bought a house. I am poor
hope this helps
*6STARS* is offline   Reply With Quote
Old 08-14-2009, 08:54 AM   #14
Roon
Member#: 154494
2007 WRX TR - 18g'd
No, we both have 18g's putting down real numbers for where we are at. You can't compare what a vf39 puts down in a different part of the country on a different dyno (Even if it is airboy's, things do change as you travel about the country) to what we put down here. Cars running the setup you have here in MN Juan simply dont put down the numbers you are claiming. We just had a vf39'd 07 WRX put down 275whp and 300ish tq on a Mustang.
Old 08-14-2009, 09:25 AM   #15
Dubstar112
Member#: 143149
2006 Evo IX RS
used to be 07 wrx 6speed
qft, any comparison made over the internet is just that... made over the internet. evironmental variables ultimately make the difference. Dyno's only measure the output and using traps is nearly as flawed. NHRA cars have fast tracks and slow tracks.. I am literally on my way to BRAINERD MN now, and I do not expect to see E-town numbers here.
Dubstar112 is offline   Reply With Quote
Old 08-14-2009, 12:28 PM   #16
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
What I trust the numbers to tell me is how much I gain from each phase of modification, within a reasonable range. The same dyno on different days will tell me different numbers, but I can factor a mean, and see the net gain of "x" part(s). Outside of that the numbers don't have much use, and certainly can't be used as the ground on which "bragging" rights stand. I do however like more power, but whether the dyno tells me 350/375, or 290/340 as long as I can turn a better time and feel more connected to the car I am happy.
UFOpilot is offline   Reply With Quote
Old 08-14-2009, 01:31 PM   #17
Dubstar112
Member#: 143149
2006 Evo IX RS
Agreed... its how it feels to you that matters.
Old 04-29-2012, 09:57 PM   #18
sackytar
Member#: 149262
2003 03WRXw6sp/05FXT
Numbers are low!!!!
Old 04-29-2012, 11:04 PM   #19
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
Originally Posted by sackytar
Numbers are low!!!!
Do you realize this thread is almost two years old?
Black07STiGuy is offline   Reply With Quote
FS: NoVA: Samco Radiator Hoses in Black and 4 No Tear Clamps for 02-07 WRX / STi. adjasont Engine/Power/Exhaust 5 11-27-2011 03:06 PM
04-07 WRX stock intake duct feenomenal Private 'Wanted' Classifieds 0 06-04-2010 09:48 AM
07 WRX 18g'd Tuned by 555 Motorsports 07HaWkEyE Proven Power Bragging 31 04-23-2010 12:30 AM
18g'd 2006 wrx (track results) RedRex26 Proven Power Bragging 7 03-07-2010 09:25 PM
Message Board Statistics All times are GMT -4. The time now is 04:54 AM.
