Old 04-12-2009, 05:53 AM   #1
ahhhh
Member#: 207726
Default GC Radiator In a GD?
Anyone know if the GD fans and mounting points would work with a GC radiator? Reason I ask because when one switches to a thicker core the top hose gets closer to the Alt pulley even after trimming it. The GC radiator hose doesn't exit/enter in the middle like the GD does.
Plus it looks alot cleaner!
ahhhh is offline   Reply With Quote
Old 04-14-2009, 05:11 AM   #2
ahhhh
Member#: 207726
to the top!
Old 04-14-2009, 10:02 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
the mounting upper points are different but it's not hard to make two new holes
Hyper is offline   Reply With Quote
Old 06-20-2011, 03:20 PM   #4
mowgli29
Member#: 203438
Bumping for an answer. I've searched and found no conclusive answer. I'm looking to put a GC radiator in my 2002 WRX.
Are the brackets the only thing that will require modification?
Will my stock fans fit?
I know the upper hose is different...but what about the lower hose; can I use the stock lower hose?
mowgli29 is offline   Reply With Quote
Old 06-20-2011, 04:17 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
You could if you wanted to. You'd need to drill new holes in the upper core support, trim the lower hose a bit, use the gc upper brackets, gc upper hose, overflow and fans. Your fan motors and blades would fit actually, but the fan housings are different.
Old 06-20-2011, 05:33 PM   #6
mowgli29
Member#: 203438
Awesome, thanks so much for the info!
Would it be possible to modify my fan housings to fit the new rad? or is it totally necessary to get the GC housings?
I will probably be making my own upper brackets, so I'm not shy of a few modifications to the fan housings.
Old 06-20-2011, 06:42 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Maybe, but they are different.
Old 06-20-2011, 09:33 PM   #8
AKGC8
Member#: 1305
2000 Impreza
I'm still running a GC radiator with my GD into GC swap but have the GD motors and fans swapped into my fan housings like 69subaru360 describes. Fan housing mounting is different. I'm sure somebody could make it work with enough modification, but it was easier for me to just swap the motors since I had all the parts.
AKGC8 is offline   Reply With Quote
Old 06-21-2011, 10:26 AM   #9
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
I have a fuidyne radiator in my GC with stock wrx fans. Trimmed the upper radiator hose and no clearance issues whatsoever.
Eby, This is on your old 94 L. It has treated me well! Still got the 99?
jake
KONKILR is offline   Reply With Quote
Old 06-21-2011, 08:53 PM   #10
AKGC8
Member#: 1305
2000 Impreza
Nice, I was curious what happened to that chassis.
Now I have a 2000 L and did a full 04 STI swap.
Old 06-21-2011, 09:23 PM   #11
KONKILR
Member#: 3190
2004 Impreza TS and
Clear your inbox! It is full.
jake
Old 06-21-2011, 09:42 PM   #12
AKGC8
Member#: 1305
2000 Impreza
Clear
Old 04-29-2012, 11:58 AM   #13
subieguy87
Member#: 153412
1998 Impreza wrxRS
Can anyone help me out?
I'm doing the opposite, using a gd rad in my ej205 swapped gc?
subieguy87 is offline   Reply With Quote
Old 04-29-2012, 05:02 PM   #14
KONKILR
Member#: 3190
2004 Impreza TS and
Thats what I have. A fluidyne and fans meant for a GD. The only thing I did is used the GD upper mounts and drilled new holes in the core support to use them. It was also neccesary to trim the upper and lower radiator hoses to fit.
jake
Old 04-29-2012, 08:23 PM   #15
subieguy87
Member#: 153412
1998 Impreza wrxRS
jake
What did u do besides drilling it out? There's a bolt welded to the btm of the upper mount...
Can u use a bolt after u drill it?
Old 04-29-2012, 09:31 PM   #16
KONKILR
Member#: 3190
2004 Impreza TS and
I put a nut on the bottom of the new holes.
Old 04-29-2012, 10:01 PM   #17
subieguy87
Member#: 153412
1998 Impreza wrxRS
Will a bolt w/ a nut that's not welded on work?
Old 04-30-2012, 12:59 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
yes45
Old 04-30-2012, 02:09 PM   #19
subieguy87
Member#: 153412
1998 Impreza wrxRS
yes45
Gracias
That's wonderfull, my ac is gone, so that'll make it easier
gd radiator in a gc? cavakilla Subaru Conversions 3 04-29-2012 03:08 PM
GC rear seats in a GD? erich Interior & Exterior Modification 6 06-11-2009 06:44 PM
How to: Mishimoto Radiator into a GD STi Mishimoto Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-08-2009 11:06 AM
GC radiator cover in blue or yellow M E R C U R Y Private 'Wanted' Classifieds 8 09-10-2004 11:47 PM
?Mystery u-pipe in front of radiator of LHD GD imprezas? JDM experts... help satrya Newbies & FAQs 1 04-12-2004 10:58 AM
