Old 04-30-2012, 06:56 PM   #26
Jet130
Member#: 314284
Reaches boost very quickly - so that's ruled out....
Jet130 is offline   Reply With Quote
Old 04-30-2012, 07:00 PM   #27
Jet130
Member#: 314284
Runs very strong also. The shop that installed the motor is different from the one that built it. I'm waiting to name them until they refund part of the money, or send me a new block. They do quite a bit of business on Nasioc. So we will see.
Old 04-30-2012, 07:01 PM   #28
Jet130
Member#: 314284
How do you check for Valve lash?
Old 04-30-2012, 07:10 PM   #29
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
You've got to take off the valve covers and stick a feeler gauge in between the lobes and the buckets. Not something I'd want to do with engine in car, but it can be done.
Zackbo is offline   Reply With Quote
Old 04-30-2012, 07:13 PM   #30
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Good choice. I would be hesitant before crucifying anyone. Eating crow is no fun. I've had my share.
Old 04-30-2012, 10:08 PM   #31
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You didnt respond to the tensioner question....
reddevil is offline   Reply With Quote
Old 04-30-2012, 10:43 PM   #32
Spacepope
Member#: 189950
2004 Hybrid Wagon
Prius Power
If they did a hybrid build with a stock head gasket, they failed completely and you need to get a refund and take your money elsewhere. You absolutely need a thicker gasket for that setup.
Spacepope is offline   Reply With Quote
Old 04-30-2012, 10:44 PM   #33
Spacepope
Member#: 189950
2004 Hybrid Wagon
Prius Power
Unless the pistons are cut for it, but, sounding like that, something is really badly screwed in there.
Old 05-01-2012, 01:00 AM   #34
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Listened to it again. sounds external.
I would bet ..... Say $10 its the tensioner. Hey, I am not a rich man.
Old 05-01-2012, 03:09 AM   #35
Jet130
Member#: 314284
Not sure - but I'm leaning towards this being the problem. It's curious because when I get the car up to speed in just about any gear, and leave it at a constant RPM, it get completely quiet! Noticed that today. Also, when idling, when the fan kicks on, it get quieter as well.
Old 05-01-2012, 04:00 AM   #36
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
The load on motor will affect the tension on the timing belt which likely changes the tension/slap on the tensioner.
Drill a hole in the timing belt cover so you can stick a long metal rod onto the tensioner and stick it in your ear and listen. WHACK WHACK WHACK......
Old 05-01-2012, 04:08 AM   #37
jesterjames
Member#: 252663
Chapter/Region: HIIC
I vote tensioner as well... its too clacky sounding and slow to be piston slap IMO
jesterjames is offline   Reply With Quote
Old 05-01-2012, 09:44 AM   #38
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Can you say piston slap....... man it surely sounds like it.
Heard a forged Audi 1.8T gone wrong just a day ago. Almost a 1 to 1 comparo eh.
TBH pistons slap doesn't really mean anything unless oil consumption is getting nasty. Other than that just live with it and boost on!
Cheers,
Jasper.
jkopinga is offline   Reply With Quote
Old 05-10-2012, 12:33 PM   #39
Jet130
Member#: 314284
Noise goes away when decelerating, and after 2.8k RPMS. Stumped.
Old 05-10-2012, 09:37 PM   #40
subi400
Member#: 216984
1996 Impreza outback
Green
Take your timing belt covers off and the crank pulley, then put the crank pulley back on and turn it on and then watch the tensioner to see what it is doing when giving it some throttle. Also, take a mechanics stethoscope to listen to the tensioner while having someone give it some throttle. You will know if it is the tensioner or not pretty quickly....
But, that does really sound like a bad case of piston slap...
subi400 is offline   Reply With Quote
Old 05-11-2012, 01:05 AM   #41
Jirv311
Member#: 273528
2002 Impreza WRX
Not to side track but why do you need a thicker head gasket?
Jirv311 is offline   Reply With Quote
Old 05-11-2012, 06:27 AM   #42
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
If you follow post #40 and it's not that then from the consensus in this thread it's gotta be piston slap.
Like I said in the first reply, I've got a hybrid that sounds very similar and I know its piston slap. Maybe I will post up a vid and you will see....
Run some heavy oil and drive it like you stole it.
Old 05-14-2012, 02:33 PM   #43
Jet130
Member#: 314284
What weight oil is good?
Old 05-14-2012, 07:41 PM   #44
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
If you are in a fairly warm climate I would run RotellaT 15W-40. Your gas mileage will suffer slightly but the extra insurance is worth it.
Old 05-14-2012, 09:43 PM   #45
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
That really sounds like the timing belt tensioner. If its the timing belt tensioner then it should be really really easy to diagnose. Take the radiator out, take the belts off, take the timing belt cover off. Have a friend start the motor up for a few seconds while you watch the tensioner. If the tensioner and belt flop all over the place thats your answer.
dexterous is offline   Reply With Quote
Old 06-04-2012, 10:57 PM   #46
SubieHondaGuy
Member#: 312223
I used a dohc phase one block with sohc heads, used the sohc head gaskets and it sounded just like that.
Installed the dohc gaskets and it went away.
SubieHondaGuy is offline   Reply With Quote
Old 06-08-2012, 01:23 PM   #47
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Holy hell thats not JUST piston slap.... sounds like a few things. Like a major exhaust leak, valve shim clearance is way off, and some piston slap altogether.
Old 06-09-2012, 08:21 PM   #48
danger1138
Member#: 279525
04 rex luger!
^^ not neccessarily if u got your heads machined to match the block. Actually stock gaskets (sti gaskets) can withstand alot..
danger1138 is offline   Reply With Quote
Old 06-09-2012, 09:08 PM   #49
Serkan
Member#: 180514
2004 Sti
Put your hand on the timing belt covers while car is running (watch for the belts)
If the covers are shaking it is a big chance your tensioner is bad. That is how I diagnosed mine.
Better way to make sure is to take the center and driverside covers off and check the tensioner visually while car is running. It is doable without taking the radiator off.
Serkan is offline   Reply With Quote
Old 06-09-2012, 09:42 PM   #50
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
Are you still driving the car?
iconone is offline   Reply With Quote
Engine knocking sound [video] newera Service & Maintenance 2 03-20-2012 11:00 PM
strange knocking/ticking behind glovebox smidge112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-17-2012 12:10 PM
Knocking/Ticking sound *video* Shinallsm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-27-2009 05:44 PM
piston slap? tensioner? knock/tick sound smurfwrx Service & Maintenance 14 10-19-2007 07:47 AM
Odd knocking/ticking sound? Deeman81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-23-2003 08:20 PM
