Old 04-29-2012, 09:24 PM   #1
MrMikeK
Member#: 266965
2006 STi
AW
Default serious electrical problem
Hey guys,
About two weeks ago I got in my car and put the key in the ignition. When I turned it I lost all electrical power. I went and wiggled the battery around and the power came back. The car started after a few turns of the key. When it idled the rpms were really low, bouncing off what looked like 250 rpms.
This happened 3 times since. Earlier tonight while driving, my headlights and everything in the cabin but my gauges lost power. This happened twice.
Any help is appreciated. Thanks
MrMikeK is offline   Reply With Quote
Old 04-29-2012, 10:52 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Clean the battery connections with a battery post cleaning brush. If that doesn't clear the trouble then you need to check the wire that ties between the battery and the power distribution panel under the hood. Also check the battery ground connection. Make sure it is making a clean connection.
Cougar4 is offline   Reply With Quote
Old 04-30-2012, 10:31 AM   #3
bassman12350
Member#: 230795
2011 Impreza WRX 5dr
WR Blue Pearl
+1 for these suggestions. Also, if you live in an area with vehicles subject to corrosion (near the ocean, in areas where the roads are salted in the winter, etc.), your car's ground connections are subject to poor contact. If this is the case, you'll need to clean most of the major chassis ground connections; primarily those in the engine compartment.
bassman12350 is offline   Reply With Quote
Old 05-01-2012, 11:19 AM   #4
MrMikeK
Member#: 266965
2006 STi
AW
Thanks for your suggestions, I'll get to cleaning it all this weekend.
serious electrical issues pannell77 Electrical & Lighting 5 04-11-2010 12:32 PM
serious electrical issues pannell77 Mid West Subaru Owners Club Forum -- MWSOC 7 04-11-2010 09:17 AM
serious electrical problems!!! wkderf Electrical & Lighting 21 03-10-2009 11:40 AM
Serious Electric Problem SUBA-NOS Newbies & FAQs 2 07-27-2005 12:13 PM
Need help: serious electrical problem with MY02 Impreza TS Automaton Car Audio, Video & Security 13 04-14-2002 03:38 PM
