#1 |
Member#: 209896
Vehicle:03 2.35L bugeye holset he351ve @23psi |
heres a light bar i made for my bugeye. i designed it around the premise of being strong enough to not shake when lights are mounted on it, to help protect my FMIC in lil fender benders, and be semi removable, with plans of also mounting a skid plate to it. this current version is made out of some exhaust tubing, and cost me $20 to make. (cost of metal.)
![]() ![]() ![]() ![]() ![]() ![]() as it sits now, need to mount my lights still and fab a skid plate for it too. ![]()
#2 |
Member#: 313807
BAIC
are you planning on going to war with that thing? haha jk pulls it off quite well!
#3 |
Member#: 269662
how is it mounted?
#4 |
Member#: 209896
took two 14in pieces of the same tubing and welded them to the sub frame. on the two pieces of the bar that go under the nose i stretched the pipe to slide over its original OD, so the bar simply slides onto the two mounts underneath and bolts secure. there is about 3-4in of overlap that the bar slides on. the setup is strong enough for me to stand on (160lbs)
#5 |
Member#: 271977
Vehicle:2005 WRX STI WRB |
Hey really sweet looking build!!! I'm planning to make something like this for my STI soon.
Just wondering what the hell kind of exhaust pipe you are using that holds 160lbs??? lol Thats impressive |
#6 |
Member#: 144903
thats hot!
#7 |
Member#: 256840
Vehicle:2002 WRX WRB |
Not bad. But that exhaust tubing will not hold up to much, not to mention the ground clearance you lost.
I built this one out of 1 1/4 .120 CMDOM tubing. It has taken a beating, and still holds up. http://forums.nasioc.com/forums/show....php?t=2193229 |
#8 |
Member#: 209896
didnt built it to battle tanks, but it is just a prototype for now anyhow haha, nice lil bar tho, clean setup
#9 |
Member#: 160991
Vehicle:05 Corn Burner Dirt Silver? |
#10 |
Member#: 209896
nice, i like that a lot actually. but hard for me to hate the price i paid for mine tho hahaha what do you use for mounting points for yours?
#11 |
Member#: 160991
We used existing sub frame points.
#12 |
Member#: 296586
SCIC
Vehicle:2002 Impreza Wrx Custom, Who knows |
are you going to weld on the brackets for the lights or not mount lights, either way i give you +1. i like the thick bar on it. if i could give you a suggestion i would try to add some support to the top in the middle. sometimes the light bars like to bounce and be noisy, adding a support bar from the middle to around where the horns go is a good idea.
#13 |
Member#: 209896
yea i plan to weld some tabs top center and on the bottom as well for my lights. and if they do bounce i will add support, but since i dont plan on adding a lot, or any really heavy lights i hope it wont bounce much. thanks for the props tho
#14 | |
Member#: 296586
SCIC
#15 | |
Member#: 304936
South East
Vehicle:97 GF8 2.5RS red |
For the next go arount source out some 1.75x.120 or 1.5x.120 HREW you could keep the weight well under 25lbs and depending on your mounts, actually have a usable bull bar. |
#16 |
Member#: 236998
Vehicle:2002 impreza ts red |
thick pipe looks great. I wana try something similar that will mate up with my skid plate. Would you say your set up is strong enough to push back light brush? thats all the strenth i need mine for.
#17 |
Member#: 209896
yea i imagine light brush wouldnt be a problem. im sure it'll push over pretty small saplings with ease.
| Thread Tools | |
| Display Modes | |
| Light Bar/Push Bar for 2011 WRX/STI | Chuck Annicelli | Electrical & Lighting | 28 | 11-13-2011 03:41 AM |
| Police equipment, Push bars, Random things little Overstock... | TheWRXMan | Private 'For Sale' Classifieds | 0 | 01-26-2004 12:04 PM |
| push bars on the rex? | Yasin | North West Impreza Club Forum -- NWIC | 1 | 07-18-2003 03:13 AM |
| Outback Push Bar | 25RS | Legacy Forum | 3 | 01-16-2002 03:50 PM |
| push bar for a 98 legacy GT | purejuju | Legacy Forum | 2 | 01-16-2002 03:49 PM |
