Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 04-30-2012, 11:57 PM   #551
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Originally Posted by J-horn92 View Post
If you remove the air pump completely does it kill your mpg, or does it not have any effect at all?
zero noticeable effect. The entire system is only active for 20-40 seconds at a cold start. It replaced front cat converters.
1 Lucky Texan is offline   Reply With Quote
Old 05-01-2012, 12:24 AM   #552
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
And it eliminates something that can eventually fail.
u2_m4r1n3 is offline   Reply With Quote
Old 05-01-2012, 12:56 AM   #553
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Originally Posted by u2_m4r1n3
And it eliminates something that "will" eventually fail.
Fixed that for you
EvileyeZ88 is offline   Reply With Quote
Old 05-01-2012, 04:42 AM   #554
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
No effect after the initial 90 seconds or so. I can't tell the difference. I suspect once you take out the factory downpipe that the secondary air has no actual function.
northman is offline   Reply With Quote
Old 05-01-2012, 05:48 AM   #555
EvileyeZ88
Member#: 233501
99 outback sport
The primary function of this system is to add extra air into the cylinders during the first 20-30 seconds of cold start up to lean out the mixture a bit and heat up the catalytic converters so they work more efficiently.
Old 05-01-2012, 10:29 AM   #556
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
The air system only runs at start up and pumps air into the head/exhaust to help heat up the cats. After about 30 seconds it shuts off.
Rene2.5RS is offline   Reply With Quote
Old 05-01-2012, 05:13 PM   #557
J-horn92
Member#: 314815
2007 Wrx
Alright isnt there an atmospheric pressure sensor that I must leave in one of the pumps so I dont have the car run in limp mode?
J-horn92 is offline   Reply With Quote
Old 05-01-2012, 05:53 PM   #558
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
not be be the typical NASIOC ass, but try searching..... in this thread!
Old 05-01-2012, 06:58 PM   #559
J-horn92
Member#: 314815
2007 Wrx
Thanks for being exactly that.. Lol but yes I have been reading for the last hour and have found my answer. I was just being lazy and didn't want to go through 30 pages of post's. Just trying to save time, I'm sure you understand.
Old 05-01-2012, 10:08 PM   #560
EvileyeZ88
Member#: 233501
99 outback sport
^we understand, but you are the 4000th person to come into the thread asking A.B.C. questions that have been answered multiple times....in this thread.
Don't be another Nasinoob
~Evil
Old 05-02-2012, 12:22 AM   #561
J-horn92
Member#: 314815
2007 Wrx
I really didn't think a yes or no answer would be such a big deal. lol but whatever someone mentioned that it your valve is stuck closed to just delete the codes and move on. If I did this would my car mess up in any way?
Old 05-02-2012, 12:27 AM   #562
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
yeah your car will explode
mccanixx is offline   Reply With Quote
Old 05-02-2012, 01:33 AM   #563
J-horn92
Member#: 314815
2007 Wrx
Has this happened to you?
Old 05-02-2012, 01:33 AM   #564
J-horn92
Member#: 314815
2007 Wrx
Old 05-02-2012, 01:34 AM   #565
J-horn92
Member#: 314815
2007 Wrx
I forgot to mention just leaving everything in place, but has this happened to you?
Old 05-02-2012, 01:36 AM   #566
J-horn92
Member#: 314815
2007 Wrx
I forgot to mention if I left everything in place, but has this happened to you?
Old 05-02-2012, 01:37 AM   #567
J-horn92
Member#: 314815
2007 Wrx
Wow, definitely didn't mean to post this so many times.
Old 05-02-2012, 07:10 AM   #568
EvileyeZ88
Member#: 233501
99 outback sport
Hahahaha nasifail
If your valves are stuck in the closed position, and you are positive of this. Then you can just delete the codes and pull the fuses and be done with it.
But make sure that they are indeed stuck in the closed position, or you will run into problems.
If you have an 07 the you have yo leave the 5 pin sensor connected from the drivers side valve. The other valve has only 2.
Hope that helps. If you have any more questions free free to pm me
~Evil
Old 05-02-2012, 08:53 AM   #569
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
Originally Posted by EvileyeZ88 View Post
Hahahaha nasifail
If you have an 07 the you have yo leave the 10 pin sensor connected from the drivers side valve.
~Evil
Agree on all this but I think the sensor connector only has 5 pins.
Old 05-02-2012, 10:55 AM   #570
EvileyeZ88
Member#: 233501
99 outback sport
^yuuuup its been about almost 2 years since I did this, surprised I remember as much as I do
Old 05-05-2012, 02:45 PM   #571
Greenhornet72
Member#: 319203
My 2006 Impreza wrx just threw these codes at me a p2440 and p2442.My cobb accessport says its my secondary air injection valve bank one and bank two are stuck open. I dont know what they are could someone please tell me if these are harmful to my engine and should be fixed very soon or is it alright just to clear them with my accessport?
Thank you
Ronnie
Greenhornet72 is offline   Reply With Quote
Old 05-05-2012, 08:17 PM   #572
EvileyeZ88
Member#: 233501
99 outback sport
It is a bad thing. You need to either replace your valves, or install block off plates and delete all related codes.
You should read through this thread, it has all the information you could possibly need to know about the subject.
~Evil
Old 05-07-2012, 01:27 AM   #573
Leftear
Member#: 285928
07 WRX Wagon
Just an update for my car.
Had the P0410 code, and I will conform that it is just the air pump itself that has gone bad. I bought a used pump off a nasioc member and its just fine now. Next time I have a problem... delete plates are going on.
Leftear is offline   Reply With Quote
Old 05-07-2012, 02:51 AM   #574
aeonflux99
Member#: 54832
2006 WRX
Had the airpump off my car for years, no issues short of a few codes.
aeonflux99 is offline   Reply With Quote
Old 05-14-2012, 08:48 PM   #575
J-horn92
Member#: 314815
2007 Wrx
If you buy some block off plates do you need to buy some gaskets, or can you just reuse the old ones?
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
