Old 04-30-2012, 11:12 AM   #1
briguy84
Member#: 311448
2012 WRX 5 Door
Default hella supertones vs. sickspeed electric blast tone
i'm was looking online for matching blue hella supertones for my 2012 wrb wrx and i came across these sickspeed electric blast tones. i found the blue hella supertones for around $70 and the sickspeed's are $45. they seem comparable to the hella supertones considering they're both 118db's. does anyone know anything about the sickspeeds as far as how they sound compared to the hella supertones? i've put the two links below so they can be compared.
Amazon.com: Sickspeed Blue Super Loud Grille Mount Compact Electric Blast Tone Horn for 12v Systems 118db: AutomotiveAmazon.com: Sickspeed Blue Super Loud Grille Mount Compact Electric Blast Tone Horn for 12v Systems 118db: Automotive
http://www.subimods.com/hella-supertone-horn-kit.html
briguy84 is offline   Reply With Quote
Old 04-30-2012, 12:09 PM   #2
BoostinChick
Member#: 218971
2007 WRX
Did you check this thread? Supertones are like $40-50...
http://forums.nasioc.com/forums/show....php?t=1840648
BoostinChick is offline   Reply With Quote
Old 04-30-2012, 12:10 PM   #3
XERO287
Member#: 253541
2011 WRX 5DR Premium
OR.
You could get these:
Amazon.com: Solleci Supertone Dual Round Horn Kit: AutomotiveAmazon.com: Solleci Supertone Dual Round Horn Kit: Automotive
And paint them whatever color you'd like. They have a different frequency than Hellas and in fact sound a bit deeper. I have them on MY11 WRX right now. I'm also going to buy a pair of Hellas to run with them.
XERO287 is offline   Reply With Quote
Old 04-30-2012, 12:11 PM   #4
XERO287
Member#: 253541
He's on Subimods, they're charging him to paint them and they come out to $70.
Old 04-30-2012, 01:16 PM   #5
BoostinChick
Member#: 218971
2007 WRX
Heh, it's like 7-10 small screws and spray paint. I used 4 coats of Krylon and 2 clear and it's lasted 2 PA winters just fine.
Old 04-30-2012, 03:26 PM   #6
briguy84
Member#: 311448
2012 WRX 5 Door
i'm a noob so i don't know what else i would need once my order arrives. i'm assuming some kind of extra wiring, not sure what type, and maybe mounting brackets?
Old 04-30-2012, 03:26 PM   #7
briguy84
Member#: 311448
2012 WRX 5 Door
Old 04-30-2012, 04:57 PM   #8
halokilller
Member#: 278870
2005 Stage 2 WRX
Obsidian Black Pearl
Originally Posted by XERO287 View Post
OR.
i have these solleci horns, no complaints so far
halokilller is offline   Reply With Quote
Old 04-30-2012, 06:23 PM   #9
RallySoob
Member#: 74872
2006 STi
White/Black
$25? Get what you pay for? sounds pretty cheap...too cheap
RallySoob is offline   Reply With Quote
Old 04-30-2012, 06:26 PM   #10
RallySoob
Member#: 74872
2006 STi
White/Black
looks like Hella makes wiring kt for $35 and also a seperate mounting kit for lil more dough. Stick with Hella's cuz they are Higher Qual and proven. Paint any color you want
Old 04-30-2012, 09:11 PM   #11
tuzzio
Member#: 292532
05 STI
I painted mine with 3 coats of pink Montana paint, then clear coated them. They're holding up rad. The brackets on mine are pieces of sheet metal stacked ontop of eachother with holes drilled in them, and they're bolted to the cross member, they make it a tight fit with my grill, and I could change this by using one bracket instead of 3, but i like the way it looks. As far as wiring goes, I plugged the stock harness in to one prong on each horn, and then used the other prong and seperately grounded them out. if I knew it was that easy, I would've bought them ages ago. All in all, I bought them used, for $30 and donated 2 hours of time to paint and mount them.
Will post pics if you would like.
tuzzio is offline   Reply With Quote
Old 04-30-2012, 10:08 PM   #12
emazz104
Member#: 281811
04 WRX
The Amazon ones look like knock offs.
Hellas are really easy to install, I originally installed mine after painting them white, it was simple, I just extended one of the factory horn wires, and screwed them into excisting holes that were already drilled with threads.
Then, I took them off and repainted them gold to match my wheels.
Then, just tonight actually, I took them back apart and wired them with a relay. Yes they are louder. No it's not a huge difference.
If you want to wire them with a relay, it's fairly simple, just a pain to fish the wires through.
All you need is some wire, and an inline fuse, with some butt connectors/solder and quick disconnects.
emazz104 is offline   Reply With Quote
Old 05-01-2012, 10:55 AM   #13
briguy84
Member#: 311448
2012 WRX 5 Door
yeah i think i'm going to go with the hella supertones for the sheer fact that everyone says they're legit, i'd be pissed if i bought knock offs and they didn't sound as good for only $20 less. i'll just suck it up and pay the extra to buy them in blue :/.
Old 05-01-2012, 11:04 AM   #14
XERO287
Member#: 253541
They sound better than the Hella's. Hella's have a higher frequency, whereas these have a lower frequency. For actual usage the Solleci's are better due to the fact that it is more audible to all drivers. Saying horns "look" like knock-offs isn't accurate. The horns look that exact same, the only difference is is sound.
Old 05-01-2012, 12:00 PM   #15
thought
Member#: 190441
2011 STi Hatch
To be clear, Supertones have 2 frequencies (375 and 500hz), and it looks as though the Sollecis do too (530 and 680hz?) which would make them much higher sounding, combined with their higher DB rating. I'd like to hear the difference in person though, as I for one think I prefer the low and high hella sound, it's more beefy.
thought is offline   Reply With Quote
Old 05-01-2012, 12:19 PM   #16
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
i have ZERO problems with people hearing my supertones
at 118db, it doesn't matter what the sound is because you're about as loud as a freight train
brew02wrx is offline   Reply With Quote
Old 05-01-2012, 01:02 PM   #17
BoostinChick
Member#: 218971
2007 WRX
I really don't get why you are so set on buying them in blue. Buy the ones for $40-50 that I linked you to and spray paint them! It would maybe take an extra hour of your install time depending on how much a perfectionist you are.
Old 05-01-2012, 02:09 PM   #18
super_usdm
Member#: 286211
1993 Legacy SS
Uhhh. Stock horn FTW!! *beep beep*
super_usdm is offline   Reply With Quote
Old 05-01-2012, 02:17 PM   #19
briguy84
Member#: 311448
2012 WRX 5 Door
i'm embarassed to use the stock horn, sounds like steve urkles clown car.
Old 05-01-2012, 02:19 PM   #20
briguy84
Member#: 311448
2012 WRX 5 Door
yeah i could do that but to get the wrb color spray paint it would cost me just as much, if not more, to do it myself. if i'm paying the same amount of money for both why not have someone else do the work for me?
Old 05-01-2012, 02:20 PM   #21
TheStig_22B
Member#: 208510
05 STI
friend got sickspeeds and i installed them the same exact way I installed my hellas and the sickspeeds where dead within a month. my hellas have been 2 years strong now. And its not the rela that went the horn just died. They also didn't sound as deep as the hellas do.
TheStig_22B is offline   Reply With Quote
Old 05-01-2012, 02:54 PM   #22
BoostinChick
Member#: 218971
2007 WRX
If you are mounting them in your grill, then you could get the closest spray paint color possible for $4. No one would be able to tell the color difference but you, of course. Have you checked to see if Duplicolor has your color out yet?
Old 05-01-2012, 03:47 PM   #23
briguy84
Member#: 311448
2012 WRX 5 Door
no i haven't checked duplicolor but thanks for the idea, i'll see what they have, thanks for the advice!
Old 05-01-2012, 07:33 PM   #24
super_usdm
Member#: 286211
1993 Legacy SS
That it does.
Let's quit effing around here folks... train horn!!
http://www.hornblasters.com/
Old 06-10-2012, 11:16 AM   #25
XERO287
Member#: 253541
Well, I finally got around to making the bracket and buying both sets of horns. It is definitely worth it to get BOTH horns as the sound that is produced is 10000000x better than any stock horn. DC drivers actually react when I honk now =)
Help with hella supertones/hella foglight install.... Super_HKS North West Impreza Club Forum -- NWIC 18 04-24-2008 10:12 AM
Hella Supertones vs Stebel Nautilus Splinter Vancouver Impreza Club Forum -- VIC 21 06-23-2007 10:29 PM
Greddy 60mm electrical boost gauge + hella supertones wrxskier18 Interior/Dressup/Audio & Security 2 03-30-2007 07:58 PM
Anyone Using FIAMM Electric Horns Instead of HELLA Supertones? clsmooth71 Interior & Exterior Modification 2 08-13-2002 06:34 PM
Hella airhorn vs supertone focalBlur Newbies & FAQs 6 09-30-2001 07:15 PM
