Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 04-30-2012, 04:16 PM   #651
Pidgeon
Member#: 284247
2002 Wrx
MBP!
Originally Posted by burkart View Post
thanks bro, no doubt. you mean the last pic, right? yea those are super fogged. i picked them up for cheap thinking i could clear them and sell them for a profit, but the entire thing has to be sanded down and polished exhaustively. after like 3 hours and 6 makita battery packs with sanding attachment i gave up. just posted the pic as an example of how versatile the j30 headlight components are..
i hear you im not dogging ya, i think they look awesome! a buddy of mine was going to do the same but never finished, so maybe ill show him yours, props though, i always hate messing with headlights..
Pidgeon is offline   Reply With Quote
Old 04-30-2012, 04:22 PM   #652
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
I'm really intrigued by your x-brace. i think it could definitely contribute to the rigidity and possibly rear suspension performance. how tightly did you bind it? how did you do it in general? we dont have the CAD CAM machines to run the scenario but the logic seems solid. suspension bridges support massive loads via tension, after all.
burkart is offline   Reply With Quote
Old 04-30-2012, 04:28 PM   #653
Pidgeon
Member#: 284247
2002 Wrx
MBP!
^exactly, it had tightened up my rear end up a good amount, i only hand tightened it, but for ****s and gigs i think ill crank it down a little more and see what up with it..
Old 04-30-2012, 05:01 PM   #654
pheonix991
Member#: 154173
2006 STI
Originally Posted by CobbWRX View Post
I want the x brace from turn in concepts but can't spend the money on it right now! I might do this!
The real one was a great upgrade. Highly recommend it.
pheonix991 is offline   Reply With Quote
Old 04-30-2012, 06:10 PM   #655
RallySoob
Member#: 74872
2006 STi
White/Black
Thats Ill! I got same Garmin Nav myself, and I never use it. But I got an idea what to do with it now How did you do this exactly? any info?
RallySoob is offline   Reply With Quote
Old 04-30-2012, 07:37 PM   #656
CobbWRX
Member#: 310040
I will get it one day might be placing a huge order with them anyways might as well ad it on! I am doing a complete build on suspension!
CobbWRX is offline   Reply With Quote
Old 05-01-2012, 02:40 PM   #657
burkart
Member#: 305000
2005 Legacy GT 5MT
garmin in instrument panel....
20120501_113618 by tommyburkart, on Flickr
20120501_113610 by tommyburkart, on Flickr
Old 05-01-2012, 03:43 PM   #658
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
I like to see the tach...
Danny5 is offline   Reply With Quote
Old 05-01-2012, 04:22 PM   #659
Drowner
Member#: 49297
14 Focus ST3
I wouldn't call leaning your handheld GPS in your dash cluster a mod of any kind.
Drowner is offline   Reply With Quote
Old 05-01-2012, 04:47 PM   #660
burkart
Member#: 305000
2005 Legacy GT 5MT
lol, its true. just a reply to earlier garmin stuff
Old 05-01-2012, 07:18 PM   #661
theoutbackdream
Member#: 301179
2013 WRX Limited
How have you guys mounted your garage door remotes?
Kinda wondering if theres a unique way to mount it in my 09.
Old 05-01-2012, 07:22 PM   #662
emazz104
Member#: 281811
04 WRX
There's a thread somewhere where they soldered wires to the pins where the buttons are and connected them to a momentary push button so you could mount it anywhere.
emazz104 is offline   Reply With Quote
Old 05-02-2012, 08:07 AM   #663
noside
Member#: 241254
2010 GR STI
More gold then your local jewelry store.
I have to get some pictures of a few other things, I spent about 15 hours wet sanding and polishing bare aluminium fuel rails, and a sheet metal intake manifold on the brother in laws 427sb looks tittys now with billet cnc heads and valve covers! I'm trying to figure out how to tackle doing the blower, charge piping and awic next. I spend a lot more time on that car then I do my own especially when it comes to custom modifications. Everything is one off custom made. even our injectors are billet adonized and polished
noside is offline   Reply With Quote
Old 05-02-2012, 11:21 AM   #664
Pidgeon
Member#: 284247
2002 Wrx
MBP!
notice any different in under hood heat since the tape? im adding tape and a blanket before "summer" actually kicks in..
Old 05-02-2012, 12:52 PM   #665
klarowe
Member#: 284753
2004 WRX STI
Pick up a homelink on ebay. One of the best (factory) looking and usually as cheap if not cheaper than a garage door remote.
klarowe is offline   Reply With Quote
Old 05-02-2012, 08:48 PM   #666
burkart
Member#: 305000
2005 Legacy GT 5MT
agreed
Old 05-02-2012, 08:51 PM   #667
lilo_memo
Member#: 200132
05 impreza sti
AW
Here's mod mod... audio video aux and usb females in the ash tray.
lilo_memo is offline   Reply With Quote
Old 05-02-2012, 09:34 PM   #668
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
I have some other pics that I took during the process, but did not do a full writeup or anything. I'll try to recall. You will need: phillips head screw driver, dremel, knife, a small power cord for your GPS (90 degree angle on it is ideal), a needle, thread, and some velcro.
1) Remove visor (a couple phillips head screws)
2) Remove mirror and cover from visor. The mirror is held in by the frame, which just snaps into place using plastic tabs that go under a metal piece in the visor
3) Start trimming. The hole left by the removal of the mirror and frame was about perfect for my GPS, but others may vary. Beneath where the mirror and frame used to be is metal and foam. I used a dremel to trim cut a square out of the metal, then a knife to cut out some of the foam. This leaves you with a thin section of foam and the fabric for the other side of the visor, which is thin enough to hear the speakers through.
4) Test fit, trim, test fit, repeat
5) Once you are satisfied with the results of step 4, clean up any obvious ugly edges with a needle and thread. As you can see from my pic, the spot where the antenna goes under the fabric was sort of rough, so using my 5th grade sewing class whip-stitch skills, I sewed it up a bit to make it look a little cleaner.
6) Now route your power cord through the visor. I cut a small notch in the stitching near the rod at the top left of the visor, where it attaches to the roof. Then I fed the power cord through there and cut another small notch into the remaining metal in the visor near the right side of the GPS. This small notch was used to hold the tip of the power cord in place with a pressure fit. My power cord came with small plastic ridges on it near the tip, which also helped when pressing it into the notch.
7) I kept the bottom part of the mirror frame in place for additional support for the GPS and to hide the lower exposed edge. Just trim it with a dremel, cut new notches for the tabs in the visor's metal (may not be necessary depending on your GPS), and push it back into place.
8) At this point you're ready to stick the GPS in. I decided to add some velcro for additional security in the visor. Two pieces of velcro stuck to the back of the GPS mate up with two pieces stuck to the foam behind the GPS in the visor.
9) Clean up the cut from where the power cord enters the visor. Again, I just did some whip-stitching that closed the cut as well as held the cord in place.
10) Remount the visor
11) Route the power cord. For this I ran mine behind the A-pillar and down to a new fuse under the dash.
RP31 is offline   Reply With Quote
Old 05-02-2012, 09:34 PM   #669
bradyarz
Member#: 272381
2008 Impreza OBS
I can't find the thread at the moment, but I did see one where the guy removed the case and got it mounted under his shift boot. Only he knew the location of the button, and it was out of the way.
bradyarz is offline   Reply With Quote
Old 05-02-2012, 09:44 PM   #670
RP31
Member#: 123574
CGM STi
Originally Posted by farmboss View Post
I really like this. I wanted a grille for my FMIC and I ended up just using some painted masonry mesh formed around the edges at the back of the opening, then epoxied in place. But I like your solution with the black trim around the mesh much better. Can you give any more details about it? How did you mount the grille to the bumper?
Old 05-02-2012, 11:13 PM   #671
farmboss
Member#: 252324
04 STi
JBP
For the bottom part of the grill, its pop riveted to a metal bracket. The metal bracket is mounted to 2 bolts that are also holding the lip to the bumper. The top part of the bracket is the part that the grill is pop riveted to. The top of the grill is held to the bumper by 2 screws going through where the license plate goes.
I got it from here... http://www.arbodies.com/abc-bodies/a...s/grillscreens
farmboss is offline   Reply With Quote
Old 05-02-2012, 11:21 PM   #672
emazz104
Member#: 281811
04 WRX
Funny, I did the exact same thing about a month ago, and had never seen it done before. Mines the same, except my RCAs are on the bottom. It's really nice having everything right there.
Old 05-02-2012, 11:40 PM   #673
lilo_memo
Member#: 200132
05 impreza sti
AW
Haha, I was going to do my RCA's on the bottom too.... When I went to drill the hole, I drill the aux (was going to be top left and usb to the right of that) too big (didnt measure the bit just eye-balled it) so I had to change the game plan. Still works out nicely, though I'll probably never use the RCA. I just wanted to have a nice flush look instead of wires sticking out somewhere.
Old 05-06-2012, 10:48 AM   #674
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Duvanator is offline   Reply With Quote
Old 05-06-2012, 11:14 AM   #675
Pidgeon
Member#: 284247
2002 Wrx
MBP!
wrap? In going with woodgrain for mine
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
