Old 04-29-2012, 08:20 AM   #1
FPS_Bloodline
Member#: 314552
2011 Impreza
Spark Sliver
Default over heard some one at the dealership
a guy at the dealership was talking to this girl, he said, you look like you dont know much about engines, you car had a misfire at a high RPM, we looked over it and everything seems fine, what probly happened is you had bad gas, and hes explained, "gas no a days had all sorts of chemicals in it and if it sits for a long periods of time they evaporate away and that is what cased your misfire
That sounds like complete bull **** to me.
FPS_Bloodline is offline   Reply With Quote
Old 04-29-2012, 08:50 AM   #2
cdoliver
Member#: 34084
2002 wrx
you sound like you don't know much about gas... What he said is true
cdoliver is offline   Reply With Quote
Old 04-29-2012, 08:51 AM   #3
FPS_Bloodline
Member#: 314552
2011 Impreza
Spark Sliver
yah but wont that take a long time to evaporate like a few weeks?
Old 04-29-2012, 09:00 AM   #4
dosman23
Member#: 297909
2014 Jeep SRT8
it can take a few weeks, but you also have to think how long was it in the holding tanks at the gas station? It may have sat there for a week before being refreshed, and add that to the time its been sitting in her car.
dosman23 is offline   Reply With Quote
Old 04-29-2012, 12:04 PM   #5
iant333
Member#: 264205
2000 swapped RS
SRP
He isn't necessarily full of ****. Gas can go bad but its rare in a cars gas tank "no a days" because of evaporative emissions stuff. Basically its a sealed unit so nothing gets out.
iant333 is offline   Reply With Quote
Old 04-29-2012, 12:44 PM   #6
Lunes
Member#: 143959
03 WRX
yeah, but when a moron gets mid grade or regular instead of premium and says "whats the difference?" OR you go to a little gas station that has had their premium tanks at half capacity for a month or THREE because they don't sell much premium. misfires can also be caused by water if you get condensation in your tank, or made someone angry and they urinate in your tank like a honda fanatic I know did to a ford a long time ago... *shrug* anything can happen.
Lunes is offline   Reply With Quote
Old 04-29-2012, 01:07 PM   #7
DonnIefnoker
Member#: 294590
2004 Wrx sti
I just got some pretty bad gas clogged my fuel filter almost completly. ultimatly cracked a ringland and wasted my turbo.... Def not bs....
DonnIefnoker is offline   Reply With Quote
Old 04-29-2012, 03:14 PM   #8
kingme
Member#: 280943
'11 WRX
"Bad gas" has become more of a problem since the government decided it would be a good idea to add 10% ethanol to the petroleum fuel supply. Ethanol is an excellent solvent and also absorbs/attracts water, which is why we can't pump E85 through pipelines. The pipelines will corrode.
E10 gas has a very short, 2-3 month shelf life.
kingme is offline   Reply With Quote
Old 04-29-2012, 04:54 PM   #9
FPS_Bloodline
Member#: 314552
2011 Impreza
Spark Sliver
Would you say its better to keep your tank half full and not full since you will have newer gas in it it that way?
Old 04-29-2012, 06:33 PM   #10
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Thread fail!
blackfang is offline   Reply With Quote
Old 04-29-2012, 07:25 PM   #11
catinthehat
Member#: 271408
lol you better hope your gas tank isn't like that or your car could turn into an expensive bomb on wheels
Basically the car salesman has a point, and the OP learned something new today
catinthehat is offline   Reply With Quote
Old 04-29-2012, 08:51 PM   #12
FPS_Bloodline
Member#: 314552
2011 Impreza
Spark Sliver
yah dosent the fumes get vented out through a charcoal type device
Old 04-29-2012, 11:04 PM   #13
moesho
Member#: 308249
well at least he wasnt sexist
moesho is offline   Reply With Quote
Old 04-29-2012, 11:48 PM   #14
kingme
Member#: 280943
'11 WRX
You're right, she probably already knew what was wrong with her car. She just wanted to see if the dealer tech could figure it out, too
Old 05-01-2012, 02:38 AM   #15
catinthehat
Member#: 271408
Exactly! It's called a charcoal canister, the canister is just to keep your car from smelling like gasoline due to the venting.
Old 05-01-2012, 02:52 AM   #16
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
No, you're wrong.
The charcoal canister absorbs the vaporized fuel, then in a purge cycle the vapors are sucked into the engine to be burned off.
PZEV vehicles are allowed almost zero emissions - including evaporative emissions from your fuel tank. It IS a sealed unit on newer vehicles.
CosmoTheCat is offline   Reply With Quote
Old 05-01-2012, 03:13 AM   #17
catinthehat
Member#: 271408
Originally Posted by CosmoTheCat View Post
No, you're wrong.
Then please explain to me what the charcoal canister is for if the vapors are just recirculated, and please explain to me how the pressure build-up due to the increase in the the partial pressure of the fuel vapor is addressed.
I am by no means an expert in vehicle fuel systems, but I am an "expert" in activated carbon systems among other things.
*edit* looked up a reputable article on the subject myself. Very interesting read. A car's fuel system is by no means a sealed system, but it is certainly more complex than I thought.
Some of my own thoughts: Vapor pressure curves are different for different compounds, so it seems plausible to me that certain vapors are being adsorbed into the charcoal cannister at faster rates than others, leaving you with liquid fuel mixture that could be much different than the original formula if left to sit long enough. Sure, once the car gets running the EVAP system does its job to try and recirculate what it can, but the ratios will still be off. Interesting stuff either way.
Old 05-02-2012, 08:40 AM   #18
cdoliver
Member#: 34084
2002 wrx
It can't be totally sealed or the gas tank would collapse when fuel was used.
Old 05-08-2012, 08:36 AM   #19
Mikkowrx09
Member#: 312677
2015 Forester XT
Ice Silver
Thats why i always put V-Power from Shell, its a little more expensive but you do feel the difference in other premiums...
Mikkowrx09 is offline   Reply With Quote
Old 05-08-2012, 09:16 AM   #20
rkramer
Member#: 118209
2015 WRX Limitec
Amazing you feel the difference when the fuel came from the same tanker truck, from the same refinery.
rkramer is offline   Reply With Quote
Old 05-08-2012, 01:38 PM   #21
///Con
Member#: 177997
World Rally Blue
Take-home lesson: Don't buy gas at 7-11
/thread
///Con is offline   Reply With Quote
Old 05-14-2012, 08:09 PM   #22
bretthejet26
Member#: 311192
2011 WRX Sedan
or cumberland farms
bretthejet26 is offline   Reply With Quote
Old 05-15-2012, 03:49 AM   #23
Dat8687
Member#: 243261
2004 WRX
Java black pearl
I loved it up north when I saw a gas statoin that Said NO ETHANOL in gas.. I was filled with joy
Dat8687 is offline   Reply With Quote
Old 05-15-2012, 06:13 AM   #24
oceanwater48
Member#: 315882
V8 U make
Baby Poop
^^^^^ which gas station is this ? google map cordinates ?
oceanwater48 is offline   Reply With Quote
('08-'10) Canadian 2010 Sport Tech Package at one of the dealerships in Edmonton A_Pointy_Rock Impreza Forum 0 11-14-2010 11:17 AM
What the hell do they tell the SRT-4 owners at the dealership? :confused: MidnightSti05 Off-Topic 69 06-01-2005 10:19 PM
I scared some guy at the bus stop at the Pentagon Jessie James Off-Topic 11 12-03-2004 04:20 PM
How bad do you want to see the US WRX in person before it arrives at the dealerships will667 General Forum Archive 5 12-09-2000 12:54 AM
