Old 04-25-2012, 02:40 AM   #1
krylon
Member#: 56761
9599 EJ255 EJ257 GC8
Rally Blues
Default A/C Conversion 07' > 11' Weight shed
I've been contemplating on swapping my 07' A/C compressor to the newer 08+ model. The new units are 9.9lbs, as the previous gen units are 15.7lbs. The newer a/c units provide a 11% less drag and power loss, which isn't a lot, but better... right?
This will all be done in my swapped daily driven GC8.
Has anyone done this? The new inline switch is 4 pin, compared to the older 2 pin. The newer lines connect to the 02-07 ' hvac expansion port pretty well, but running into space issues w/ the way the new lines run around the tmic.
I am thinking om keeping the entire old system and swapping in the compressor. I will just swap the single pin harness on the compressor.
any ideas..?
krylon is offline   Reply With Quote
Old 05-04-2012, 01:40 PM   #2
krylon
Member#: 56761
Rally Blues
So, I pulled the old compressor out and fit up the new gen compressor. Brackets differ, but still bolt up at the same points on the block.
Low/high pressure hoses route slightly different and won't work well in the GC as is. I'm also noticing the switch on the condenser return line is 4 pin an the old switch is 2 pin. The compressor harness guide/snap in differ, but are single pin. So, just a simple harness swap there.
I fell better w/ keeping the entire old routing system of lines. I will just have the newer line ends that mate to the compressor, fitted to the old H/L lines.
If all goes well, I plan to dyno soon and will post stats of power loss when old/new a/c units are switched on.
FS : >* 11' wrx oem parts, floor mats, shift knob, cat back, springs, intake Entaille NWIC Private Classifieds 24 02-06-2012 06:48 PM
07' STI Spec C Tank in an 11' Sedan? jockeygolfs Water/Methanol Injection, Nitrous & Intercooler Cooling 0 12-28-2011 01:11 PM
Shedding weight from a rex Parks09 Newbies & FAQs 14 04-21-2010 10:59 PM
Audi Vows To Shed Weight AVANTI R5 Non-Subaru News & Rumors 12 06-09-2009 02:40 PM
shedding some weight!!!!!!!!! white2002rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 06-27-2008 11:17 PM
