#1 |
Member#: 269172
Vehicle:2011 sti |
I know these threads are getting old, but for the sake of keeping records, I figured I would post this on NASIOC.
2011 STI, 15,xxx miles, turbo back exhaust, tune, blown ringland, number 4 cylinder is at 55 psi. The car throws no codes, and to the average guy, it probably would not seem like anything is wrong. Part 1 A few weeks ago I noticed a lack of power and boost. I confirmed this with the boost gage on the accessport, which would not get above 11. I went home to look at the car, took the intercooler off, and oil started dripping out everywhere. I called the shop where I had the car tuned, and they told me to have it towed to their shop. After 2 hours with the car, they told me I had a ringland failure in the number 4 cylinder, and that the compression test came back at 55 psi for this cylinder. We devised a plan to build the engine and make the car fast. At an estimated cost of $12-14,000, I need to get a loan to do this, but I know I would be happy with the car, and I hope to make the engine more resistent to failures. Part 2 Just to play all my cards, I went to the dealership where I bought the car. I told them my mods, the other shops diagnosis, and asked if there was any warranty on the car. They told me that even with the mods, the ringland should not fail this early. They gave me Subaru Customer Relations number, and told me that SCR were the only ones who could help, since the car was tuned. I called the number, and Subaru said they have a good faith policy, and they would like me to have the car towed to them at their cost, to see if there was anything they could do. The dealership gets the car and goes to work. I get a call the next day telling me that there is no way I blew a ringland, because the car never threw a code. The tech told me that it was "beyond logic", and "impossible" for this to be the case. He then goes on to say that I need a compression test at a cost of $150.00 to diagnose the problem, and if that does not reveal the problem, they will have to do more work, possibly at my expense. He tells me they will do the leak down test, call me with resukts, and we will go from there. 3 days later... I got a call today from the tech. He told me that I had a ringland failure in the number 4 cylinder, the rod was shot, and the head gasket blown. He then goes on the say that I once had my oil changed at another dealership, and they flagged my car as "highly modified", and thus I no longer have a warranty. For $2,000.00 they will fix the problem. He then goes on to say that COBB Accessports are horrible for the car, and that is the reason for my problem. Part 3 My real problems. How did Subaru's gesture of "good will" result in a diagnostics bill that will probably be $600 or more, even though I never authorized it? How come they took 3 days to get back to me, when they said they would call my after the compression test? If the car was black flagged by a previous dealership, why did I go through all of this at my expense? If it is in the system that the car is not to be under warrenty, and I told them I wanted to know if they could fix it under warranty, why didn't anyone say no, before all this crap started? What to do. I really do not want to pay Subaru for anything besides the compression test that i agreed to. I never authorized whatever work is necessary to determine a bad rod and blown gasket. I do not see any point to fixing the engine with Subaru, even if I go back to stock, since there is no warranty. So, It is time to build the engine. I must say though, I am really disappointed with Subaru, not the car, just the people I talked to recently. There inability to communicate with each other, and give me a straight answer. I feel used. They convinced me to bring the car in under the pretense that it would be warranted with a gesture of good faith, then rescind that offer, and left me with a bill for a problem that I had already paid to have diagnosed.
#2 |
Member#: 280572
E. Canada
Vehicle:2011 sti sedan plasma blue pearl |
U r pretty much stuck with the bill cuz of the car being black flagged at another dealer and the dealer that did all the testing might of worked with u until this. U could take legal action cuz of the pre diagnoses that u gave them but really is it going to be worth while, probably not. Being in the position r in I would get it in writing that your mods caused this issue regardless of what r intending to do. I would also press the issue of getting it covered under warranty firmly but respectfully cuz they did say that shouldn't be an issue so early. If I was in your shoes I would just get a built short block and be done with it and this $10-14,000 is ridiculous, do your research there r alot of good engine builders out there for a third of this cost good luck
#3 |
Member#: 130990
Vehicle:06 Red Wagon hta68 MPS tuned JDM 6-speed |
Is your car paid off? Try to avoid borrowing to fix your motor. I know you can spend a lot less than you're talking for a factory shortblock with some drop-ins. I spent some money on a built motor from Maxwell power, but they do sell a pretty good package for a budget: 2800.00 for a new SB with JE pistons. Similar deals can be found elsewhere.
It's just not wise to pile debt on top of debt. Unfortunately, I don't see Subaru fixing that motor of yours. But I think you do have recourse on that 600.00 if you did not authorize beyond the 150.00. Go upstairs and call SOA, to start. Also, if you paid with a credit card, you can dispute the charges and have them pull the money back from the dealer pending resolution. |
#4 | |
Member#: 280572
E. Canada
#5 |
Member#: 269172
Vehicle:2011 sti |
The 12k is for more than a rebuilt engine. I'm going to have the engine built, the heads port and polished, new turbo, intercooler, fuel pump, injectors and a gauge cluster. Sorry I did not specify.
I just feel misled by the conversations I had with everyone from Subaru. I never would have moved the car from the shop to the dealership if I had known it was not going to be covered. I was up front with everyone and told them the car was tuned. I called SOA back and am waiting for a reply. |
#6 | |
Member#: 130990
#7 | |
Member#: 280572
E. Canada
#8 |
Member#: 280572
E. Canada
Is your tuner a reputable business I would look further look into the tune u got cuz I'm stg2 with 35k my11 sti 318whp 352awt 94 octane. To be quit frank wouldn't let them touch my car just for the fact weather they caused it or not they wouldn't see another dollar from me
#9 |
Member#: 232430
RMIC
Vehicle:555 I haz 5 Subarus GC8/GF/SG/GD sedan & wag |
Well Im a tech at a Subaru Dealer..... I know this for FACT. There is no "black Flag" policy. That doesnt exist, however if you had some previous work done that the car needed to be called in to the tech line for some kind of assistance. Then and only then do they ask if the car is modified. So, I call B.S on the tech. He just wants the job as "customer pay" because warranty is only going to pay him 10.4 hours of labor. Where as customer pay is 16.5 hours labor. The compression test and leak down test should be covered under warranty. Thats how it works, if they find that the cause was from modifications then they will deny a claim for parts warranty. Subaru gives you the benefit of the doubt that the engine that went into your car may have had a failure that WAS caused by a failure on their end. If it turns out its from abuse or because you tuned it they have the right to say, sorry not gonna happen. BUT they still should cover the compression and leak down test as it is for them to determine a cause. If they didnt get written or telephone consent from you for more things or more diag you can tell them to eat it and you are coming to get your car. By law they have to have that, all phones there should be recorded.
Now, where can you go from here. This is what I recommend! Call the service Manager for the dealer. DEMAND that the Subaru Field Service Rep call you so you can explain the situation to him and what you believe should ultimately be done about it and what is fair. In most cases there will be a 1 time exception and it will be covered. If not try to get them to pay the labor and you pay parts, or vise virsa. Happens all the time when an actual cause cant accurately be 100% be determined. This is what I hate about my job, when other techs dont give the customer the benefit of the doubt and just shoot for the customer pay route. Yes the car was tuned, but for what? Just minor fueling....... lets hope so. |
#10 | |
Member#: 280572
E. Canada
+1 fare exchanges no robbery the way it should be ![]() |
#11 | |
Member#: 280543
#12 |
Member#: 232430
RMIC
In MT, the kind that tries its best to help customers in relation with SOA. Contacting them and talking with them goes a long way, and ultimately decisions for repairs are made by us (technicians) or in some cases the FSE. I had a similar (almost exact to OP) case recently which required the FSE to get involved because the customer had his car tuned a few years ago, which I was not aware of till they asked me for the CID/CVN #s which were different from factory records. Went over with the customer what exactly was done and why, relayed that info to the FSE and he said to give the customer the benefit of the doubt and to go a head and fix it this time. The customers car was stock accept for a SPT intake and exhaust. He had kept it stock as possible for warranty purposes. If its obvious you have a tune with high boost/timing adjustments you can kiss your warranty good bye. Now, we cant see what was changed tune wise, but if the CID & CVN #s are different you can bet it raises a red flag and then your under the microscope and questions will be asked. There is a way to save your factory CID/CVN # to your car but Im not about to disclose how to do so. If you know how, good for you.
Im just a tech who really likes to play fair, Im not there to ruin your day and hit your wallet for as much as possible. I have work coming out my ears, the last thing I need is to piss someone off who is just going to tell the next guy that we are d***Ks. If there is a possibility its Subarus fault, Ill try my best to find out if it should be covered. Now go and run 20lbs of boost on a car still under warranty and try to get me to warranty a block.... Not gonna happen, its purely your fault and I shouldnt make Subaru pay for your mistakes. If you raise boost and drive it like you stole it, just man up and pay the price. |
#13 |
Member#: 136314
Vehicle:2014 Grand Cherokee |
Sorry to hear about your ringland problem. Hope everything gets cleared up for you.
I live next State over, so I would REALLY like to know the name of this Subaru dealership...so I can avoid them at all costs. Could you also let us know a couple other things as well... 1) What stage were you at, and who did your tune? 2) Was the CBE the only mod to the car? Did you have some sort of CAI other than stock? 3) What oil/oil filter were you using? 4) Were you rough on the car, or did you baby it? |
#14 |
Member#: 309636
Vehicle:2012 WRX Limited Plasma Blue Pearl |
Wow, so they CAN tell if the ecu was retuned, even if it's a stock car with a Stage 1 OTS Cobb AP tune... Hmm.
#15 | |
Member#: 232430
RMIC
There is a product that many of you use that saves the original CID/CVN #s. Open source and other means of tuning wont save these numbers. As far as I know there is only one product out there that saves these numbers and has software to re-flash those Factory #s back to the ECU. If you open source tune or use other lap-top tuning software the CID & CVN #s are erased and show up as ########. |
#16 |
Member#: 280838
Vehicle:MY12 WRX DGM EFI Stg2+ |
^Are you talking about the AP unmarry?
#17 |
Member#: 305107
Vehicle:2012 wrx/TP Stage 2 satin white pearl |
my questions to the OP is at what miles did you do a stage 1 tune?
#18 |
Member#: 300773
Vehicle:08 STI Black Pearl |
As far as I understand the AP dumps the entire ECU to its flash memory and when you *uninstall* it pushes 100% of that data back onto the ECU.
Cobb says the dealer cannot determine if it has been tinkered with... but who knows if that is true. |
#19 | |
Member#: 232430
RMIC
refer to the following quote below.
#20 |
Member#: 9264
Vehicle:2012 WRX 5dr Ice Silver |
It's my understanding that they can't tell the ECU has been modified, but what they can see is that the flash counts (number of times of the ECU has been reflashed) on the ECU don't match the number they have in their system. Now if Cobb has come up with a way modify the flash counts, that would be news to me.
#21 | |
Member#: 309636
Here's an email from Christian at COBB from 2006 that I found...
#22 |
Member#: 156128
Vehicle:2011 WRX da ba dee da ba dye |
#23 | |
Member#: 232430
RMIC
read the last part of the Quote from Christan. Last edited by UK-Wagon; 05-07-2012 at 08:24 PM. |
#24 |
Member#: 262734
Vehicle:2004 STI WRB |
If the normal person can not tell you have ring land failure trade the car back into the dealership for another one and let it be their problem
#25 | |
Member#: 9264
Thanks for this posting up. |
| Thread Tools | |
| Display Modes | |
| Ringland Failure Poll for MY 2009-2011 STi's | last lemming alive | Factory 2.5L Turbo Powertrain | 39 | 09-08-2012 08:53 PM |
| Ringland failures with ELH? | TRSCobra | Factory 2.5L Turbo Powertrain | 4 | 03-11-2011 05:32 PM |
| And I Thought Ringland Failures were for the 2.5 motors... | dux10 | Factory 2.0L Turbo Powertrain | 4 | 02-18-2011 03:32 PM |
| Stock pistons...cracked ringlands...what next??? | daddyphatsax304 | Factory 2.0L Turbo Powertrain | 12 | 07-22-2010 12:58 PM |
| School me on ringland failure...preventive measures? | JDMFLCL | Newbies & FAQs | 12 | 06-18-2009 09:33 PM |
