Old 04-29-2012, 09:47 PM   #1
cmh_subaru
Member#: 318452
2006 STi
Obp
Question HELP! 06 STi making binding noise with tight turns, low speed (see linked video)
06 STi is making an odd noise when taking tight turns at lower speeds. First noticed when pulling in and out of parking stalls. It happens both in forward and reverse and both right and left. Checked all the basics and couldn't find anything with wheel bearings, axles, drive shaft, dust shields, etc. We tried cleaning the ABS wheel speed sensors with no change.
Please see this linked video. This is not my video but it's the exact same noise.
Any help would be appreciated. Thanks.
cmh_subaru is offline   Reply With Quote
Old 04-29-2012, 10:11 PM   #2
Supraru
Member#: 23313
99' 2.5Rs
black
First you could start by wearing shorts that don't suck. lol
Second I'd check out your exhaust. Sounds like it's rubbing and that's making the noise.
Supraru is offline   Reply With Quote
Old 04-29-2012, 10:12 PM   #3
Supraru
Member#: 23313
99' 2.5Rs
black
Old 04-29-2012, 10:31 PM   #4
cmh_subaru
Member#: 318452
2006 STi
Obp
Again, it's not my video; stole it from youtube. it's not the exhaust.
Old 04-29-2012, 10:37 PM   #5
Supraru
Member#: 23313
99' 2.5Rs
black
You beat the hell out of your car?
Old 04-29-2012, 11:02 PM   #6
cmh_subaru
Member#: 318452
2006 STi
Obp
nope.. it's my wife's daily driver.
Old 04-29-2012, 11:15 PM   #7
Supraru
Member#: 23313
99' 2.5Rs
black
Time to buy a trans.
Old 04-29-2012, 11:29 PM   #8
cmh_subaru
Member#: 318452
2006 STi
Obp
Nice guess. Anyone else out there?
Old 04-29-2012, 11:32 PM   #9
Supraru
Member#: 23313
99' 2.5Rs
black
You post a video of someone else's car making a noise. What kind of help do you expect? Stop being a cheap ass and take it to a dealer for diagnostics. Clearly you're not qualified.
Old 04-29-2012, 11:37 PM   #10
cmh_subaru
Member#: 318452
2006 STi
Obp
Its the same noise that my car is making. If your not going to be of any help why are you posting.
Old 04-30-2012, 01:38 AM   #11
fizzyl
Member#: 103490
06 STi
My 06 makes the exact same sound. There are a number of threads about this if you search for differential binding, or center diff issues. It's a load groaning sound. Some times it's the wheel speed sensors confusing the DCCD. Sometimes it's the steering angle sensor. Sometimes it's the center diff binding "normally". Sometimes it's the center diff choking on itself on the verge of death.
Try this, put the DCCD in manual and put the bias all to the rear. It should decrease the sound significantly.
I've taken my car to the dealer 3 times for the issue. One time they said they'd never heard it before on any STi but that it was normal. They replaced the tranny/diff fluid to no avail. The next time they replaced the DCCD controller because they couldn't find any errors with speed or angle sensors. The third time they just threw up their hands and said it's normal.
It's on the books 3 times for me now so I'm just waiting for it to break.
It's definitely not normal because not all STis do it. I think it's especially prevalent in 06s and sometimes 07s. I think there was a diff change around that time. From the dozens of threads I've read it starts happening between 20-25k miles and stays. I'm at 55k now and it's been doing it for 30k. If definitely did NOT do it the first 20k miles.
fizzyl is offline   Reply With Quote
Old 04-30-2012, 07:49 AM   #12
Supraru
Member#: 23313
99' 2.5Rs
black
Bride you want a direct answer and no one has one. Either reign your searching skills or take it somewhere to be diagnosed. Chances are your diff is bad. Then what are you going to do? Bitch about it in this thread or take it somewhere to get fixed? So why bother wasting everyones time and take it to a shop.
Old 04-30-2012, 12:55 PM   #13
cmh_subaru
Member#: 318452
2006 STi
Obp
Thanks fizzyl I will let you know if i find out what the cause is. Thanks for your input.
Old 04-30-2012, 06:31 PM   #14
cmh_subaru
Member#: 318452
2006 STi
Obp
Took a look at the car today after work. Looks like i will be needing a new center differential. Called Subaru and they said it would be $2,400 for the part.
Old 04-30-2012, 10:59 PM   #15
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Had this in my 05sti and it is starting now in my 07 STI try adding a friction modifier to your trans cocktail.
Russ
BlackEyeII is offline   Reply With Quote
Old 04-30-2012, 11:00 PM   #16
BlackEyeII
Member#: 65140
Default Blarney
iPad fail sorry...
Old 05-01-2012, 10:12 PM   #17
cmh_subaru
Member#: 318452
2006 STi
Obp
I Think i have it figured out. So i replaced the clutch about a month ago and everything was fine then about two weeks after the clutch replacement the noise started. Everyone said to use any 75-w90 and not to worry since the DCCD is a sealed unit. So i used mobile 1 75w-90 that i had at work. Now i find out that the DCCD is not actualy a fully sealed unit and that the clutches do see the trans fluid. I will be replacing the transmission fluid this weekend with the Subaru extra s fluid. Ill let you know if it makes a difference. Dident even think about the fluid till now.
Old 05-05-2012, 12:05 PM   #18
cmh_subaru
Member#: 318452
2006 STi
Obp
Replaced the trans fluid with the subaru extra s fluid and the noise is gone!
Old 05-06-2012, 01:59 PM   #19
Smoothneal
Member#: 301039
2004 Impreza WRX STI
WR blue
Supraru is mad at life. what a tool. I have a 04 sti and makes this noise in reverse especially when in reverse,uphill,and turning all in the same motion. It all like CLANK CLICK CLANK. Sounded like CV joints at first but its only in reverse.
Smoothneal is offline   Reply With Quote
Old 05-06-2012, 03:44 PM   #20
Supraru
Member#: 23313
99' 2.5Rs
black
Newbs are tools, just like you.
Old 05-07-2012, 04:24 PM   #21
Smoothneal
Member#: 301039
WR blue
I guess some people need a forum to gain respect.
Old 05-07-2012, 04:32 PM   #22
briankyle97
Member#: 298271
2015 WRX base
Can't stand cry babies that have nothing better to do but anyways, my WRX was making a similar noise and it ended up being the strut tower bar nut that was rubbing with the strut bar. My be worth looking at if you have one. Just added an extra washer and noise gone. I could have sworn the noise was coming from underneath.
briankyle97 is offline   Reply With Quote
Old 05-07-2012, 06:16 PM   #23
Smoothneal
Member#: 301039
WR blue
I dont have a bar. I have tried keeping my car stock. But all these performance/aftermarket parts are cheaper now than 2004. Feels like its time to do some work.
Old 02-06-2016, 06:41 PM   #24
anchoricex
Member#: 167744
Bringing this thread up. My car is doing this exact same noise in the video in the first post. OP in this thread was able to fix by replacing his tranny oil with Subaru Extra S.
You can NO LONGER buy Subaru Extra-S gear oil, and Subaru put out a bulletin a while back saying dealerships can use Subaru HPGO (high performance gear oil) which is NOT THE SAME THING: See analysis here: http://www.bobistheoilguy.com/forums...topics/3542880
This is a huge PITA and I don't know what to flush my tranny fluid with.
anchoricex is offline   Reply With Quote
Old 02-07-2016, 03:05 AM   #25
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Motul Gear 300 75w-90. You have synchros, so don't get the LS version unless you feel like cracking the transmission case for an overhaul prematurely.
mrsaturn7085 is online now   Reply With Quote
HELP! 2011 Outback Sport Popping noise from rear end low speeds. tornado542 General Community 4 08-31-2011 06:41 PM
binding noise ?? When i turn my steering wheel raggedoutsti Newbies & FAQs 3 10-06-2010 07:56 PM
Thinking noise at medium and low speeds, axle problem? Xenri Transmission (AT/MT) & Driveline 0 04-28-2010 06:35 PM
Squeeking noise when accelerate at low speed jonpark Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-15-2009 05:40 PM
Binding in the steering at low speeds? 03MBP Brakes, Steering & Suspension 2 09-04-2005 02:23 AM
