Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 05-07-2012, 08:09 PM   #1
chansen42
Member#: 305256
2004 Wrx
Default 04 WRX - No power windows, no power locks, no illumination lights!!!
Hey everyone
I've been battle this issue for about a week...
It all started when my fog lights stopped working. Checked the fuse, it was fine... figured it was the relay. I pulled the relay and swapped it with the A/C relay and it was working fine... plugged it back in and then power windows, power locks, and all illumination stopped working... all fuses are in tact.
any help is much appreciated.
thanks
chansen42 is offline   Reply With Quote
Old 05-07-2012, 09:05 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Did you checked the fuse box besides the steering wheel? Swap out the fuse for a new one. A fuse could be blown even when it looks intact.
minifreak is offline   Reply With Quote
Old 05-07-2012, 09:18 PM   #3
chansen42
Member#: 305256
2004 Wrx
replaced the illumination fuse just now and that started working again. the locks work too now... still no windows!
doesn't matter which switches i use, not one window will budge. and i don't hear a click from the relay either
Old 05-08-2012, 07:19 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Fuse SBF-6 in the panel under the hood supplies power to the windows. Use a test light to verify power is getting to both sides of the fuse. If that is ok then check the wiring going to that fuse location is making good connection.
Cougar4 is offline   Reply With Quote
Old 08-08-2014, 04:58 PM   #5
Dcasta9
Member#: 339589
I'm gonna bump this from the dead, I have the same issues right now on my '02 wrx, did you ever figure it out!?
Dcasta9 is offline   Reply With Quote
Old 08-20-2014, 12:02 AM   #6
Anthonym1979
Member#: 399460
2002 wrx
iam having a similar problem with my 2002 wrx the turn signals and all the power windows don't work I have tracked the problem down to the green/white wire on the coil side of the relay on the dash has no voltage , I can get everything to work with a power probe . I have looked at wiring schematics and I cant find were the green/white wiring is feed from
Anthonym1979 is offline   Reply With Quote
Old 08-20-2014, 12:32 PM   #7
Cougar4
Member#: 53443
Winestone
That relay is most likely the ignition relay. Data shows that a grn/wht wire is tied to the output side of the relay contacts. A wht/blu wire supplies the power to the relay contact. Verify that those points are getting proper power while the trouble is happening. If there is a problem at the input side there is a connection at connector B62 pin-1 where the problem might be at.
04 STI Gauge Cluster into 04 WRX - Brake light? Craigster05 Electrical & Lighting 4 01-11-2010 12:49 PM
WTB: 2000 Legacy Driver Power Window Switch/Doors Lock Assembly eternum Private 'Wanted' Classifieds 0 04-30-2006 05:12 PM
power windows and power door locks zuhi Electrical & Lighting 4 04-23-2005 04:11 PM
04 WRX - Window tint affect reception? IMPRZV1 Car Audio, Video & Security 21 04-21-2004 03:28 AM
Sunroof in 04 WRX - Yes in 04 STi yes or no? TheShadowWRX STi Forum Archive 29 01-08-2003 04:55 PM
