Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 05-08-2012, 01:23 AM   #1
westicles3
Member#: 302089
2010 WRX
Default Tire stretching question
Hows performance?
So just got some new 225/40-17 nittos that will be going on 17x9 grids (got a killer deal). I've seen how it looks and the little bit of stretch there is isn't too bad looking. I'm more into performance than looks however and can't find much on how this might affect handling or wear patterns. Any input would be awesome. Thanks!
westicles3 is offline   Reply With Quote
Old 05-08-2012, 03:01 AM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
'Stretching' a skinnier tire on a larger wheel is unnecessary and will decrease your performance. Grip, breaking distance, added unsprung/rotational weight, the works. If you're going for looks, great! Take this thread to Tire and Wheel in Technical. You're not going to get any positive advice from very many people around here. My advice, sell that skinny rubber, get tires that actually fit.
RoadKillDMD is offline   Reply With Quote
Old 05-08-2012, 08:50 AM   #3
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
why would you not buy tires that fit your rims properly?
It sounds like you already bought the tires and are going to install them no matter what anyone here says. we could tell you until we are blue in the face how it will negatively impact performance, blah blah and you would still do it so.....
jayman4312 is offline   Reply With Quote
Old 05-08-2012, 10:56 AM   #4
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
225s fit well on a 7.5-8in wheel, for a 9in wheel you wanna look at 255's
stretching tires decreases traction and cornering ability because you're taking away the sidewall and since the tire isnt square on the wheel the contact patch is smaller and you'll probably wear through the tires quicker, its just dumb
brew02wrx is offline   Reply With Quote
Old 05-08-2012, 11:21 AM   #5
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Agree with all^^
You need a 245 at the least a 255 will be a flat/flush fit or a 265 with a bulge
dangerousatom is offline   Reply With Quote
Old 05-08-2012, 11:30 AM   #6
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
The stretch is supposed to give a stiffer sidewall, that's really the only pro, most people are stretching to fit wide/low offset wheels, not for performance.
colin1234567 is offline   Reply With Quote
Old 05-08-2012, 12:05 PM   #7
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
You will be much happier with wheels and tires that are the proper size for each other. If you care about performance your going to be losing it if this is your setup you are gioing to run. In the end is your car do what you want.
07VTRex is offline   Reply With Quote
Old 05-08-2012, 01:59 PM   #8
Rev Works
Member#: 305656
05 STi
With what most people are saying here, A stretched tire will give you less performance attributes over a tire that would fit that wheel properly such as a 245-255.
Rev Works is offline   Reply With Quote
Old 05-08-2012, 05:23 PM   #9
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Ok, I agree with most of this. I'm curious how a 225 width tire on a 17x9 wheel will add unsprung/rotational weight, compared to say, a 255 width tire on a 17x9 wheel. Assuming 225/40/17 compared to a 255/35/17, so as to keep the overall diameter close between the two. I can't imagine the 225 tire weighs much more, if any, than the 255 tire.
Gallo2011 is offline   Reply With Quote
Old 05-08-2012, 05:31 PM   #10
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The comparison isn't between a 225 on a 9" wheel and a 255 on the same wheel, the comparison is between a 225 on a 9" wheel and a 225 on a 7.5" wheel.
In other words, if you're going with a 225, choosing a wheel that's the right width will reduce weight and increase performance versus choosing a wheel that's too wide.
Old 05-08-2012, 05:50 PM   #11
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Yeah, I read RoadKill's post again and noticed he mentioned a larger wheel with the 225. A 225 tire on a 7.5" wheel will definitely weight less than a 225 on a 9" wheel.
OP, it sounds like you want the best of both worlds, so to speak. Good looks and performance. I think a 255 tire on a 17x9 wheel would look pretty mean. You'd definitely gain the performance you're looking for too. Check out the Top Scoob on the home page for what I'm talking about. His is extreme, but it looks good and performs even better.
Old 05-09-2012, 02:17 AM   #12
westicles3
Member#: 302089
2010 WRX
Thanks for the input guys. Think I'll end up selling the tires and get the proper fit. Anyone interested in some new nitto invos?? Lol
Old 05-09-2012, 03:55 AM   #13
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
lol @ a "little" stretch on a 17x9 wheel....
nightcrawler60 is offline   Reply With Quote
Old 05-09-2012, 09:11 AM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Tire Stretch has nothing to do with tire wear. At all. Not one bit.
Old 05-09-2012, 09:33 AM   #15
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
This. its when you start going super crazy awesome hella flush and toein/adjust camber all crazy and ride around daily like that. Thats when you go through tires everyday due to awful uneven wear.
Old 05-09-2012, 09:37 AM   #16
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I was slammed, tucking 255s with 4* of camber, and I had no abnormal tire wear. The key is 0 toe.
Old 05-09-2012, 12:20 PM   #17
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
But you keep wheels as long as I keep guitars. Maybe a month max.
Don't sell the tires, they're fine. Sell those stupid wheels and get some that are proper and will fit. 17x8 would be nice and even 17x7 1/2 would go well with 225's.
215 tire stretched on a 7.5" wide wheel? peterjh85 Tire & Wheel 12 03-11-2012 01:36 AM
Summer tires stretched and poked sempersubi Tire & Wheel 21 02-25-2011 04:11 PM
tire stretch question invidiaWRX218 Tire & Wheel 17 06-21-2009 09:26 AM
Timing belt stretching question breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-19-2008 11:47 AM
VW tire stretching soundwave Off-Topic 98 05-25-2004 07:42 PM
