Old 05-08-2012, 11:22 AM   #1
waltah
Member#: 317856
Default Cobb OTS map ? , intelligent mode
Thus may be a dumb question but does the OTS map for stage 1 change only the S# map or sport and intelligent as well? Love the stage 1 93 tune!
Thanks folks
waltah is offline   Reply With Quote
Old 05-08-2012, 02:04 PM   #2
Migraine777
Member#: 308772
2012 Sti Wagon
All the different Si-Drive modes do is adjust throttle input %s.
S = as close to cable-driven throttle as possible (think 100% pedal = 100% throttle)
S# = aggressive, top end happy throttle response (think 80% pedal = 100% throttle)
I = sluggish, calculated throttle response (think 100% pedal = 70% throttle)
**** DISCLAIMER ****
Before all the flames, these are not actual or even calculated values, I was just using easy to understand numbers for the o.p. to understand how the modes work.
That being said, all the "modes" work with any tune, it's just a preference on how you want throttle response to be...
-Pat
Migraine777 is offline   Reply With Quote
cobb ots maps DausWRX Newbies & FAQs 4 02-19-2008 12:31 PM
Use Modified Stock Injectors with Cobb OTS map? Spike700 Newbies & FAQs 1 12-01-2007 03:55 PM
cobb ots maps scooterman Newbies & FAQs 21 08-13-2007 08:57 AM
Cobb OTS Map - VF39 93 MT101 Vs. FP18G 93 MT101 rhinotech Engine Management & Tuning 23 06-21-2007 09:15 PM
Will the FP 16G Cobb OTS map work? crashnscar AccessPort 1 01-30-2007 02:20 PM
Message Board Statistics All times are GMT -4. The time now is 12:06 PM.
