Old 05-08-2012, 05:24 PM   #1
spydernooby
Member#: 307299
Default 02 rex 6 speed swap tranny mount and other questions
about to do a 6 speed swap on my 02 bug eye and got a couple last minute questions.
its a usdm 02 wrx and the transmission is from a 2004 subaru wrx sti (usdm).
the plan is to use the stock r160 differential and an automatic drive shaft.
my questions are , do the drive ratios match up (from what i read they are both 3.90) and more importantly what do i do for a transmission mount and subframe brace/crossmember.
spydernooby is offline   Reply With Quote
Old 05-08-2012, 05:46 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
No, the final drive does not match up. Only the 06+ STI 6MT has matching ratio to be used with the 3.54 FD in the 02~05 WRX R160.
You'll need to use 6MT transmission mount as well.
Read the sticky. http://forums.nasioc.com/forums/show....php?t=1672474
minifreak is offline   Reply With Quote
Old 05-08-2012, 06:20 PM   #3
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
^^^^ This
MD04WRX is offline   Reply With Quote
Old 05-09-2012, 01:15 AM   #4
spydernooby
Member#: 307299
oh that really confuses me then. i was under the impression both had 3.90 final drives (or according to this table of subaru transmissions im reading)
Old 05-09-2012, 12:59 PM   #5
dragoontwo
Member#: 275500
1992 SVX
They do Have the same final drive. The center and rear differential ratios are different. Your WRX has a 3.9:1 front differential, a 1.1:1 center differential, and a 3.54:1 rear differential. That STI has a 3.9:1 front differential, a 1:1 center differential, and a 3.9:1 rear differential.
dragoontwo is offline   Reply With Quote
Old 05-09-2012, 01:22 PM   #6
spydernooby
Member#: 307299
ok, thanks for explaining it. so in order to do this swap i would need to also use the rear diff and drive shaft from that sti. and in order to use that differential yet retain the 5x100 bolt pattern (as my rims are 5x100) id need to go with a set of early 04 5x100 brembos?
Old 05-09-2012, 02:24 PM   #7
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
There are a few options:
1. Find a set of 04 STi rear hubs + brembo/FHI 2pots setup.
2. Get Legacy Spec B axles.
3. Get the Missing Link.
Do some search and reading, all the info is available if you are willing to learn.
04 sti 6 speed swap into 00 2.5rs questions salvi Transmission (AT/MT) & Driveline 3 09-14-2011 02:13 PM
WTB: 02 WRX Group N Motor/Tranny mounts and Pitch stop. silvrex02 Private 'Wanted' Classifieds 5 07-14-2009 02:55 PM
6 speed swap need help and suggestions Serkan Transmission (AT/MT) & Driveline 0 03-04-2009 09:02 PM
Wanted to Buy 6 speed trans, STi intercooler and other sti parts AllBlk07Wrexx Private 'Wanted' Classifieds 6 08-24-2007 12:42 AM
top mounts and other questions jkyes Legacy Forum 5 07-22-2003 04:21 PM
