Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 05-06-2012, 10:02 AM   #1
Ko3n3k3
Member#: 273925
Default 2 Wires on 00 RS to 02 WRX harness I can't figure out
Hey I just got finished merging an 02 WRX to an 00 R.S. But I ran across 2 wires that (I believe) are unaccounted for in the guide I was using. One is B136/29 a R/W wire from the R.S ECU to the 2nd wire in the MAP (sensor # 22012aa070). I was wondering if anyone had a suggestion on what this does and where I can merge it to.
The other is just a blue wire going into a ground plug and I will re-ground it in the WRX plug.
Thanks in advance,
Ryan
Ko3n3k3 is offline   Reply With Quote
Old 05-06-2012, 09:19 PM   #2
Ko3n3k3
Member#: 273925
I think it is a power wire that i can splice into the power for the o2 sensor but i'm not sure
Old 05-10-2012, 09:41 AM   #3
Ko3n3k3
Member#: 273925
Also, from more research i've found the wrx is a "MAF" car and the rs is a MAP car but i know there are different tuning thoughts involving these two things which confuses me more. Do turbocharged cars have MAFs and naturally aspirated have MAPs?
01 rs to 02 wrx coilovers down2earthsubie Brakes, Steering & Suspension 3 02-11-2008 11:31 PM
00 rs to 06 wrx sus. question E6V6I6L Brakes, Steering & Suspension 0 10-15-2007 01:44 AM
doing a 02 rs to 02 wrx swap. have a question simprezl25 Subaru Conversions 0 06-21-2006 02:11 AM
any aftermarket alarms direct plug in to 02 WRX harness? GDA Car Audio, Video & Security 1 08-09-2001 12:48 PM
Custom Short Shifter design help, it is worth it :) 2000 RS to 02 WRX..... joostin420 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-14-2001 09:41 AM
