Old 03-25-2012, 01:38 AM   #1
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Default Bmxpunk's rallycar build
So here is my rallycar project that has been coming for a long time. Bought this 95 imp Brighton in 2001. Later swapped on a 2.2t followed closely by a somewhat built 2.2t. During the second build I started to race stage rally in an open light impreza that a friend and I built. That's the car Justin Pritchard most recently used to school some open class cars at 100acre wood.
Most recently I had this cage completed by Grant and Scott at the Colorado Rally Group. Its a very tight fitting cage and the CRG guys took their time with this and will be offering these cage kits for gc bodies soon.
Suspension arms will all be provided by William at TSSFab.
With lots to do still, first event I hope to make will be temple canyon hill climb in Colorado in early may.
bmxpunk is offline   Reply With Quote
Old 03-25-2012, 12:32 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Are you going to mount the shoulder harnesses to that current bar behind the seat? It looks a little low.
yarrgh is offline   Reply With Quote
Old 03-25-2012, 11:02 PM   #3
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I looked at that today and at the rules again so it's something I want to look into more. And if someone could explain the rule to me. I saw the 10* or less part, then the drawing in the RA rule book makes it seem like the angle of the seat comes into play.
Shouldn't affect the codriver as that seat is lower, and I am looking for slightly lower brackets myself.
Also looking at the fia rule it says between horizontal and 45*with 10 being optimal.
Old 03-26-2012, 07:13 AM   #4
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
The RA text says between horizontal at 10*, but the picture in the rule book appears to be a generic FIA drawing that supports the FIA rule you quoted above.
Call Mike Hurst at RA and send pics.
Jard is online now   Reply With Quote
Old 03-26-2012, 07:38 AM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Rules or not, that bar is way too low to mount harnesses.
Old 03-26-2012, 08:41 AM   #6
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Is TSSFab going to do front control arms for you too? I've see all his other work, but did not think he was doing those for GC track width cars.
Old 03-26-2012, 10:00 AM   #7
bmxpunk
Member#: 89599
1995 almost 22B:)
red
My car is going to have the sti track width. I just installed some 07 sti front arms last night, until TSS has the front design down. Going the sti route I figured finding/buying/begging/borrowing spares will be easier.
As far as mike hurst goes, he has all of these pictures and more and has already sent my log book.
Old 03-26-2012, 12:00 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I'm looking forward to seeing this car done and racing. Given your 2009 Colorado Cup Open Lights title in your old car, I know that you've got what it takes to get it done. Here's hoping to be involved in this car like we were with the last one...
Old 03-28-2012, 10:24 PM   #9
rexracer23
Member#: 282211
2004 WRX
Like the progress so far... What's your estimated budget if you don'd mind me asking?
rexracer23 is offline   Reply With Quote
Old 04-12-2012, 02:11 AM   #10
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I don't know if I could pin down a budget.
Do as much as I can laborwise myself to keep cost down. Get much appreciated help from friends in the forms of discounts, labor, and knowledge.
I do nearly any side work I can find which is everything from car repair to cat sitting (not kidding in the slightest there).
To give you an idea I will have around $6-7000 in safety gear alone. Of course that has been spread out over some time.
Old 04-17-2012, 12:59 PM   #11
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Doesn't appear to be that low to me, from the second picture. Defnintely rather have it a little "too" low than too high.
rallynutdon is offline   Reply With Quote
Old 04-17-2012, 10:59 PM   #12
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I measured and the bar is about 15* below on the drivers side and my seat is laid back about 18*.
Old 04-24-2012, 09:24 AM   #13
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Here is my engine management solution. At least for the time being.
this board is made by enduring solutions ltd out of the uk. It plugs directly into the socket on most ej20g (or20k) ecus and is tuned via laptop through the data connector. It makes the old ecu's tunable like the modern units. I like the fact that it keeps factory functions like knock control and closed loop boost control. It's the second most affordable EM solution besides the rob tune, but it gives me a little more precision to deal with the 34mm restrictor that has to go on the turbo. It is also possible to switch between 2preloaded maps in the ecu without having to reattach a computer. Motorsport functions like anti-lag and launch control are rumored to be in the works for this summer.
Old 04-25-2012, 06:58 AM   #14
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
So how much is it?
Old 04-25-2012, 11:27 AM   #15
bmxpunk
Member#: 89599
1995 almost 22B:)
red
After shipping and the cable to tune it, just under $600.
Old 05-02-2012, 11:09 PM   #16
bmxpunk
Member#: 89599
1995 almost 22B:)
red
A friend whipped these up for me today. time to get welding.
I have a new pedal set on the way with a balance bar and dual masters so it's time to invest in some brake hard line. Schroth harnesses also on the way. TrAnsmission has to come out for some new gears and a new front differential. First hill climb I am trying to make is June 16 so I have some work ahead of me.
Old 05-03-2012, 08:09 AM   #17
Aceyduce
Member#: 194449
2011 Mazda, 2003 WRX
Black , WRB
What pedal set did you go with? I've been thinking of going down that path.
Aceyduce is offline   Reply With Quote
Old 05-05-2012, 11:54 PM   #18
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Some welding work completed tonight.
And a little painting after
Old 05-13-2012, 06:53 AM   #19
raynman
Member#: 320016
What are you doing as far as gearbox goes?
I know it costs, but a 6 speed with a competition front LSD goes a long way towards reliability.
We had a Legacy RS, 5 speed dog box. Kept breaking front crown wheel and pinions. A common occurrence the faster you go. It also depends how hard you are going to drive it and how much horsepower.
The setup we had in our GC8 (and later in the legacy) was an 06 6 speed with DCCD with a plated front LSD and motec centre diff controller. Worked brilliantly
raynman is offline   Reply With Quote
Old 05-13-2012, 10:19 AM   #20
3MI Racing
Member#: 200987
from Turn In Concept's at this weekend Global Time Attack at Road Atlanta:
Should be interesting to see if the Moore Sport brace kit can help with this.
Old 05-14-2012, 12:50 AM   #21
raynman
Member#: 320016
Is that a 5 or a 6 speed - looks like a 5
Impressive - front diff broke the casing
BTW - early 5 speed casings (I think they are the 4 bolt ones) are even more prone to breaking.
Old 05-15-2012, 08:20 PM   #22
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Head back from Mike Hurst today, harness bar does have to go up. Apparently I fall well within the FIA rule (max 45* recommend 10*) but not the RA rule of max 10*.
Because of the new pedalbox I also need to move the driver seat mounts back a bit.
I also wanted to add some support bars between the rear strut towers and from the bottom of the main hoop to the strut towers where the back stays meet. From reading the rule book and what other people have said I assumed I could use smaller diameter tubing 1" or 1.25" x0.095" but the email I received from Mike also said that isn't the case. Any additions to the cage must be at least 1.5"x0.095".
1 set forward 2 steps back.
Old 05-16-2012, 02:37 PM   #23
ayanooo
Member#: 278908
'07 OBP WRX
Imprezive
ayanooo is offline   Reply With Quote
Old 05-16-2012, 03:18 PM   #24
2005wrxowner1
Member#: 291158
2005 wrx
wrb
that cracked diff is not good dude. nice car otherwise. i like old 2.2s
2005wrxowner1 is offline   Reply With Quote
Old 05-16-2012, 07:38 PM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
Looks like I need to make a call to TIC tomorrow morning...
2007 Subaru WRX Wagon - all JL Audio build chithead Car Audio, Video & Security 8 04-06-2012 02:27 AM
My "taking forever" rallycar build ... Tbagger Member's Car Gallery 20 09-01-2009 09:23 PM
70's Rallycar FengShui Member's Car Gallery 8 04-06-2002 05:06 AM
Where to get rallycar sounds? RallyKid General Community 1 01-31-2002 11:47 AM
Rallycars book by Reinhard Klein stiggy-pug Motorsports 9 05-01-2001 04:15 PM
