Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 04-11-2012, 02:29 PM   #1
SubiBratz
Member#: 311904
Default My 1978 Subaru Brat With Franken Motor [PICS]
So I pulled a mint 1978 Brat out a barn that was sitting 20 years before she saw the road again. Long story short, got tiny 1.6 running and was really unhappy about the power of the motor so MY SWAP BEGAN!!!!!!
I found a running 1991 Legacy Sedan for the brat to HUMP.
I took the entire running gear and suspension and I mean everything..
SubiBratz is offline   Reply With Quote
Old 04-12-2012, 12:24 AM   #2
SubiBratz
Member#: 311904
This is the cross member that had to be shortened to fit the brat's body. Gave it p/s!!!
Old 04-12-2012, 03:59 PM   #3
04trailsti
Member#: 179170
thats awesome ive been wanting to see a legit brat swap for a long time. I will be following this. Ive never seen under a Brat does it share the same subframe design as 93 newer Imprezas/legacy
04trailsti is offline   Reply With Quote
Old 04-12-2012, 04:17 PM   #4
SubiBratz
Member#: 311904
Thanks.. I seen a whole bunch of Gen 2 brats with a swap/ adpter plates to mate engine and tran, five lug parts of 3 different subarus XT6 ect to give the car 5 lug.. LOL This is what I did...
Old 04-12-2012, 04:20 PM   #5
SubiBratz
Member#: 311904
You can see the crossmember shortened with power steering and the custom Legacy A-Arms Brackets. Also a peek of the Custom Trans Mount.. Pretty COOL HUH?
Old 04-12-2012, 04:26 PM   #6
SubiBratz
Member#: 311904
These are the Legacy's A-Arms welds and custom bracket..
Has anyone done this or is this the First!!!!
Old 04-12-2012, 07:45 PM   #7
D3F0
Member#: 265799
1988 Subaru RX TURBO
Wow this is cool excellent work and I have never seen that online and Ive looked at a lot of conversions haha
D3F0 is offline   Reply With Quote
Old 04-13-2012, 07:44 PM   #8
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Wow the only first I see in these pics is a 1978 brat not rusted beyond repair. You must be in the desert.
Does the EJ22 fit between the brat frame rails?
Scoobie Steve is offline   Reply With Quote
Old 04-14-2012, 12:54 AM   #9
SubiBratz
Member#: 311904
Frame Rails needed to be modded to fit the valve covers. Also the Trans Tunnel wasn't going to work with the new 5 Speed trans. So trans tunnel was created....
Old 04-14-2012, 03:00 AM   #10
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
pretty sweet!
You are not the first to do this however. I've done it. Although yours will probably be the first to run and drive...
I did it slightly differently. I used the legacy rear suspension but I used the stock brat front crossmember. I got custom control arms to mount the 5 lug stuff so I still have manual steering and such. Also used an adapter plate and used an RX transmission which is slightly smaller so it fit in the factory tunnel. Not by much though... What did you do with the tie rod lengths from shortening the crossmember?
Zefy is offline   Reply With Quote
Old 04-14-2012, 11:10 AM   #11
SubiBratz
Member#: 311904
Tie Rods had to be made custom. I will get pics of the Tie Rods and show what we did. My P/S works a little to well, I can almost sneeze and take a right hand turn just from the wind.LOL This is the Rear Hubs welded.
<a href="http://www.flickr.com/photos/77121483@N04/6922394578/"
Old 04-14-2012, 11:13 AM   #12
SubiBratz
Member#: 311904
This is the 2.2 Legacy motor after being pulled from the parts car.
Old 04-14-2012, 11:19 AM   #13
SubiBratz
Member#: 311904
This is the Franken Motor..
2002 Legacy 2.5 Block
1991 Legacy 2.2 Dual Port Heads
Cometic Hybrid Gaskets
Can you say sexy...
Old 04-15-2012, 12:10 PM   #14
SubiBratz
Member#: 311904
I drove it last night..... OMG can you say smiles. Feels like rocketship on rails... Need to install a surge tank had a little issue with it sucking air but I only had a little less than a 1/4 tank...
Wrx's here the little brat comes, feels alot faster than any WRX I drove, maybe all the torque this burger has.
I figure the power to weight ratio is crazy.. Like 2000lbs with I am guessing aleast 170-180 H.P. and about the same amount of torque..
Old 04-18-2012, 12:27 PM   #15
SubiBratz
Member#: 311904
Does anyone know where I can get a Surge Tank for a decent price?
Old 05-02-2012, 12:16 PM   #16
SubiBratz
Member#: 311904
Check out the new stance....
Old 05-02-2012, 12:18 PM   #17
SubiBratz
Member#: 311904
The powerplant... Franken
Old 05-02-2012, 02:15 PM   #18
Subachouli
Member#: 98777
This.. is .. awesome!
Well done.
Subachouli is online now   Reply With Quote
Old 05-07-2012, 07:47 PM   #19
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Man, Well done!
Nice color too.My first Subby was a 1978.
sense of nature is offline   Reply With Quote
Old 05-07-2012, 08:36 PM   #20
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
That's freaking awesome!
Did the strut towers have to be modified, or did the suspension bolt in?
BeBop86 is offline   Reply With Quote
Old 05-07-2012, 09:40 PM   #21
njwrxman21
Member#: 132568
03 wrx
wrb
freaking awesome !!! nice work !!!!
njwrxman21 is offline   Reply With Quote
Old 05-07-2012, 11:22 PM   #22
SubiBratz
Member#: 311904
Thanks everyone for all the awsome feed back... Yes the strut towers need to be widened a bit to fit the Legacy's struts. Pretty much nothing was a direct fit with this project except the rear diff... direct fit... LOL
Old 05-07-2012, 11:28 PM   #23
SubiBratz
Member#: 311904
The color of the car is Subaru #85. I have the window sticker for the Brat when it was purchased in WA and it told me all the options it came with...
In 1978 the car cost 5,785 and came with 22 options crazy huh?
Old 05-12-2012, 10:50 AM   #24
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I love this build and can't wait to see more. What did you do for exhaust? I'm guessing custom but was wondering if a borla header would fit for that subie rumble. Light weight plus torquey motor is a winning combo.
Does the hybrid run well with just putting premium gas in it?
geronimo81 is offline   Reply With Quote
Old 05-14-2012, 11:31 AM   #25
SubiBratz
Member#: 311904
The exhaust is was done by a local exhaust shop and sounds pretty mean. I dont have a borla headers and they would or I mean should fit but never tried. I plan on running this a the track to see what 1/4 mile time this thing can do. Any one want to guess what time this Brat will put down?
FS : UT: 1978 Subaru Brat - Restored & Documented ninefourteener Private Vehicle 'For Sale' Classifieds 15 06-18-2011 12:58 AM
FS : 1978 Subaru BRAT - restored & documented ninefourteener RMIC Private Classifieds 18 06-13-2011 08:06 PM
1978 Subaru Brat mini Truck 4spd 4x4 CD Lots of PIX & NEW parts (Phx, AZ) JapCarRealGood SWIC Private Classifieds 11 04-30-2009 03:07 PM
Subaru BRAT with foot wide super swampers Pipercub Mid Atlantic Impreza Club -- MAIC 16 06-01-2002 01:42 AM
