Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 05-08-2012, 04:45 PM   #76
Ryeeno
Member#: 117161
'02 WRB WRX
'10 Forester XT
Yeah, that was my initial thought, that using the passenger seat would add a little distance for those low frequency waves to develop.
I've been all over google and search without finding anything dedicated to which seat will sound better to the driver.
My kid's car seat is on that side too so no feet kicking it.
Ryeeno is offline   Reply With Quote
Old 05-08-2012, 04:53 PM   #77
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
It's a moot point if you have time alignment in your headunit.
You just measure the distance and dial in the delay required.
-- Dave
AcquaCow is offline   Reply With Quote
Old 05-08-2012, 04:58 PM   #78
Ryeeno
Member#: 117161
'02 WRB WRX
'10 Forester XT
I don't have that on my HU.
It's a lot of work to get a little more bass.
Old 05-08-2012, 05:40 PM   #79
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Well, if you woofer was completely out of phase, you'd have no bass =)
But then you could just reverse terminal polarity to solve that... odds are you'll be somewhere in the middle.
-- Dave
Old 05-08-2012, 07:14 PM   #80
Cardiff Giant
Member#: 40325
2013 Nissan Rogue
Seeing as this thread was bumped thought I'd mention that the Kenwood I posted earlier in the thread completely died on me a while back. It was still powering on and everything but was producing no sound. I checked everything (tried different cables,different outputs from my HU) and no luck. Since I bought it from an amazon seller who wasn't a kenwood retailer I was out of luck in terms of warranty. Not sure if this is just a freak occurrence of if there is a known issue with them but I'm sub-less.
Cardiff Giant is offline   Reply With Quote
Old 05-08-2012, 07:23 PM   #81
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
If it makes you feel any better, I had a Kenwood amp that died on me about 10 years ago, and I sent it in under warranty. They fixed it, and turned it around in about a month, and it worked great... for a couple months, then it died again.
Wade-O is offline   Reply With Quote
Old 05-08-2012, 08:08 PM   #82
phenryiv1
Member#: 91212
2011 WRX 5DR
Put it under the driver's seat. Bass is supposed to be nondirectional, but if you have it under the passenger seat you have more volume coming from your right.
With it right under you there is no perception of a discrepency from side to side.
Old 05-08-2012, 08:25 PM   #83
Ryeeno
Member#: 117161
'02 WRB WRX
'10 Forester XT
Interesting point. Just when I had decided on the passenger seat. Thanks a lot!
Old 05-08-2012, 08:48 PM   #84
phenryiv1
Member#: 91212
2011 WRX 5DR
I had a Clarion underseat sub under the passenger seat in my 2008 Legacy and was annoyed that it always seemed like more volume was coming from my right.
I would have changed it to the driver's side but the drivers side (only) was a power seat and the motor was in the way.
Old 05-09-2012, 10:48 AM   #85
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
if you have the crossover set correctly, you shouldn't be able to determine left or right... but if you have the sub playing higher frequencies for more mid-bass fill, then yeah, you'll probably notice it.
I have my subs crossed in at about 90Hz.
-- Dave
Old 05-09-2012, 04:53 PM   #86
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
For these under seat subs that's probably a bit too low. The published frequency response for the B-8PT is 40-200 Hz. If I set my crossover to 120 it seems to cut out most of the unwanted "noise" but at 90 it cuts out almost everything. I still haven't really found a sweet spot, so I'm constantly adjusting it depending on the music I'm listening to.
Old 05-09-2012, 07:43 PM   #87
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Aah... their kung-fu is weak!
Old 05-11-2012, 10:06 PM   #88
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
Sad but true. I was playing around with it yesterday and it drops off significantly around 55hz.
Old 05-15-2012, 01:45 AM   #89
Ryeeno
Member#: 117161
'02 WRB WRX
'10 Forester XT
So I'm doing the install this week with the sub under the passenger seat and I have a question. This is my first attempt at anything like this, btw.
I'm going to put the power line through the driver's side grommet and down the sidewall under the door jam to the under seat but I'm wondering what the best way to go from that side across the car to the passenger seat.
Do I go under the carpet under the driver's seat, across the center console (inside) and then down under the passenger seat?
I think I'm pretty clear on the rest. (famous last words)
Old 05-15-2012, 02:09 AM   #90
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
Yup, that's exactly how I did it. There are lots of spaces under the carpet to route the wire through.
Old 05-15-2012, 02:11 AM   #91
Ryeeno
Member#: 117161
'02 WRB WRX
'10 Forester XT
Cool thanks. Still haven't decided whether to go from the HU to the sub down the center console or passenger door sill.
Old 05-15-2012, 02:16 AM   #92
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
I ran my remote turn-on and RCA interconnects down the center, and power down the driver's side.
Old 05-16-2012, 11:18 AM   #93
Ryeeno
Member#: 117161
'02 WRB WRX
'10 Forester XT
All done! I took my time and tried do everything as neatly and invisible as possible so it took me around 3 hours or so. Thanks for all the tips.
Today will be lots of setting tweaking but initial tests sound great. That's all the bass I need.
It's under the passenger seat and I'm thus far not noticing the sound coming from the right. Being able to feel it under my butt would have got on my nerves more.
Old 05-16-2012, 11:53 AM   #94
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
My wife instantly comes down with a case of the giggles whenever we take my car anywhere.
Old 02-05-2013, 03:13 AM   #95
Classictint
Member#: 344571
2005 Sti Sedan
Bump
Bump
Bump
Classictint is offline   Reply With Quote
Old 02-05-2013, 04:12 PM   #96
evilspoons
Member#: 321311
2012 STi 5-door
Focal also makes an under-seat subwoofer. I was considering this until I just ended up buying a regular 10" subwoofer from them to go with the Audio Integrations sub box in the hatch.
Anyone still thinking about an under seat sub, check it out: http://www.focal.com/en/plug-play/27...050750135.html
evilspoons is offline   Reply With Quote
Old 01-27-2014, 09:32 PM   #97
GSR2STI
Member#: 342219
2014 WRX
Time to bump this up again! I am in the market for an under the seat sub. Any new products out there or do you guys still recommend the SO one? I like that if you buy it from Crutchfield you get the free wiring kit. Great price at around 150-160.
GSR2STI is offline   Reply With Quote
Old 01-28-2014, 12:31 AM   #98
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I think this may still be available... one of the raam audio boxes: http://forums.nasioc.com/forums/show....php?t=2581159
-- Dave
Old 02-28-2014, 02:35 PM   #99
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
Probably going to post mine for sale soon, just have to figure out what the shipping is going to run so I can price it accordingly. I upgraded to a 12" in an Audio Integrations enclosure about a year ago.
Old 02-28-2014, 11:31 PM   #100
Cwbrig
Member#: 308568
2013 WRX Base
ISM
I just installed a kicker hideaway under the driver seat in my '13 base wrx. I love it, though its a bit much for my old ears so I keep it turned down to a reasonable volume. (Extra points if you read the last two words in Milton's voice.)
I had an extra wiring harness from installing an oem sub in my wife's '10 FXT with nav.(they give you both harnesses with the sub)
Cwbrig is offline   Reply With Quote
FS : Stock subaru under Seat subwoofer Jaebin03 MWSOC Private Classifieds 4 02-20-2011 03:55 AM
OEM Subaru Under Seat Subwoofer with PnP Harness Ruff Interior/Dressup/Audio & Security 8 03-12-2010 10:34 PM
Genuine Subaru under seat subwoofer / amplifier carbonwrxfiber Interior/Dressup/Audio & Security 0 02-22-2008 05:51 PM
4sale, NY : Subaru Factory Under Seat Subwoofer getek20 Private 'For Sale' Classifieds 3 04-26-2004 12:13 AM
Under-seat Subwoofer? Tarmac RS Car Audio, Video & Security 3 03-29-2000 05:07 PM
