Old 05-14-2012, 06:08 AM   #1
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
Default Camber bolts?
Alright I have a 2006 Legacy Sedan on stock struts and Tein springs and will be running some pretty aggressive wheels.
What camber bolts do you recommend? I'm looking to get 0-2 negative if possible.
I read that the Impreza camber bolts are the same and the front and rear camber bolts are interchangeable? Is this true. An help would be great. I really need to button up this set up before June.
ej25_TS is offline   Reply With Quote
Old 05-14-2012, 10:36 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
camber bolts aren't going to work in the rear. whiteline makes some product for the rear, but I can't remember what they call it.
fibuz is offline   Reply With Quote
Old 05-15-2012, 04:58 AM   #3
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
why does this video say the bolts do work in the rear?
Old 05-15-2012, 08:04 PM   #4
brysawn
Member#: 219379
If the video says it, then why are you even asking?
brysawn is offline   Reply With Quote
Old 05-16-2012, 07:38 AM   #5
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
Because I have yet to find a single person who has used them in the rear. Everyone says they will not work.
Old 05-16-2012, 08:38 PM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Old 05-17-2012, 03:09 AM   #7
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
awesome thanks for the info and links fibuz
Tokico D-Specs + Camber bolts = less camber than stock struts without camber bolts?! formula91 Brakes, Steering & Suspension 10 09-07-2009 12:59 AM
Removing Negative Rear Camber with camber bolts? NicGordon Brakes, Steering & Suspension 1 08-15-2003 12:39 AM
rear camber bolts = front camber bolts? Penguinking Brakes, Steering & Suspension 1 07-12-2003 10:01 PM
why can you use camber PLATES in STX, but not camber BOLTS!? rex n effect Motorsports 2 05-12-2003 02:32 PM
Can only get 0.5 negative camber with camber bolts? Tronner Brakes, Steering & Suspension 1 08-23-2002 08:56 PM
Message Board Statistics All times are GMT -4. The time now is 11:58 PM.
